Question about Car Audio & Video
Had to disconnect my clio battery and not sure how to reset the radio. I have the code but no handbook so how do I reset the radio ? please
  • philipmor777 Jan 03, 2011
    Had same issue and when pressed control for final time just keeps going back to code and locking out we know it is right code as used before any suggestions
  • 4,848 Answers
Using the Steering Wheel remote Control
Turn on the radio and the display will show 'CODE'
Use the Steering Wheel Remote Controls for code entry.
Press the [ ¬] button then rotate the thumb wheel for the correct first digit
Press the [ ¬] button then rotate the thumb wheel for the correct second digit
Press the [ ¬] button then rotate the thumb wheel for the correct third digit
Press the [ ¬] button then rotate the thumb wheel for the correct fourth digit
If the correct code is now shown on screen,
press and hold the [ ¬] button for up to 10 seconds to store the code
Posted on Jan 03, 2011
  • 5 more comments
  • xxxxxx xxx Jan 03, 2011
    1...Either make sure you press the final button ( ¬ ) for at least 10 seconds to store the code
    2...If that also fails, then it is likely you are using the wrong code. If possible post the SECURITY NUMBER and I`ll check it for you. This number is found on a label on the casing and is in the format TOA123 or TA123 or just A123 at the end of a barcode.
    The third possible reason is that your radio is not displaying CODE. Leave it SWITCHED ON..UNDISTURBED until it does
    The radio is displaying the word code, when that goe off it goes to the four Os on the screen. I have then followed your process with the number from the dealer but it just goes back to the word code and locks me out again !!! your help is appreciated on this
    In case we have further faults where do I find the number ? and if it is on the radio casing how do we get the radio out ?
    The SECURITY NUMBER is found on a label on the radio casing so the radio has to be removed.
    See here for removal instructions
    http://www.fitaudio.com/?View=entry
    A pair of extractors are required (available from Ebay etc ) but these can be made from 2 pieces of bent, wire coat-hanger or 4 small drills(using the blunt end) or 4 small Allen Keys or 4 small screwdrivers or 4 nails or even 4 darts.
    An assistant is useful to pull the radio out whilst you are releasing the 4
    securing clips
    http://www.youtube.com/watch?v=urC-4NbXv...
    note: on some radios , these 4 holes are protected by 4 small screws. These
    can be unscrewed using the appropriate size of Allen key.
    That link should be
I need a radio code for a renault clio RN
When you disconnect your battery and then reconnect it again, it disables the radio. This is an anti-theft protection for your car radio.
The enable your radio the activation code is in your vehicle owner's manual. If you do not have this code you need to go to your Renault service centre and get them to enter this code for you.
Feb 05, 2013 | Car Audio & Video
Radio code for reanult clio
Oct 03, 2012 | Renault Clio Cars & Trucks
Renault clio free radio code
Hello , well there is a link http://www.renault-radio-codes.com/renault-clio-radio-code.php , enter your Renault serial and you're cool ;)
Oct 10, 2010 | Car Audio & Video
Srs reset?
This maybe a little tricky. You need to make sure you have the proper radio code so you can reset after you disconnect the batery. Once you have mad esure you have the code and the battery is disconnected, double check all your connections under the seat. This is telling you there is a hard code recognized. If you do not have the radio code, you will need to call the dealer with vin and then write it in the back of the owner's handbook or somewhere else safe.
Mar 15, 2010 | 2008 Mercedes-Benz Mercedes Benz C Class
I have a renault scenic 2000, replaced battery need to input the radio code, noticed on this blog that you can push numbers 2, 5 and on button, I did this and my radio came on without me having to inp
Some radios hold the codes for a few Min's.However ,Disconnect the battery again and leave disconnected for an hour.Then reconnect and Enter codes and confirm.Should work ok.
May 29, 2009 | 2000 Renault 181
How do i put code into a clio cd player????
cd player uses the display above the radio on the later model,either take it to reanult garage or put a belson in like mine whic plays USB/SD card/ CD/radio ,it was about 90€ and trust me it brilliant no more cds in car ,just one sd chip 2 gb all my favourite tunez on one device
Dec 27, 2008 | 2000 Renault 181
Car Audio & Video Logo
115 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
