Question about Ovens
Hostess trolley trips house electricity when heats up
2 Suggested Answers
SOURCE: cI have a Phillips Hostess
sounds like the eliment has gone hard to get parts i am looking for user manual for this model
Posted on Aug 01, 2011
Electric trips off when oven reaches temperature
this can be caused with anything that heats up ( irons etc ) as they overload the fuse when heating elements are worn or have a bad earth wire which has weakened over time. is it a second hand cooker ? or old house ? its down to power through the wire causing the fuse to trip
Apr 23, 2015 | Ovens
MAIN HOUSE FUSES TRIPPED, RESET, OVEN AND GRILL WILL NOT HEAT UP
It would appear that the tripping of the switch has caused some kind of short within the cooker. I would look for the continuity of the heating element.
Most likely the wires leading to the heating element have burnt and will need replacement. If you are comfortable with attempting a DIY, well and good. You will have to open the back panel to access the said wires. It should be easy enough to identify..it will be the wire leadingto the heating coil.
If , however, you are not familiar with these kind of things, I would recommend getting a repair guy to do it for you.
Cheers and good luck with the repair!
IrishDruid.
May 26, 2008 | Belling XOU252 Electric Single Oven
Grill on my tecnik tkc8525 tripping out my house electric. Any ideas ?
Probably heating element goes to ground when heating up. Suggest changing element.
Nov 10, 2014 | Tecnik TKC8525 Double Oven
Kenmore duel fuel oven wont heat
I take it this will be an electric oven. If so the likely hood is that the oven element has blown and will need replacing. Normally when elements short they will trip the houses RCD (once only normally)
Apr 10, 2014 | Ovens
Electrolux EOB 6632 oven trips main house circuit breaker if used above 180c. Installation electrician has done whole house test, says everything normal, must just be a particularly sensitive ciecuit...
Hi, welcome to FixYa! my name is Shaun. I hope i can help you out with your question. Your main house breaker is tripping over 180C because of the amount of current your oven is drawing. Keep in mind that an oven is capable of pulling up to 1/4 the amount of amperage of your total house current capacity, up to 50 Amps. This is assuming you have a typical 200 Amp main breaker. Add this in with your heating/air-conditioning, up to 30A, if electric, your water heater, 25 A if electric, and whatever lights and appliances you have plugged in and turned on, you can imagine how quickly those amps add up when your oven is on. Your oven breaker won't trip because you're not exceeding 50A on that circuit, however if your total household load is exceeding 200A, your main will trip. Also, breakers lose efficiency over time. Sometimes they can drop current capacity by as much as 25%. So your best bet is to replace your house main and see if that fixes your problem. Hope this helps out. Have a good day!
May 05, 2011 | Electrolux EOB6632 Electric Single Oven
I have a hotpoint ew91 oven that stopped working after tripping house fuse. after resetting fuse fan works but no heat.
It is most likely that the oven heating element has failed which caused the house fuse to trip.
The replace the heating element will mean taking the back off the oven and removing the old heat element by undoing the fixing screws and the electrical connectors( normally this surrounds the fan assembly).
Fitting the new heat element should then be straight forward.
Remember to disconnect the power to the oven before removing the back.
Dec 09, 2010 | Ovens
Oven not heating after tripping electrics
sounds like the element has failed.
Aug 05, 2009 | Ovens
Lights grill and fan work but oven isnt heating up
On our oven, we have to reset the clock before the oven will work. I think it's because of the automatic timer features.
Yours is a slightly different model, but on ours we have to press the two buttons with arrows on, at the same time as turning the clock dial. Once this is done, the oven should work again.
Good luck.
Jan 04, 2009 | Neff U1721 Double circotherm Electric Oven
Ovens Logo
168 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
