Question about HP Color LaserJet 9500HDN Printer
Clean sensor error
I have the "clean sensor error" on a HP Color Laserjet 9500 hdn....I see the answer below....the problem is I have no idea what the density sensor looks like!! Any information? I have searched for the sensor online and cannot find any pictures. Thanks for any help anyone can provide,
my printer displays on the control panel clean sensors and from there it can not print or go to the ready mode.i have cleaned several sensors but still it is displaying that error on the control panel.Please assist.
Best Solution posted on Jan 27, 2008
jaylex
Rank: Guru
Rating: 85%, 268 votes
The sensor it refers to is the density sensor located inside the machine via the right hand door. Open it and clean the large sensor in the middle. If this doesn't work then clean it with a soution and a soft cloth.
  • jc2481 Feb 04, 2009
    I have been having the same issue. I initially was having issues with the magenta and after replacing the drum kit and toner cartrige as well as a cleaning kit...I continually get the clean sensor error...any idea?
SOURCE: clean sensor
Clean the sensor that is located inside this part.
Don't forget clean the LED in the middle and the Sensor in the sides.
Posted on Oct 22, 2008
Joed911
  • 4338 Answers
SOURCE: Connecting the HP Laserjet 9500 hdn
This unit is meant to be used on a Parallel connection or an JetDirect Network adapter, for use over the local network.
If you want to use the Parallel port, you would need a computer which has a Parallel port on it and a Parallel printer cable.
According to the specs, this unit came standard with a HP Jetdirect 620n Fast Ethernet .
You can conect it to your router. This way all the computers can use it via the network.
Here is the user guide:
http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/bpl13223/bpl13223.pdf
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on May 21, 2009
  • 16 Answers
SOURCE: hp colour laserjet 9500 hdn with noise and fuser error 50.6 .
Look at fuser rollers and make sure the new one doesnt have spacing to far in between rollers. Also on front side of fuser there is a big connector that meshes with one inside machine. The fuser connector assy RG5-5925-000CN could be broken as well
Posted on Mar 02, 2010
  • 38 Answers
SOURCE: hp color laser jet 9500 hdn i have this message
Unplug the printer from the pc or the network to clear the error, the upgrade the firmware.
Posted on Jun 16, 2010
seeker5211
  • 1089 Answers
SOURCE: hp 9500 hdn - error message 57.70. Can I relace
No!
The 57.7 error says that the fuser fan could be bad.
If you take the back cover off the printer and look to the right, you will see two fans, one above the other.
The bottom fan is the one you want. It is probably clogged with dirt or else the dirt got inside the fan and is preventing it from spinning. Replace it
Posted on Apr 04, 2011
I had a problem my color laserjet printer 8500dn that is asking to clean density sensor I don't no how to do it please help
Hi Elias, The link below is a user manual for a color laser jet 8500, 8500n, 8500dn, I had a look and the answer to your question (Clean density sensor) is on page 155 (To clean the density sensor
1 Open the upper right door.
2 Use the brush located next to the sensor to remove all toner particles from the sensor)..... This WILL Help...CHEERS..
http://h20566.www2.hp.com/hpsc/doc/public/display?docId=emr_na-c00656644
Mar 30, 2016 | Office Equipment & Supplies
How to fix sensor error on hp color laserjet 2600
54.06
Error message
54.06
Description
Color density sensor error
Action
  1. Power cycle the printer.
  2. Calibrate the printer. Click here to view the document "HP Color LaserJet 2600n - Calibrating the printer" available on the HP Web site at (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00314525).
  3. Change the Print Density settings through the HP Toolbox. Click here to view the document " HP Color LaserJet 2600n Printer - Change Device Print Settings in HP Toolbox" available on the HP Web site at (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00310627).
  4. If the problem continues, contact HP Customer Support Center for technical assistance athttp://www.hp.com/support/clj2600n or see the flyer that came in the printer box for additional contact information.
Apr 02, 2014 | HP Color LaserJet 2600n Printer
Define 54.18 ERROR code on a Hp Laserjet 5500
According to the HP Service manual, there is no 54.18 error.
The listed errors are:
54.1 Temperature error
Check the fuser. See 50.X fuser error.
54.3 Image density sensor error
Check the connections. Replace the color registration detection assembly.
54.5 Colour registration sensor error
54.6 Image density error
54.7(Y), 54.8(M), 54.9(C), or 54.10(K) Drum phase sensor error
Check the connections. Replace the drum phase sensor for the indicated color.
54.11(K), 54.12(C), 54.13(M), or 54.14(Y) Toner sensor error
Check the connections. Check the cartridge and replace it if necessary.
54.19 Transfer Belt error
Check the ETB connection. Replace the ETB. Replace the DC controller.
It is most likely that you have a faulty Toner Cartridge.
Jun 21, 2010 | HP Color LaserJet 5500 Printer
Hp color laser jet 9500 hdn i have this message error 49.4c02
Jun 09, 2010 | HP LaserJet 9500n Printer
Hp colour laserjet 9500 hdn with noise and fuser error 50.6 .
Jan 21, 2009 | HP Color LaserJet 9500HDN Printer
How to clean a density sensor unit on a hp color laserjet 8550
1 Open the right upper door.
Sensor is located on the door lower center of door ther should be a small brush next to it
particles from the sensor.
Jun 06, 2008 | HP Color LaserJet 8550dn Printer
How to clean Density Sensor of Hp 3500 ?
Thank you for this info. I used your advice to fix my HP printer and it worked. By the way, great link to HP support parges on the www.partshere.com site. I was able to fix my printer and by the way purchased more printer parts and fusers. Thank you again!
Feb 27, 2008 | HP Color LaserJet 3500 Printer
Density sensor out of range
CLEAN THE DENSITY SENSORS POINTING AT THE TOP OF THE TRANSFER BELT. A COLD RESET CAN HELP TOO
Jan 20, 2008 | HP Color LaserJet 3500 Printer
HP Color LaserJet 9500HDN Printer Logo
914 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
