Question about Refrigerators
I have a Kelvinator CS390 Opal series refrigerator which uses the cyclic system. The cooling panel has been continually getting a thick build up of ice on it, and water drips from the top of the fridge onto everything as it accumulates. I know fridges struggle a bit during the Xmas overload, but this was happening before that and has continued after it. The control dial is set at the higher end of the "colder" section, which we've never had to do before, but it is not cooling too well. What can I do to help it along? Thanks
SOURCE: Ice & water dripping in refrigerator
hi , roger here i am a maintenance tech for an apartment complex that just happens to have whirlpool appliances. the way i see it is the most likely problem you have is a clogged drain. if you push the refrigerator out where you can access the back of it you will see a plastic hose that runs from about the middle of the fridge down to the bottom and then dumps into a pan that sits on the top of the compresser. the easiest thing to do is to remove the hose from the pan and blow hard through it or hook an air nozzle from a compresser and blow through it . it should take care of it. also try to avoid turning the fridge up on its max settings. hope this helps.
Posted on Feb 13, 2008
  • 1314 Answers
ok your defrost drain is frozen take the back panel off in the freezer section under the coils you will see a silver pan if its frozen it will be a block of ice you have to remove the ice then make sure the drain and tube are clear all the way to the pan at the bottom you should see the plastic tube on the back of the unit in the center over time algae can grow in the tube blocking it drying the unit will help but soon as it defrosts the tube fill up again and the problem reoccurs you kinda got to snake it out so to speak.the best way to deal with it is to go to lowes or home depot and get a eurka 302 enviro hand held steamer an investment but a great product to have around the house cost about 40 bucks but 1000s of uses
Posted on Feb 14, 2008
Maytag317
  • 1136 Answers
SOURCE: Fridge ice accumulation inside and water dripping outside
Hi, Are you getting ice build up in the freezer side as well? There is a air shuttle between the fresh food side and the freezer side. thwater might be getting in the freshfood side from there. Look at the bottom rear panel in the freezer for ice build up. Ig=f there is ice, you will need to get to the drain from inside the freezer and check for blockage.
Please let me know if I can help you further.
Vic
Posted on May 10, 2009
Maytag317
  • 1136 Answers
SOURCE: water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
Hi, I can help you. The drain is plugged in the freezer section. Could I get the model #?
Some models need an after market drain heat strip added.
Please let me know and I can get you through tis.
Thanks
Vic
Posted on May 30, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Kenmore elite - Water dripping from freezer to refrigerator
Your refrigerator has a defrost drain blockage behind the evaporator in your your freezer compartment. Some models like yours have leak in the turns as the water leaves the freezer. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution with clorox in the drain will help you clean locate the leak and where the blockage may be downline.. I do have the manual on yours and can help you solve this. Some times this is a factory defect and I can help you solve the freezing drain problem. Let me know, Sea Breeze
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://servicepartstec.blogspot.com/
Posted on Jul 01, 2009
Kelvinator cyclic 410 Upside Down Fridge Freezer. Fridge not getting cold. Freezer is working fine.
Is the fan in freezer compartment working? Is the damper fully open to allow cold freezer air into fridge section?
Sep 23, 2017 | Refrigerators
Kelvinator opal
for this you need an expert to put more liquid into your refrigerator to return to normal
Dec 15, 2013 | Refrigerators
Fidge is warm but freezer ok Kelvinator c 500 c r cyclic
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 07, 2011 | Refrigerators
I have a Kelvinator Opal Fridge/Freezer. The freezer is working fine but the food compartment wont cool. It used to run too cool and freeze stuff on the top shelf. The fridge seals are fine, the fan runs...
The vent from the freezer to the fridge can be blocked with frost and is preventing the flow of cool air to the fridge.
This can happen if there is frost build up due to failure of the auto defrost timer.
So please check on the fan section , remove panel and see if there is frost or block, if so check the timer Heater and the thermostat.
Jan 24, 2011 | Refrigerators
Fridge running continuously
Another defective thermostat.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 10, 2010 | Refrigerators
Where abouts is the thermostat inside the fridge there are white and yellow wires that go to either side of the fridge and the yeallow ones are broken what are these wires for it is a kelvinator C375vm
It sounds like you have a cyclic defrost fridge,Kelvinators were originally fitted with heat assist thermostats,so in order for the fridge to come back on a yellow wire heater was run around the cooling evaporator in the fridge compartment start running again at approx +4C so when the element fused the fridge did not start again until approx +12C.So instead of replacing heater a different thermo was used that came back on at +4c deg regardless.Kind Regards.
Jul 09, 2009 | Refrigerators
Refrigerators Logo
154 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
