Question about Pentax Cameras
Pentax optio stuck on green mode cant do anything other than take pictures and internal memory full
Click on the green button with the picture of the trash can... i have a pentax optio m50 and it worked for me!
Posted on Feb 13, 2009
How do i remove green mode on a camera pentax RS1000
Pentax Optio RS1000 Digital Camera Green - Questions ...
www.fixya.com > ... > Optio > Pentax Optio RS1000 Digital Camera
turn green mode off my camera how to turn offf green mode just hit the green button, its the delete pic button as well, but it can be used to turn green mode on ...
Oct 27, 2015 | Pentax Cameras
I have a Pentax Optio E40 and get the message that the built in memory is full. How can I see what is in that memory? Can I delete those pictures to clear the memory?
Yes you can play back the images and/or delete them from the internal memory from the camera. I strongly recommend an SD card in the future. The internal memory can hold a maximum of about 87 pictures at the lowest resolution (2 pictures at the highest resolution). It'll be easiest to view the current pictures without an SD card in place.
To view the pictures, press the playback button (above and to the left of the 4-way arrow buttons) on the back of the camera. Use the left/right buttons in that 4-way area to navigate through the pictures. (You'll start at the last photo.) If you want to start the camera in playback mode, just press and hold the playback button while you turn on the camera.
To delete the picture that you are looking at, press the green/trash button to the right of the Menu button. Then press the up/down arrows to reach Delete and click OK (in the center of the 4-way buttons). (See Page 100 (page 102) of the manual.)
If you press the green button twice, you'll get a prompt to Delete all. That is similarly navigated with the up/down arrows and then OK.
Ricoh owns the Pentax Optio Line and has the manuals here: http://www.us.ricoh-imaging.com/support/download-details/356 . (You'll need Adobe Reader to access the program.) The user manual is the second link.
I hope this helps.
Jul 28, 2014 | Pentax Optio Cameras
Pentax Optio M30- How do I transfer pictures from the internal memory onto an SD card??
this model not support it, To do that, you need to connect to pc and transfer it. As long you inserted the SD card, IT will use memory from SD card and not display image, video from built in memory.
if you want to delete file in built in memory, you need to remove memory card.
check this :
PENTAX OPTIO M30
May 09, 2011 | Pentax Optio M30 Digital Camera
The memory card in my pentax optio 60 is full. Can I record over it and if so how The memory card in my pentax optio 60 is full can i recoed over the top of it and if so how David
Certainly. If you're sure you've copied all the pictures you want to your computer, simply format the card to wipe it clean. Rotate the mode dial to the screwdriver-and-wrench position and turn the camera on. Use cursor-down to select "Format" and press the OK button. The instructions are in the "Formatting an SD Memory Card or Internal Memory" section of the manual (page 22 in my copy).
Memory cards should be formatted each time you finish transferring your pictures to your computer. FixYa is full of people asking how to retrieve pictures from cards that haven't been formatted regularly.
Apr 23, 2011 | Cameras
Internal Memory on Camera wont allow format
You usually have to take out the SD card, close the door and then delete images in camera in the normal way (press delete button in play mode, when confirmation dialogue appears, press delete button again, select >delete all< and press OK). Most cameras default to the memory card when one is inserted, that's why you have to take it out to delete data from the internal memory.
Hope that helps
Aug 01, 2010 | Pentax Optio M60 Digital Camera
Green Mode stuck on
remove the batteries and the memory/SD card. replace the batteries first. power up the camera (this will help save your pics from possible deletion). If you can get to the menu of your camera, here is where you'll find the 'green mode'. check the settings. if its on, turn it off. after saving, reload your SD card and try to take another picture.
Aug 24, 2009 | Pentax Optio M10 Digital Camera
Pentax Optio M20 in Green Mode switches off after turning on
Try to press & hold down the Green button (the trash can button on the bottom right corner) & see if it gets u out of green mode.
Jul 27, 2009 | Pentax Optio M20 Digital Camera
My Pentax Optio E40 Camera
The built-in memory only has about 8 pictures or so. You have to buy a memory card to insert in the same section where the batteries are inserted.
Apr 03, 2008 | Pentax Optio E40 Digital Camera
Internal memory card full
You are using built in internal memory (11Mb).
One of these must help:
*Check memory card.
*Check picture saving settings.
*Reset to factory defaults.
User Manual
Feb 13, 2008 | Pentax Optio E30 Digital Camera
Cameras Logo
699 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
halotheracer
halotheracer
Are you a Pentax Camera Expert? Answer questions, earn points and help others
