TOSHIBA LCD TV. THE ON/OFF BUTTON WILL NOT WORK. WE CANNOT SWITCH ON THE TV
    Problem Solver:
  • 10 Answers
This is a common problem, inside the set the mains on/off switch has a small plactic cap on it which breaks easily - the power button externally is slightly off-set to the switch inside so this cap transfers the "push" at a slight angle - a new modified plastic cap with a stronger molding is now available from toshiba
Posted on Jan 06, 2011
  • 17,129 Answers
If this is to do with only the On/Off switch the remove the panel and cross check the switch continuity of the switch. Once this is done the switch can be confirmed or replaced. But I fear the set does not power as the SMPS unit might be damaged. So it will be important to remove the rear panel after the power plug is taken out and check the power supply unit.
Please check this link below for help.
SMPS
Posted on Jan 03, 2011
Toshiba television won't turn on after power flicker
Free Fix For Toshiba 50" TV That Will Not Turn On. - YouTube
? 2:20
https://www.youtube.com/watch?v=8-0nQ57Bvow
Mar 21, 2012 - Uploaded by rstarre ten g
My flat screen tv cuts off and on while the power but is on what should i try before i buy a new one .... I have a ...
Toshiba TV power outage - AllExperts
en.allexperts.com > ... > TV/VCR/Stereo Troubleshooting
Feb 3, 2011 - TV/VCR/Stereo Troubleshooting/Toshiba TV power outage - no power... we had a power outage (they're calling rolling blackouts due to power grid ... but I admit I'm now afraid to turn it off for fear it won't come back on again.
Toshiba 32c120u LCD TV won't turn on - Tom's Guide
www.tomsguide.com/answers/id.../toshiba-32c120u-lcd-turn.html
May 27, 2015 - My toshiba tv is flashing but won't turn on with remote or power botton on tv itself ... dang this worked for me but after a minute it stoped working.
Dec 28, 2015 | Toshiba 58L7350U 58" 3D 1080p LED-LCD TV -...
My toshiba tv is stuck on initial setup menu, language selection. original remote is not working
Hi,, today i got the solution for the problem 'Tv Stuck On Language Screen"
I have Skyworth Lcd and it was stuck on Language screen 4 days back, i've tried every sigle App and Different Universal Remotes and buttons on Tv but nothing was working except a single App named "SURE UNIVERSAL REMOTE FOR TV"
i suggest if someone face this Language screen stucking problem and no buttons and remotes are working then you should download this App on your Cell phone and select your tv and you'll surely be able to restore your Tv.
Feb 10, 2013 | Toshiba 40RV525U 40 in. LCD TV
Toshiba 32AV502R won't turn on even though green light goes on
Try changing the input device to something you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 30, 2012 | Toshiba 32AV502R LCD TV
My toshiba regza 32av615 lcd tv keeps flicking thought the channels on its own
If the set is going up only or down only it is likely the button for each or one on the set itself is bad.
Channel up or any for example is a micro switch-beneath each actual button. They are "momentary" switches which means only work when pressed---a lot of them fail in this way.
A way to know for sure is have someone remove the keyboard(usually on a small circuit board inside) and locate the offending button--up or down and unsolder that switch---usually two or three pins.
The switches can be tested with a ohm meter set very high--should be no reading unless switch is pressed---
If set works now with the switch eliminated either just use the remote or purchase a replacement board--they usually do not sell individual switches
Let me know what happens or if you have a further question.
Apr 12, 2012 | Toshiba REGZA 32AV615 32 in. LCD TV
Toshiba tv keeps on changing inputs at irreguar times on its own and the every button on the remote changes the input. have tried removing batteries from remote but problem continues
There is a known problem with Toshiba Tvs that options change with out any input of buttons or remote. the tv switch panel needs replacement. This is situated behind where the buttons are on your tv usually bottom right. there is a work round if you dont want the expense of part replacement. you can disconnect these buttons and only use the remote. This requires taking off the back (ensure tv is disconnected from power as there is high voltage in the tv) once the back is removed and tv is laying on its front you will see bottom left where the buttons now are, a couple of cables one will have seveal wires and one will only have a couple of wires take the smaller one off this will disconnect the buttons and stop the problem. once this is done you can only use the remote control to control the tv settings but the power on off button still works.
I hope this was useful.
Apr 05, 2011 | Toshiba REGZA 32AV615 32 in. LCD TV
Connecting Compaq Presario CQ40 to LCD tv Toshiba REGZA '32'
Check your resolution output from laptop it maybe set to high for the TV to handle, also go to the Display Properties and ensure that the second monitor out is enable. Good luck!!
May 28, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Cannot find code to program sky remote control
please follow the steps below:
TV
RED + SELECT (flashes twice)
TV
0156
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
Mar 12, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Televison & Video Logo
290 people viewed this question
Top Televison & Video Experts
Electro Med Services...
