Question about Vacuums
Drive went out on my Hoover Steam Vac Shampooer and brushes won't turn plus there's a burning smell coming from it. Only used it 6 times - bought it in March - 2008.
Http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=761326
Generic problem for all Vacuums
Posted by buster_lls on Jul 09, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It sounds to me like you have multiple problems with your power drive; a burning smell and the brushes don’t turn, and the dop is on March, 2008 – the Hoover Steam Vac Shampooer has a one year factory warranty and it could be a broken part for the brushes won’t turn or a belt would cause the burning smell. If it is not the belt or broken part it probably is the motor of which you should take it to a authorized Hoover vacuum cleaner dealer in your area or to contact the Hoover factory cust serv listed below or the Hoover website for information. If it is the motor the factory authorized dealer will replace the part for the motor and the broken part for the brushes, if it is the belt that would be an out of pocket expense. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jul 09, 2008
My hoover steam vac is making a horrible noise and smells like its burning
Something may have jammed the brush roller, preventing rotation. This causes the motor shaft to rotate in one spot on the belt, causing the burning rubber smell. Eventually, the belt will break. You need to find what caused the jam and remove it. It would be a good idea to replace the belt as a burned belt is unlikely to last much longer.
Dec 18, 2014 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover Steam Vac Replacement Drive Brush instructions
Here's a link to the diagnosing:
http://www.fixya.com/support/t4286338-hooverspin_scrub_brushes_always_stop
And if you find out that you need to replace the turbine, here's a link that shows you step by step how to replace the turbine:
http://www.fixya.com/support/r4530769-diagnosis_fix_hoover_steamvacs_when
Sep 01, 2012 | JTRhomeswarehousecom Hoover Steam Vac...
Is my 6215-900 brushes drive driven by a belt? I
No, there isn't a drive belt on the Hoover Steam Vac models.
Oct 24, 2009 | Hoover F6212-900 / F6215-900 SteamVac...
Bissell carpet shampooer wont dispense water
Bad Pump. You pump is where the belt attaches to spin the brushes and also puts water on the floor. Take it to you local Best Buy to be serviced or a local appliance shop which may service it.
Dec 15, 2008 | Bissell ProHeat Turbo Deep Cleaner Upright...
Spin brush removal
Brush Disassembly Hoover STEAM VAC Owners Manual F9514-900 (F9514900) does not
explain how to take the brush assembly apart. The instructions are as
follows:
Figure 1 shows the key
features. There are two
clear plastic outer pieces
which are held onto the
white inner piece with 3
tabs each. The clear
plastic tabs go underneath
the corresponding white
extended tabs on the white
plastic inner piece.
Figure 2 shows where the
screwdriver is inserted
(flat blade) and gently
pushed down while pulling
the clear plastic outer
piece away from the inner
white piece.
Figure 3 shows assembled
unit. Note extended brush
axle goes in center, which
fits into the female drive
unit on the shampooer.
I used the hose nozzle out
on the lawn to direct high
velocity water stream
trying to get the hair out
of the brushes. Hair and
fuzz remarkably entrained
in brushes, but I got 90% of it out.
Oct 19, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Hoover Steam Vac Spin Scrub Carpet Cleaner won't suck
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=728884
Hoover Steam Vac Spin Scrub Carpet Cleaner won't...
Posted by hoofbeats1 on Jul 01, 2008
My machine is a little more than a year old. I have used it about 5 times. It started leaking the third time I used it. The fourth time I took it out, the brushes would not spin (I did clean them and rinse them after use each time).
Now the engine screams and won't **** anything up. Do you have any suggestions? My last Hoover Steam Vac was great and lasted for 3 years! Hi,
I have a Hoover Dual V SteamVac F7425-900 that the brushes won't spin. The lint screen is clean & the brushes switch is in the on position.
It dispenses & sucks up the cleaning solution & water; just no brush action. Help
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The only thing that I can recommend is that you may have a bad switch, some vacs may have a broken belt or the drive mechanism inside the Hoover Dual V SteamVac F7425-900 in or by the brush assm section and is need of repair. Please check the trouble shooting section of the owner’s manual if you’re needing help and to save money. If you don’t have one then contact the Hoover factory cust serv. So, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
8 a.m. - 7 p.m. EST
Go Ahead. Use Us.
Jul 01, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
The brushes will not spin anymore and the switch to go from spin to locked does nothing this is on a hoover steam vac shampooer
Pull out the brush block, make sure it will turn and to see if the shaft is on it, the shaft goes up into the turbine. If the block is ok, then the turbine isn't working. You take it apart and clean out the turbine, or replace it.
Mar 29, 2008 | Vacuums
Belt on steam vac v2
The V2 doesn't use a belt, it uses a turbine to drive the brush block, If brushes are not turning, either the shaft on the brush block broke off, or the turbine is bad and will have to be replaced.
Dec 23, 2007 | Hoover F5906-900 Upright Steam Vacuum
HOOVER STEAN VAC 2 DEEP CLEANER
If you used any other cleaning solution other than Hoover, your Steam Cleaner will develop deposits in the turbine that drives the brushes. What happens is this:
Users pour other store bought brand cleaners in the reservoir to clean. Then they store the Hoover Steam Vac. While sitting in storage, the residue dries in the turbine and develops hard deposites, which ruins it. It will cost you about $100 to have the Hoover Store repair.
Cleaning Solution:
http://www.amazon.com/dp/B0002B8L26?smid=ATVPDKIKX0DER&tag=yahoo-kitchen-20&linkCode=asn
Oct 14, 2007 | Hoover F7220900 SteamVac V2 Upright Vacuum
Vacuums Logo
306 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
