Question about Samsung Televison & Video
The pixels are distorting and the sound cuts out . its a 46" lcd samgsung what should i do ?
  • 734 Answers
If its condensation problem, leave the TV in standby and use it often to drive off moisture on the ciruits.
Posted on Jan 03, 2011
Philips Electronics 46PFL3908 46 sound distortion
sounds like you burnt up the amp chip only way to fix is to replace thw whole circuit board
Mar 24, 2014 | Philips Electronics 46PFL3908 46" 1080p...
We have an intermittent pixel problem and sound distortion
Check the connection at its LVDS cable [the flat cable that connects its T'con to LCD panel for any loose contact. Re-seat this cable once and check. To get some details, http://electronicshelponline.blogspot.com/Pull up older posts.
Dec 09, 2013 | Sony BRAVIA W-Series KDL-46W4150 46 in....
My 46 inch samsung has a picture distortion, it's like it has a mirror image , how can i fix this?
Anthony, you did not list a model #. If you would it makes it eassier to determine what may have happened with your Samsung TV. An LCD would start with LN46----.
I have had screen issues with some samsung product. As well as other makes of televisions that use Samsung 46 inch dislay lcd.
Mar 02, 2013 | Samsung LN-T4661F 46 in. LCD HDTV
DP42647 On half of our 47 inch screen it is black and distorted when we first turn the TV on but after 30 or 40 minutes it finally just lights up and is fine.
Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish board that call the T-CON board for the replacement.This board sit in the middle at the bottom of the LCD screen panel.This T-CON board only job are to decodering picture pixels dots only before it show up to the LCD screen panel.
Jun 10, 2011 | Sanyo DP46849 46 in. HDTV
TV signal seems to "crack" with pixel distortion.
This is what digital signals do if there is not enough signal to paint the picture on your set. If you are using an antenna, then the signal coming from the station over the air is not strong enough or is being blocked by the trees and buildings. The TV needs a signal at least 60-70 % to get the data, and since the FCC mandated higher frequencies for over the air TV, the stations signal will not travel very far. You can try a better TV antenna, with a higher DB gain, but it seems to be a loosing battle for the present.
If you subscribe to cable TV and it is happening, then by all means complain to your Cable Provider as they should send yo a signal that will run your set.
Jan 17, 2011 | Sony KDL-46XBR4 46 in. LCD Television
The picture of our jvc LT-46FN97 will suddenly distort
Sounds to me like the digital pixeling that occurs with a weak signal. You have not identified whether this happens on broadcast/antenna TV, cable or satellite service, or a video input such as a DVD. This can be a common problem if you have a weak signal on any of those inputs. In any case, blowing out the dust will not help.
Dec 15, 2017 | JVC LT-42X688 46 in. LCD HDTV
Pro pixel LCD tv has sound but not picture, can see a flash when it is turned on but goes black
Refer to others I have posted to for this topic...defective lcd controller board.
Thanks
Josh
Oct 30, 2007 | Samsung LN-S4692D 46 in. LCD HDTV
Televison & Video Logo
32 people viewed this question
Jerry Greenberg
Jerry Greenberg
