Question about Proform Drive Motor Choke Treadmill
Motor choke run very hot start smkeing after twenty minutes?
Carrier apu blows cold air for twenty seconds and fan quits engine keeps running and fan starts again but only blows cold air for another twenty seconds
Have you tried rebooting the system? Just turn off the breaker for a few minutes.If you need more questions for your Air Conditioning Repair needs, check us out online.
Jul 07, 2017 | Carrier Heating & Cooling
Why is it hard to start my Mercruiser 7.4L MPI after a hot run?
Electric choke? Try retrofitting a manual choke. I think the electric choke is closing over a hot engine, thinking that the engine's cooler than it really is. A manual choke will allow you to start it with no choke at all when you know the motor's already warmed up.
Jul 25, 2014 | Mercury Marine Mercruiser 350 - 454 - 5.7...
1993 Eagle Vision.. Car runs great... for 15 min. Then falls on its face..try to start..barley runs...rapidly pump gas pedal car will run barley. shakes and chokes and sputers... shut the car down for...
Could be fuel pump is going out. Its getting hot not working properly and when it cools down it works right again for a short period. Ive seen this happen several times.
Oct 05, 2013 | Eagle Vision Cars & Trucks
Missing cut out
if you have a automatic choke get it checked and make sure its working properlly, it might be staying on wich means the bik will not start or run when it warm
Aug 07, 2013 | Honda VT 500 C Shadow Motorcycles
Mower will run then starts running bad turn the choke off and it stalls stalls after i choke it also blows gas out of the top of the carburator how do i adjust the vaalvesType your problem for a solut
Using the choke as you did,mentioned in your problem,you have flooded the carburetor. DO NOT USE THE CHOKE,ONCE THE TRACTOR IS RUNNING. Choke is used to start the motor only. When you run with the choke on,the motor gets to much gas and the plug(s) get fowled up and gas comes out of the carburetor. Remember the motor is hot,when gas comes out of the carburetor,the amount of over flow (flooding),could cause a FIRE. Lay off the choke,clean the spark plug(s),they will most likely be fowled up. The filter will be soaked with gas,remove the filter,soak up the gas,using a handy wipe,let filter dry out. Once dry replace filter. You should be good to go. Remember,do not over choke,use when starting a cold motor,usually when motor is hot from running,you may not have to use the choke at all. Hope this helps. Sincerely,Brad Locke
Apr 22, 2013 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Briggs straton 6.75 starts to die..if i open the fuel cap it runs again. also wont start when hot. twenty minutes or so it's fine again.
hello,After it stalls take the fuel cap off and put it back on and see if it starts,maybe the cap is bad or clogged and not letting air in to equalize the pressure of the fuel being used in other wards a clogged vent, this is a small thing but a big problem,,hope this helps, ``
Feb 20, 2012 | Troy Garden
1988 Cutlass Calais. Motor runs fine on start up.
Sounds like the veh is loading up on fuel make sure coolant sensor to computer is reading right it could be choking the car.Also check for clean throttle body But what the most likely cause is the mass air flow sensor. Blow it out now do this gently there is a wire in there thats what you want clean. dont spray any liquids on it THANK TIM
Feb 17, 2010 | 1988 Oldsmobile Calais
Oven will only run for a minute twenty six, then it shuts down, and comes back up twenty minutes later
your thermal cutout on the side of the magnetron is defective,sounds like the mag is getting very hot,and taking a long time to cool so thermal can reset
Sep 07, 2009 | Microwave Ovens
MOWER RUNS FIVE MINUTES THEN STOP AFTER IT WARMS UP
Check your automatic choke ... a cold mower needs more choke, and the auto-choke should release when the motor warms and runs smoothly. If the choke is sticking, the motor will die when it gets warmed up, then start again after it cools down.
Apr 12, 2009 | Mtd 22" Yard Machine Push Mower
1999 plymouth breeze rom's running high
does it idle high also? i've had that problem, when i start the car (same as yours) it idles at 4.5rpms and after twenty minutes of driving for some reason goes to normal, i was told its a rpm sensor problem. good luck.
Jun 03, 2008 | 1999 Plymouth Breeze
Proform Drive Motor Choke Treadmill Logo
99 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
