Question about Jenn-Air JGR8855BDS Gas Kitchen Range
Oven does not heat up
Jenn-Air Gas Stove - JGR8855ADS - bought 2001. Oven takes about 10 minutes to get to 120 or 130. Very irratic. Started a few months ago, got better, now we can't get it to heat up at all. Stove-top and broiler work fine.
  • 1 more comment
  • sdhaggard Sep 08, 2008
    HOW OR DID YOU GET THIS FIXED
  • RLMR Jan 18, 2009
    Ditto on the problem and our's was purchased about 2003.  But our oven problem has been going on for almost a year. We used to be able to pre-heat on broil, then go to bake and it would work adequately, but now all it does is pulse and not really heat up at all. Burners / broiler work fine.  We think it may be the oven control module or the touch pad gone bad (ie parts not communicating with each other). We know a good service guy and are trying to contact him for advice.
  • Lin928 Jan 18, 2009
    We appreciate your reply. We did finally call a repairman and it was the 'ignitor'. It cost about $150+ to repair and he had the part with him so it ws a quick fix. That was about 5 months ago and it is still working fine. My husband said that he probably could have repaired it himself too. Had a similar problem with our Rheem furnace a few years back. Accordinging to that technician, the ignitors can wear out. The furnace has been fine since then also. Hope this helps.
We may have found it -  google Maytag Gas and Electric Range Service Manual (1997 models to present) and save it as a PDF to your desk top.  Then print out the PDF pages # 18, 25 & 26, 52, 62 65 & 66.  Those pages sound exactly like the problem we're having, which sounds identical to the problem you're having. We now suspect the issue is the gas valve heater coil and the volts it needs for ignition.  Because without enough volts, the ignitor won't ignite (like, duh?).  The specific PDF page is # 66 in reference to the Glow Bar Operation item # 4. If we're right, we'll need to get three small parts, totaling about $60 in all.  Let's hope this is the solution!
Posted on Jan 18, 2009
Tip
Bought a used Gas oven but top Burners are having low flames..
hi<br />i have model#JGR8855ADS<br />on top burners flames are very low..even high performance one is low..what sould be the problem...pls help me ???
on May 10, 2011 | Jenn-Air JGR8855BDS Gas Kitchen Range
Model JGR8855ADS is reading Code F9. what does
Hi There
I have this code for you. hope this helps you.
F9 Door latch Check door latch components.Thank you for writing to fix ya.
Best Regards Richard
Feb 18, 2010 | Jenn-Air JGR8750 Gas Kitchen Range
It is slow to heat up
The oven ignitor is slowly going out...it needs to be replaced!
Oct 25, 2009 | Jenn-Air JGR8855BDS Gas Kitchen Range
Re: Jenn Air #svd48600b Gas Stove Top works... Oven and Broiler not working(Elec.) I replaced Electronic oven control assy...It works correctly, but never gets Hot!! Any ideas??
Having a problem with the stove on this Jenn Air svd48600b.
Often with the oven warms up to 350F it starts beeping at and shuts off.
It flashes either just an FC error code, or FC and F5.
It is often possible to get the oven to work again if you wait 10-15min and cycle the power.
I imagine something is wrong with a heat sensor? The temperature sensor responsible for displaying temperature on the control panel seems fine though.
One other detail, even when the oven doesn't shut off at hot temperatures, the fan comes on (at around 220F) and stays on for over an hour after the oven is turned off.
Does anyone know if there is a different temperature sensor that might cause this? Is there a specific electronics board that may be leading to this problem.
when it heats up.
Aug 24, 2009 | Jenn-Air Kitchen Ranges
GE gas stove the burners on top work, the oven won't get hot
The most common reason a gas oven won't heat is a bad igniter. It is located near the valve and burner under the oven bottom. You can usually see it glow orange just before the fire lights. Most GE ranges take a cylindrical igniter part #WB2X9154 or #WB13K21 rectangular igniter.
Jan 02, 2009 | Jenn-Air JES9750AAS Electric Kitchen Range
JENN-AIR Oven shuts off and comes back on after several minutes
they are equiped with a heat sensor it could be a bad thermastat(sensor) or
ventalation problem
Nov 20, 2007 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-aire gas stove
  If this is a gas range your problem is most likely your oven ignitor.  As they get older they get weak and takes longer to open gas valve.  Eventually it won't come on at all.  Replacing the oven ignitor will often take care of problem.  BE SURE TO UNPLUG UNIT BEFORE REPAIR!!
  Remove oven floor.  The ignitor is in a cage attached to back of oven burner.  It mounts with 2 screws.  You may have to cut wires and wirenut in replacement.  Doesn't matter if the 2 wires are reversed.
Oct 24, 2007 | Jenn-Air JGR8850 Gas Kitchen Range
Jenn-Air JGR8855BDS Gas Kitchen Range Logo
506 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
