Question about Miller MATIC 140 MIG WELDING PKG w/cart 907311011
Sould like it is running but the switch is still off. you can hear aload buzzing noise.
  • 407 Answers
Your machine must be under warranty still. Please send it back to your welding store and ask for switch warranty repair.
Posted on Jan 04, 2011
BUZZING NOISE FROM MY HEAT PUMP
Take a look at this YouTube page that explains with good videos what are some of the common problems with heat pump noise. The one that seems dominant is the defrost cycle a heat pump goes thru when it melts ice off the evaporative coils. In defrost cycle, The compressor runs but the cooling fan does not, so you will hear a loud buzzing sound and the unit sounds like it is stalled...because only the compressor is running to generate heat to melt coil ice.
https://www.youtube.com/results?search_query=American+Standard+5000+Heat+Pump+makes+a+buzzing+noise
Defrost cycle noise video:
https://www.youtube.com/watch?v=wudLk0WoIVo
Mar 06, 2015 | American Standard 5000 Heat Pump Unit
Buzzing in fuel filter xantia hdi diesel 2litre
pump noise is what you hear if noise is very loud or rough have dealer ck . other wise dont worry the noise is normal.
Jul 15, 2012 | Peugeot Liberte Cars & Trucks
I have an affinity washer and dryer. The last loand did not complete its cycle. It is partially full of water, but not enough to seap out. Itmakes a buzzing sound and will not spin. It is not the type of...
It sounds like the drain pump has stopped. If it still has water in it and you turn it on (in the spin only cycle) the drain pump should be running and you sould be hearing the water drain. The washer will not spin until the water is out. Depending on how handy you are determines whether you can access the drain pump and remove the obstrustion. There is also a trap to catch debries from going into the pump. This could be plugged, but normally you don't hear a buzz. You hear the drain pump working but no water going out. Good luck
Apr 23, 2011 | Frigidaire Affinity ATF7000E Front Load...
I own a 2003 lincoln navigator. I have a problem sometimes where I go to start my truck and all I hear is a buzzing noise coming from my fuse box on the passenger side of the truck by the passengers feet....
Its the relay in the fuse box by the passenger side floor board. Remove the kick plate and its either white relay on the top (one is mounted horizontal on the right or rear position and vertical on the front or left. Its $6 bucks at Auto zone. You can switch both of them around and the truck will start and run till you get the replacement. Steve
Feb 23, 2011 | 2003 Lincoln Navigator
My bmw x5 diesel 2002 not starting when engine has run for 30 or more minutes, and also sometime it does not start in the morning the battery is nearly dead. i have realised that even if i took the...
Hi , this sounds like you have a couple of problems , firstly with the non starting after the engine has been running ,,, this is normally fuel pressure retension or the pre supply pump under the vehicle is faulty , the easiest way to check the pump, is when your vehicle doesn't start with the ignition lights still on , see if you can hear a buzzing noise from under the vehicle just behind the left hand front wheel , this will only prime itself for approx 20 seconds so it may be easier to have the help of someone , if you dont hear the buzzing turn the ignition off for 1 minute and switch on again , if there is no buzzing noise , replace the pre supply pump , the seccond fault with the blower motor running with the ignition off is a simple fault , this will require a replacment heater resistor , the resistor fails and drains the battery so it will cure the blower fault and the flat battery, hope this helps , regards mark
Jan 31, 2011 | 2005 BMW X5
Kenmore model 66812694 - quits running, buzzing noise at restart
bad motor,when you hear that noise open the door,hold in the door switch with one hand and with the other spin the drum and have someone else start it while you do this,all your doing is helping the motor start to spin but it sounds like a bad motor,this could be from not cleaning out the dryer,if it's gas it should be done once a year,electric can go another 6 months because there isn't an open flame in there,if you clean out the dryer and vent line the clothes will dry on time,the parts will last longer and you won't have a dryer fire.
Nov 19, 2017 | Kenmore Dryers
My Air Conditioner makes a loud buzzing noise now. It didn't do that before, now it makes so much noise I can't hear anything over it
Buzzing noise - contactor. maybe a bug got in the contacts or maybe the coil is bad but in any case if you replace the contactor the buzz will go away.
May 23, 2009 | Goldstar Heating & Cooling
Driver Window
Sounds like a motor, or a s stuck mechanism. Either way the door panel must come off and this is no easy task.
Aug 04, 2008 | 2001 Ford Explorer Sport Trac
Problem has returned to Maytag fridge
I note this is a very old post. The compressor is not starting and what you were hearing was the PTC relay energizing followed by the KilXon thermal overload kicking off the compressor start sequence. What happens is that the PTC relays sometimes get a heated contact. Due to the weakened state of the contact it can cause a buzz. Even with a goo PTC relay you would hear the compressor buzz if it was not starting. In that case the run capacitor may have failed or the compresor rotor is internally locked at which point the start cycle will repeat every 3 to 4 minutes as the thermal overload cycles and the compressor will not start.
Thanks for choosing FixYa
Kelly
Jun 18, 2008 | Refrigerators
Miller MATIC 140 MIG WELDING PKG w/cart 907311011 Logo
165 people viewed this question
Top Miller Welding Tools Experts
Robert Lee
Level 1 Expert
Kory Ronning
Robert Monigold
Robert Monigold
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
