Question about Saniflo Home
The toilet keeps flushing itself, sometimes every couple of minutes. what can I do?
    Problem Solver:
  • 9 Answers
Is the float set correctley if not it may be overfilling and the toliet will flush itself at a certain level.
Posted on Jan 05, 2011
Toilet is running
The most common reason for a toilet to continue to run is a problem with either the flapper or the entire flush valve itself. The water is slowly draining so the fill valve keeps running.
The flapper is the least expensive and easiest solution, so start their. It's usually around $5. If that doesn't solve the problem, I would purchase a flush valve kit, around $20, and replace your flush valve.
*Note: If you have to replace the flush valve, you have to take your toilet apart. Start with the flapper.
Feb 27, 2015 | Home
How do I know which pieces I need from a hardware store? I'm visiting my mom for a couple days and her toilet just stopped working. I think I need a couple pieces from the hardware store, but I'm not...
The normal way would be to look at the toilet first. There are a number of parts that wear out or break..
The most common is the chain that is attached to the flush lever breaks or pulls out from the flapper in the bottom of the tank.
Sometimes the lever itself will break inside the tank. There is also a metal hook that joins the lever to the chain that lifts the flapper, those can corrode, bend or break.
Sometimes the flapper will leak, but that just makes the tank keep trying to fill itself every 5 to 10 minutes.
If the inlet valve is broken, it may not let water in at all but that is rare.
Just take the lid off and look. That hardware chain has all the parts. They are listed on this page.
Plumbing Supplies Toilet Parts Do it Best
There are a load of videos here showing the various fixes. They are all very easy. I dare to say "even a woman could do it". :>)
fixing toilet flush system Google Search
Sep 30, 2017 | Home
What are the most common venting problems for toilets?
What all that means is the sewage pipe going to the street is getting clogged so either snake it with 50 foot snake or go buy so Drain-O (60 ounce bottle costs about $9) and pour 1/5 in toilet and wait 10 minutes then pout 1/5 in Bathroom sink & wait 10 minutes. Keep do that until 60 ounce bottle is empty. Let this stay in pipes for couple hours and your toilet will double flush now its clean with no corrosion, hair, cooking oil, and other debris.
Apr 17, 2014 | Home
I have a toto toilet that doesn't start to refill until a couple of minutes after I flush. Any ideas. Thanks.
Several ideas. Start to fill? Have you looked inside the tank to see what's going on? If it just filling very slowly, then you most likely have some calcuim build up inside your flush valve blocking some flow, if this is the case you will have to clean the flush valve. If your flush valve is staying up and the toilet is "running" unitil the float drops. The float (either the arm ballcock style, or newer fluidmaster) is rubbing on either the flush lever or side of the tank, and taking longer to drop to let the water start flowing. I
Jun 23, 2010 | Toto Toilets ST784S 12 Sedona Beige...
I bought a toilet from homedepot in toronto 6 months ago. from yesterday, it keeps to refill the tank like every 10 seconds. but i can not see where the water leaks
There are a few likely causes for a toilet to leak and refill. The most common is the flapper not seating properly. Usualy on an American Standard it is a disc. Either way, they are fairly easy to replace. One test I use to see if the leak is comming from the flush assembly is to put a couple drops of food coloring in the tank and wait a few minutes to see if it appears in the bowl. If so, there is a leak in the flush assembly, usualy the flapper. Hope this heps. Please vote to let me know.
May 12, 2010 | American Standard 2860.334 Enfield Two...
Toilet takes vey long to fill the tank.
More then likely the power valve in your flush master ball valve is out.. Replace flush valve and should fix problem. Home depot sell fluid master for like 7.50
Mar 02, 2010 | Kohler - Toilet - Two-piece - Highline -...
Kohler 81100 Pressure-Clean Flushometer Toilet
This type of flush system can be re presurised quickly by holding down the flush handle for about good 2 minutes, then release , wait for the tank to be refilled with water.
Now you can flush away your inner rotting mess down tube good-by...
Dec 26, 2008 | Home
Home Logo
310 people viewed this question
Top Saniflo Home Experts
Donni Steen
Paul Carew
Are you a Saniflo Home Expert? Answer questions, earn points and help others
