Question about Dewalt DC618KA Angled Nailer Kit
I have 2 dewalt 16g angle nailers and both are doing the same thing,they misfire or the leave the head of the nail out about 15 mm. They will only sink the odd nail why? It seems to be doing it on 50mm brads but the same is happening with 35mmbut not as ofte. It sounds like it hasnt got the power or something,both guns are only 2 yrs old
    Sergeant:
    Champion:
  • 342 Answers
Is the pressure regulator on the compressor open to about 100 psi or 80 psi try that and see if that helps
Posted on Jan 03, 2011
My dc616 dewalt nailer is not firing and constant flash not battery no jambed nails what else could it be
look at the end where the nail comes out . it should be flush across , if the plunger is sticking out then push it back in with a flat screw driver and try again.soft wood quite often lets the nail shoot to far
Aug 13, 2015 | Dewalt DC616 16g Cordless 18v Straight...
Why is my DeWalt D51275 15 gauge angled finish nailer bending nails and jamming?
A few things to check - some may seem overly obvious but humor me:
1) Check your nails - make sure they are the correct angle and gauge
2) Check to make sure there is not a piece of a broken nail in the nose
3) Check the driver blade & insure it is not bent or chipped
4) Make sure the nail carrier spring is pushing nails forward and isn't getting hung up
Jun 08, 2014 | Dewalt DC628K Factory Reconditioned Heavy...
Gun fires mor than one nail at a time porter cable model da 250a 15 ga. finish nailer
There are two issues that people have with nailers that sound the same however are totally different. Firing more that one nail at a time can be taken as; two nails being driven with one fire or the nailer vary rapidly firing a second time almost instantly after firing the first nail and each time only drive one nail. Problem of double fire (either type) is very common with nailers (the gun very quickly fires twice), however two nails at once can only happen if the wrong gauge nails are used in the gun. A 15 g nailer can very easily pass two 18 g nails or, with more difficulty, pass two 16g nails. To help prevent the driver blade from hitting two nail heads at once, most drivers are slightly tapered at the tip so that the driver will hit the first nail and the tapered part will push the other nails back into the rails slightly. Remove the head of the nailer and pull out the driver. Measure or compare the thickness of the driver to the thickness of the nail head. If you are sure that you are using 15 gauge nails, check the driver for taper. The tapered part should face the rails. If not tapered, try carefully grinding a taper keeping the tip cool so that you do not effect the hardness. You could also check for other brands of 15 g nails with slightly more spacing between the nails. There is a big difference in quality among brands of nails. Good luck with your repair
Jun 01, 2011 | Porter Cable FactoryReconditioned DA250BR...
Shooting two nails at once
Problem of double fire is very common with nailers (the gun very quickly fires twice), however two nails at once can only happen if the wrong gauge nails are used in the gun. A 15 g nailer can very easily pass two 18 g nails or, with more difficulty, pass two 16g nails. To help prevent the driver blade from hitting two nail heads at once, most drivers are slightly tapered at the tip so that the driver will hit the first nail and the tapered part will push the other nails back into the rails slightly. Remove the head of the nailer and pull out the driver. Measure or compare the thickness of the driver to the thickness of the nails. If you are using 15 gauge nails, check the driver for taper. The tapered part should face the rails. If not tapered, try carefully grinding a taper keeping the tip cool so that you do not loose the hardness. You could also check for other brands of 15 g nails. There is a big difference in quality among brands of nails. Good luck with your repair.
May 31, 2011 | Porter Cable FactoryReconditioned DA250BR...
Nails keep jamming in the gun. how do you fix that and not sure about the correct air pressure.
Not all nails are exactly to gauge, but if they measure about right (take one nail off strip and see if it fits snuggly into bottom of nose) most likely the problem is the driver; missing tip or bent. Remove head and pull out driver. If just the tip is broken you can grind it square again and if bent you could try to adjust. If not driver is available at dewalt service center and at www.toolpartsdirect.com Good luck
Oct 09, 2010 | Dewalt 1 - 1/4 - 2 - 1/2" 15 - GAUGE 34...
Dewalt nailgun wont punch nails
dewalt nailgun jamming "constantly"
Oct 13, 2009 | Dewalt DC618KA Angled Nailer Kit
DeWalt d51822 framing nailer, shoots 2 nails at once 1 in 5 times
I worked at at tool rental center while attending college and learned from the old tool masters about nails and nailers. Rental stores have many different brands of nailers to rent and customers would bring their own nails of all brands. You will notice on the case/box that your nails will /should work on many other brands however the degree or angle of the nails is not always exacly as stated on the box. You should check with protractor the exact angle of your nails and also check the exact angle of the nailer. Use straight edge on travel path of the piston and another on guide rails to check angle of the gun. You will discover that all is not as stated as in a perfect world. If the angle is off slightly, the head of the second nail will get into the path of the driver. This happens mostly with clip head because the nail heads are so close together. The full round head is spaced further apart with less jamming. If angle is off slightly, take a look at other brands of nails with protractor in hand, the angle will be different slightly or choose a slightly thicker nail. Look for the nails to fit with bottom of nail hitting the barrel first. This will move the head of the nail slightly away from the center line. Finally do not release pusher with force as this will jamb nails closer together. Good Luck!?
Jun 03, 2009 | Dewalt Heavy - Duty 31° Clipped Head...
Need nails
Do a search on Google or Yahoo to find sellors and prices.
Mar 23, 2009 | Dewalt 1 - 1/4 - 2 - 1/2" 15 - GAUGE 34...
D51844 Won't Fire Nails
The Dewalt D51844 uses a full round head 20 degree nail. Sometimes the generic brand nails are not made exactly to the stated degree. They do this so their nails will work on a variety of nailers. Best to check the nails angle in relation to the angle of your nailer. Place a strip of nails on the outside of the rail. Align the heads of the nails to a convenient straight edge on the rail then check that the head and shaft of the first nail is aligned with the barrel. If the lower part of the nail projects out further than the head, then the driver will miss the head. If the head of the first nail appears close enough to barrell for the driver to hit it then place a new strip of nails into the mag and slide the pusher foward. Fire one nail, if success, remove the nails from the mag and check if the plastic holding the nails together is projecting in front of the first nail. Sometimes the plastic is not right, too stiff, and will not let the next nail align with the barrell. If the next nail appears ready and slides forward then the driver may not be going all the way up after shot. Check by inserting a metal rod into barrell and push driver up till it stops. If the driver is in the uppermost position, then most likely brand of nails. Use Dewalt nail. Good Luck
Jan 25, 2009 | Dewalt D51844 Framing Nailer
Dewalt DC618KA Angled Nailer Kit Logo
283 people viewed this question
Top Dewalt Tools & Hardware - Others Experts
John Trevino
john h
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
