Question about Polk Audio PSW250 Subwoofer
Polk audion psw250 subwoofer has humming noise
  • 2,098 Answers
Humming noise on your sound is not due to your speaker but it is come from the amplifier. I've encountered a lot of this problem that is caused by the electrolytic capacitor. If you are a technician first locate for a dry joints on the board and then resolder it using your soldering iron and a high quality soldering lead. Resolder not only the capacitor but also around the output I.C.
If nothing happen then it is coming from your output I.C. sometimes it was leaky/shorted which produces a humming noise but first do the the above mentioned instructions before isolating the defective output i.c.
Posted on Jan 03, 2011
  • IF Unlisted
    IF Unlisted Nov 04, 2015
    Hey JD. Any idea which capacitor might be causing the problem here? Also not quite sure how to find the output I.C. on the board. Thanks!!
Loud humming sound from subwoofer PSW111 (specially(noticeable once AV receiver is off).
Check the connections from your reciever to your subwoofer. It sounds like they may be a little loose.
May 15, 2011 | Polk Audio PSW111 Speaker
When my sub is off it hums how can i fix this
Teach it the words ;-)
"OFF"? Turned off, no power?
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Polk-Audio-RM6750-Speaker-Systems-manual/id/2771dj580/t/2/
Disconnect the input(s) and see if it hums in the absence of an audio source. A bad audio cable shield or unwisely-routed audio cables will allow entrance of unwanted signals from external power sources, magnetic fields, even dimmer-controlled track lights. Sometimes, simply reversing the orientation of the ac power plug can eliminate humming.
Feb 27, 2011 | Polk Audio RM6750 System
My receiver dies every time I attempt to plug in the stereo wire into the receiver (the other end is already in the subwoffer)? Is there something wrong with my receiver or am I not hooking it up...
your sub woofer is partly shorted check the output transistor of your sub woofer before pluging to the receiver or this will damage your receiver
Dec 24, 2010 | Polk Audio PSW250 Subwoofer
My Polk PSW 303 subwoofer emits a hum when plugged in and powered off. When the unit is turned on the hum gets louder. At this point the unit is useless. Does anyone know what could be causing this?
Hiya sounds alot like there is a power supply issue with the unit that will require repair for it to be doing off or on. Probably wont be to expensive, request a quote first to make sure viable.
Best of luck
Jul 16, 2009 | Polk Audio PSW-303 Subwoofer
Polk Audio PSW202
The power supply or amplifier has a shorted component.
Nov 08, 2008 | Polk Audio PSW250 Subwoofer
Loud hum on subwoofer.
try another speaker on that channel if you get no sound or it hums then it is time to take your set to a tech your audio out put on that side is damage along with some caps.good luck.
Mar 30, 2007 | Polk Audio RT1000I Speaker
Polk Audio PSW250 Subwoofer Logo
947 people viewed this question
Top Polk Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
kdigby
kdigby
Level 1 Expert
Are you a Polk Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
