I want to install Turbo c++ in windows 7 64 bit
Do you have dosbox on windows 7? If yes, then u can download turbo c++ and run it through dosbox.. let me know if you need the exact steps..
Posted on Jan 03, 2011
I have sony vaio laptop window 7,64 bit with 500 gb harddrive having only one partition = c i want to make 4 partitions how can i make it without losing my recovery data default from manufacturer
Type Computer Management into the search box above the start icon. Select Disc Management, select the drive name you wish to adjust and right click on it. Select Shrink Size and select whatever size you require. When complete format the new partition.
Dec 24, 2014 | Sony VAIO Computers & Internet
Logithec attack3 devices not detected
Disconnect the divice uninstall the driver restart the laptop and then reinstall the driver again restart the laptop then connect the device it works.
Apr 03, 2014 | Video Game Consoles & Games
How to Run Turbo Pascal Full Screen mode on Windows 7
Now that's a program I've not worked with in a while ;-) I haven't used it since my early high school days in the 1990s. Turbo is a really old application that has been around for ages- unfortunately, being as such, it is only capable of developing 16-bit DOS applications, which has, for better or worse, gone the way of the dinosaur. In the x64-bit versions of Windows Vista and 7, all 16-bit native support has actually gone out the window in favor of 32-bit and 64-bit application development. This is why DosBox was invented- it is a true 16-bit DOS environment (much like command.com and CMD.exe used to be) that is capable of running all the older DOS programs that are no longer compatible with Windows.
When you run Turbo from the DOSbox program, press ALT-ENTER and it will fullscreen whatever you're working with.
Hope this helps,
- Vern
Mar 24, 2012 | Computers & Internet
I am using windows 7 ultimate 64 bit OS. i am having turbo c++ 32 bit software.how can i install it in my laptop...
The Turbo C++ you are trying to install is just incompatible for your OS. Because your OS is of 64-bit and you are trying to install 32-bit one. Try to find a 64-bit Turbo C++ program.
You can try downloading this one for 64 bit compatibility:
Turbo C++ for 64bit
Dec 19, 2010 | Computers & Internet
How can i install turbo c in windows 7 x64
How to install Turbo C++ on Windows 7 We are providing detailed procedure how to install Turbo C++ on Windows 7. The very same procedure can be used on Win Vista. If you are running 64 bit version of Win 7, read this article. Users having Win 7 Pro and Win 7 Ultimate should use the virtual Windows XP Mode to install Turbo C++.
Installing Turbo C++ on Windows 7
1. Extract the zip files to: e.g. C:\TurboC
step1.jpg Extract zip files
2. Run the install: C:\TurboC\INSTALL.EXE
step2.jpg Run the install
3. Press Enter to continue
step3.jpg Press Enter to continue
4. Enter the Source drive: e.g.C and press Enter to continue
step4.jpg Enter the Source drive
5. Enter the Source path: \TURBOC and press Enter to continue
step5.jpg Enter the Source path
6. In directories specify where Turbo C files are copied. E.g. C:\TC . When done go to start instalation and press Enter
step6.jpg Specify where Turbo C++ files are copied
7. Succesfull instalation
step7.jpg Succesfull instalation
8. First launch from your destination e.g. C:\TC\BIN\TC.EXE
step8.jpg First launch from your destination
Jun 23, 2010 | Computers & Internet
HOW TO RUN TURBO C IN 64 BIT WINDOWS 7
Turbo C/C++
64 Bit operating systems like Windows Xp64, Windows Vista64, and Window 7 will no longer run 16 bit applications and this includes Turbo C 2.01/Turbo C++ 3.0/3.1 or the programs they produce.
Turbo C 2.0 was first released in 1989, Turbo C++ 3.1 in 1991 making these programs nearly two decades old. They are just too old to run on modern PCs.
Upgrade To Modern Compiler
Note that Turbo C/C++ is very very very very old and produces 16 bit programs which no long run on many modern computers. So the best advice is to upgrade to a new compiler. There are many free compilers out there that you can use.
Free Compilers:
  • Microsoft Express 2008 -- Great compiler and comes with a nice IDE (Visual Studio)
  • MinGW -- Command line compiler but there are many IDEs that use it such as Code::Blocks, Eclipse, Dev-C++
  • Borland C++ 5.5 -- Will compile Turbo C++ programs (including graphics.h) but produces 32bit code (slightly better than Turbo C) Only includes command line tools.
  • DigitalMars -- Its still old but at least it produces 32bit programs (better than Turbo C). You might stumble across D++ which is a very powerful language derivative of C++.
  • OpenWacom -- Again, nearly as old as Turbo C, but it produces more modern 32bit applications! (this project is still active too).
If you are just working with C there is:
  • Pelles -- and excellent modern C compiler and IDE. Pelles also has the new TR1 libraries available so you can use regex and other new features. As well as support for many older libraries.
  • LCC-Win32 -- Used as the basis for many of the research compilers.
  • Tiny C -- is said to produce very fast programs.
All of the above are Free and all excellent replacements for Turbo C which is so old it will not even run on your computer.
Regards.
May 24, 2010 | Microsoft Windows Vista Ultimate Edition
I m using vista home premium 64 bit opreting system & i am unable to run some of the softwares that run on 32 bit OS like TURBO c/c++ compiler. every time i try to run it it shows the message "the...
There are compatability issues with many of the 32 bit software titles. The 64 bit version of Vista is not backwards compatable with all titles of 32 bit Vista. You will have to down load the patch or 64 bit version of the titles you are having trouble with. You can try to run it in compatability mode but things like Turbo C/C++ will not function in that mode correctly. They won't debug right.
Oct 12, 2009 | Microsoft Windows Vista Ultimate Edition
How to run turbo c++in vista 64 bit os
You can run Turbo C++ 3.0 on Windows XP 64 bit , Vista 32 bit and 64 bit OS (in full screen)
Install the software DOSBox ver 0.72 (Freeware) from the link below (Direct Link)
http://prdownloads.so urcef orge.net/dosbox/DOSBox0.72-win 32-in staller.exe?download
Before going to the details u have to create a folder (any name will do).
Here we name it as Turbo
Copy the TC into the Turbo folder
Run the DOSBox 0.72 from the icon located on the desktop or from the location of the installation folder
Then u are presented with two screens which look like the command prompt in Windows
Now u are presented with two screens. One with a Z prompt. U can ignore the other screen.
There type the following commands at the command prompt [Z]:
Mount [Type in any alphabet that u wish except z] [Type the source of the turbo C] press enter
For example (Type in the following commands after the Z prompt):
Z: mount d c:\Turbo\ [The folder TC is present inside the folder Turbo]
* Now u should get a message which says: Drive D is mounted as a local directory c:\Turbo\ ***
C:\> cd TC [The contents inside the folder Turbo gets mounted as a virtual drive (Here D drive)
source site :
http://mycomputer.freefor ums.o rg/running-turbo-c-in-full-scr een-m ode-help-t1241.html .
Sep 03, 2009 | Microsoft Windows Vista Ultimate Edition
Plz tell me how i can run c++ in full screen in vista ultimate
Hello
Use the command prompt. Maximize the window size. Change directory to c:. You will have a line that fits 75 characters and a window that occupies about 2/3 of the whole window. That's enough fore all reasonable problems. If you are not happy with what you get, you may try developping your C++ program under Linux.
Hope it helps
Aug 29, 2009 | Compaq Presario 700 470024-192 Notebook
Computers & Internet Logo
70 people viewed this question
David Payne
David Payne
