Question about Sony Pentium 4, 1.7 GHz (A8058419A) Processor Upgrade
I bought a flip hd mincorder and it needs a least a 2.0 p4 processor. I have a 1.7 p4. Can I swap to a faster processor ? would I notice an improvement ?
  • 88 Answers
You will notice a lot of improvement in the speed and working of the PC when you change it to a faster processor. You can run the mini-corder with your 1.7Ghz P4 processor but you will soon be tired with the slow response of your PC. Changing it to a faster processor is a better option. You will be able to notice a change in the working of your PC with the mini-corder.
Before buying a Processor make sure you old processor can be replaced. Old Motherboards do not allow the replacement of the processor as it would be soldered. If you cannot change the Processor you will have to get a new motherboard with a better processor if you need a better one.
I suggest you buy an Intel Core2Duo or an Intel iCore Processor, not a P4. Leave a comment if you need more guidance. Don't forget to rate the solution.
Posted on Jan 05, 2011
Put in another HD made it a slave but i dont see it as a slave in system files
The master/slave drive model applies to IDE drives (older) these use a 40 or 80 pin ribbon cable. The newer SATA drives (L shaped connectors) don't rely on master/slave config. If you are using IDE you will need to specifically configure the jumper on the main drive as master and the other as slave, alternately you can set them both to cable select. The slave drive will show up under disk management as Disk 1. If you add a second disk this will give you more storage space, in this case 50GB (think of this a long term storage or data that is saved after the computer is shut down) Ram on the other hand is where the computer stores data and applications for faster access, not all of a program has to be loaded in to ram, parts of it can be swapped out from your hard drive as needed. Having more ram means the computer doesn't need to waste time swapping out parts of a program, it can load it all into ram at once.
Feb 03, 2012 | Computers & Internet
Should I upgrade my P4 2.66 Ghz Processor or buy a new computer
I would suggest that you should try to buy a new computer. We do have new Computers that has new processors that are much faster than a P4. :)
Mar 17, 2011 | HP Pentium 4 , 2.66 GHz (DD647AV)...
I have an HP Pavilion a335w computer. It's running a P4 2.5GHz processor (Northwood A80532) 512 L2 with a 100MHz FSB. It has a TriGem Glendale motherboard, PGA478 socket, and it's maxed at 1MB RAM. How...
I have a Compaq that came with this board and a celeron 1.8 or 2.0 I believe. The fastest P4 that will run is a Intel Northwood 2.8 Ghtz 400 FSB nothing ELSE! Northwood 2.8 is the fastest 400 FSB, the boards chipset won't run anything faster than 400 FSB. Mine is running, Win 7 the Northwood P4 2.8 with 2 gigs ram, 160 gig HD and a 256 video card for over 5 years (minus win 7, had XP before with no issues. Good for light gaming, web surfing and MS office! Add a Zotac 512 MB PCI or Sparkle Video card and you can handle most more medium gaiming out today!
Dec 18, 2010 | HP Pavilion a335w (Refurbished...
Cannot install final cut pro.....the software says my macbook pro(macbook3,1) does not have minimum system requirements. my mac.... 2.2 ghz 800mhz core 2 duo 4gb ram 2x2gb @ 667mhz GeForce 5600m gt 128mb...
yes it seems that your laptop dose not meet the minimum requirements to install final cut pro software.you will need to purchase a laptop with the correct requirements,sorry.
ken
Apr 04, 2010 | Apple MacBook Pro Laptop Computer with...
Is the P4 processor removable in order to replace w/a faster P4?
To remove:
There is a lever/clamp that firmly holds the processor in the socket. You must pull the little brown/tan handle out (away from the socket) and up. It goes out perhaps 1/4 inch and up 90 degreee. Once this clamp has been released you should easily be able to lift the processor with your fingers.
Be extremely careful with all the pins on the processor as they bend out of alignment with very little force.
And i guess, you shld be able to replace the processor however you wld also want to confirm it with the customercare to confirm if your motherboard would support that.
Feb 11, 2010 | Sony VAIO Digital Studio PCV-RX650 PC...
I am using intel 845 GVSR mother board with p4 2.4Ghz processor and 256mb of ram.. my problem is whenever am playing any high resolution video or any HD video, the monitor screen became black and after...
If you have only 256 MB of RAM with a P4 system...there is most likely your problem....
I recommend that you increase your ram to at least 1 GB -- 2 GB if you can afford it and your board will support it. You will find that your system will be much faster, more responsive, and will most likely crash a LOT less!
Jan 24, 2010 | Intel Computers & Internet
I have elite mother board P4 M800 PRO M2 socket 775...the problem is always hang and to slow..i reformat 3 times but the problem same plz help me i need assistance..
This are things that need to consider in a computer speed performance:
1. Amount of ram memory(If you have only small amount of memory then your computer performance is poor.)
2. Speed of your processor(You should need at least a 1Ghz processor speed or more).
I suggest you increase your ram memory so that your computer will perform faster.
Dec 16, 2009 | EliteGroup P4M800PRO-M Motherboard
My flip ultrahd apparently needs a faster processor than my imac has. Nice of them to put this in the spec's - oh wait, it's not. Does the non-HD version need a faster processor?
Non-HD video can be edited on mac G4. Mine works from 2003 as well... And with a professional video. So, don't be afraid and edit Your non-HD without trouble.
Sincerely.
Sep 16, 2009 | Pure Digital Flip Video Ultra Camcorder
Swaping hdd 845 motherboard to 915 motherboard
its always safe to have data backed up
u can swap the HDD
but bootup with the Win2K CD in the Drive and after the files are loaded at the first screen select install then after it detects the OS select R (Repair) and this will reinstall the operating system files and then you can use the system as before though u may have to install the device drivers and motherboard drivers
for any other clarifications u can place a comment in the same question or u can mail me at mail2pvs@gmail.com
Jul 30, 2009 | Intel Pentium 4, 3.0 GHz 530...
Won't detect the hard drive
Try the out of case build explained here, it can really help when trying to narrow down a defective part.
http://forum.pcmech.com/showthread.php?t=132409
Aug 30, 2008 | Intel D845HV (735858149143) Motherboard
Sony Pentium 4, 1.7 GHz (A8058419A) Processor Upgrade Logo
73 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
