Question about Samsung SGH-X700 Cellular Phone
Not able to access pc with the help of usb cable
I got my system formatted recently and now im not able to access with the help of data cable....its showing the message that there is no required software to support the operation
  • anubhagulati Jul 09, 2008
    my comp says new hardware device and doesnt let me work on it
Can give me format code manual
Posted on Apr 21, 2009
Recently my external hard disk freezed. i connected to one of my friends laptops and once it was visible and accessible. next time, it was not accessible visible though. I thought it is the problem of his...
i would check the image you have saved before formatting your external drive just to make sure you will have it after a format you will lose all data
if you can see your external hard drive
right click on your external drive select properties tools check now you should check now with two boxes you could tick both boxes automatically fix files and attempt repair bad sectors on your drive
have no input while chkdsk utility is in progress any may damage this external drive
also
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope some of this helps you
Sep 23, 2011 | Seagate 500GB FreeAgent GoFlex Pro
I have transcend JF V30/4GB pen drive. Recently i am getting in the pen drive that i cannot do any format in the pen drive nor i cannot copy/delete the files in the pen drive. it was showing that...
Hello and Welcome to FixYa!
Kindly try this solution:
  • Connect the USB stick to another computer and copy all the data.
  • Download this file (click here) to that PC and format the USB stick using this program.
  • Now try to connect the USB stick to your ACER laptop and see if it works.
If you have any further queries, please do not hesitate to comment again. If this solution was helpful to you, kindly rate it.
Regards, Waqar.
May 22, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I am using Transcend 320 GB external hard disk in a Windows 7 Operating system. It is keep on asking me to format the disk while i plugging in to laptop. Unable to see the contents in the external hard...
guess you are using a USB port to for that.....
1 - check the cable that connects the HD to the USB port...change the cable and verify
2 - connect to another PC and check if it's ok there
3 - bring another ext HD from a friend and try conencting that....check if that's OK
4 - there could be a corruption in the HD that is preventing the PC from reading it
cardinal rule for USB....not a very dependent device specialy if connecting thru USB data cables....
solution
always use a good qty USB data cable compatible with USB2....as some cheap cables are only for USB1
visit my website
www.sureshayyar.110mb.com
for more info on PC issue and solutions...
reg
Kris
Feb 17, 2011 | Transcend StoreJet 25 Mobile 500GB USB 20...
I have recently purchased a Hyundai i20 with AVN system. The USB port does not read music or videos. It appears that the USB port and AVN system are not compatible. Has anyone else encountered a system...
Hi Pradeep,
To be able to read data (music, video, etc) off the USB you need to format it accordingly:
0. The USB should have data on the boot drive itself 1. The USB needs to be formatted correctly (FAT32 with allocation units of 512KB).
Try this - should work.
Avi (Another i20 AVN User)
Jan 03, 2011 | GPS
Hi Sir, I have a problem with my SD Card when im going to read it on my pc. It ask for "format the disk before you use it". When I click cancel, it says"your volume not contain...
Does the SD card have pictures on it? What is the camera model used with this card? Have you tried connecting the camera itself to the PC in order to transfer the card's contents?
Dec 17, 2010 | Computers & Internet
My usb stick needs to be formatted for pc but i cant
you can try format recovery software like asoftech data recovery. You can see
Recover formatted files
It tells the steps how to perform format recovery.
If above does not work, you may have to format the usb drive (use quick format), and then use above mentioned software to scan again the usb drive and recover your files.
Apr 04, 2010 | Computers & Internet
Formatting the pendrive
Plug it into another usb socket and you should find it works, Sometimes usb sockets and drives can become corrup.. by right when you reboot you machine it will revert back to normal
Nov 17, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
My Freeagent external hard drive doesn't show up on My Computer
Your Mac would have formatted the Seagate drive as HFS+ (journaled) format. If you have access to a Mac, copy your data off the Seagate to any Mac, then use your PC to reformat the Seagate drive in FAT32 format. Macs recognize FAT32 format, and can store data in it, but can't create the format. The Mac holding your data can store it on the Seagate in the FAT32 format, and you can then copy the files to your PC. Hope this helps.
Feb 25, 2009 | Seagate Free Agent Go Small 12 GB USB...
Hey i have prob in iso games
STEP 1: CONNECT YOUR PSP TO PC
The PSP can function as a USB Memory Stick Duo reader. Using this functionality, you can copy pictures, audio, and other content to and from your Memory Stick Duo. To access the Memory Stick Duo in your PSP from your PC, you'll need a USB cable that has a "Mini-B" connector (common for digital cameras) and a "Standard-A" connector (common for printers, etc). Plug the Mini-B side into the top of your PSP and the Standard-A side into your PC. From the PSP software, navigate to the top of the settings list and select "USB Connection." Your PC (Windows/Mac/Linux) should detect a new "Removable Disk Drive" that you can then access.
STEP 2: FORMAT YOUR MEMORY STICK
In order to be able to use your new memory stick on your PSP, you'll have to format it. When you format your memory stick, the formatting will create a set of new folders on your PSP: GAME, MUSIC, PHOTO, and SAVEDATA.
STEP 3: EXTRACT THE SAVED GAME
This process will greatly depend on which software you use to extract zip files. WinRAR for instance offers the "extract here" option, which will simply extract the contents of a zip file to it's current directory.
STEP 4: TRANSFER SAVE GAME TO "SAVEDATA" FOLDER
Just copy the folder you have just extracted, and paste it into the PSP's "SAVEDATA" folder. But, BEWARE!, to any folder overwrite warnings! Because the PSP save game folders use the same names for the same games, copying folders into these locations could lead to lost data. For this reason, we recommend that you backup your old save games before overwriting them. For Example, I would simply rename a folder like "ULPS0004" to "ULPS0004_backup."
STEP 5: EXIT USB MODE
Because your PSP has been in USB Mode throughout this process, just push X to exit. Then you can safely disconnect your PSP from your PC.
STEP 6: VERIFY TRANSFER OF SAVE DATA
To verify the integrity of the SAVE GAME data you have just transferred, use the PSP's built-in Save Data Utility. Select it from the "Game" menu.
That's it, simple and smooth.
Oct 16, 2008 | Sony PlayStation Portable (PSP) Console
My usb flashdisk become raw data
1). Do not format this hard drive before you've recovered all your stored data back. In your case, the formatting process may erase everything on your drive and make your data gone permanently.
2). Never save anything new on this drive in case that any new file would rewrite your original data.
3). Plunge this drive to your computer and download a RAW drive data recovery freeware to get back all your lost data back:
http://www.freeware-fix.blogspot.com/2013/02/raw-hard-drive-recovery.html
This hard drive has helped many people around me restore their inaccessible data back from a RAW drive or memory card. It can also work perfectly on your drive.
Read more detailed information of this freeware here:
http://blog4mark.blogspot.com/2012/10/help-external-drive-became-raw.html
4). Save and back up all your restored data on another drive in case of data recovery failure.
5). Format this drive to see whether it is fixable.
Dec 16, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Samsung SGH-X700 Cellular Phone Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
