Simpson ezi loader 5.5kg when you turn it on to wash a load the door lock keeps clicking so that i am unable to use it at all.
  • Washing Mach... Master
  • 19,396 Answers
Hi.
The door lock motor is stuck engaged.
Either there is a contact in wiring to door lock, or the door lock motor is damaged. Before replacing the door motor trip the circuit breaker or disconnect power cord. When power is off, remove water from bottom of the tub (disconnect filter from pump, access door is below front door at left hand side. With power off try also playing with the door lock.
Close door and connect back power.
If the washer still does not work, then the door lock mechanism must be replaced.
Posted on Jan 03, 2011
I have a Simpson Ezy Loader. I need to replace the door hinge which I have purchased but I am unable to get the broken door hinge out of the door as the door wont come apart.
may i ask why are you replacing the hinge? the door is in two halves and held together by a few large screws, once you remove the screws you will need to put a flat blade screw driver in between the two halves of the door and pry it open, theres a heap of tiny clips that hold the two pieces together, it will be quite hard and may make a loud crack when you pop it open, dont worry you wont break anything.
Feb 04, 2017 | Simpson Washing Machines
I have 5.5 kg front loader simpson EZI sensor washing machine,the handle to open the washine machine has gone loose and now can not open my full load of washing from the machine
you need to take the top off turn off the mains supply
and reach down to the door catch behind and manualy open it
if the handle has cracked a the pivot pehaps a flat blate screwdrive and you can carefully release it
youll find a littl preasure to the door will help you then let go and the door will open easier
Mar 02, 2015 | Simpson Washing Machines
Simpson Ezi Sensor Front Loader keeps pausing during washes, doesn't put through the detergent.
you might be putting the detergent in the wrong part of the dispenser,or you might have the hose on the wrong way,or the water valve has failed. Read up on your user manual to see what happens on this part of the cycle,does the w/m empty ,then try and bring in more water?? The main give away to this fault is,detergent still in the dispenser.Check all your filters on your inlet hose and water valves.
You have to ask yourself what has changed,cheers.
Aug 14, 2012 | Simpson Washing Machines
My simpson ezi sensor wont agitate
hi just read your posting.Does the machine spin and drain?Please reply with answer and I can help you further.
Jul 14, 2012 | Simpson Washing Machines
Simpson ezi loader 5.5kg front loader. when it goes to start the door clicks 3 times then the end light flashes. I am an electrician. but I do not work on appliances. if you could send me a...
the door is clicking because it is trying to lock the door but is unable to for some reason what is the make/ model number of the machine? most likely it would be something dealing with the door look but id rather be 100 percent correct then assuming Please send model number i await your reply Thanks again
Rick
Dec 09, 2010 | Washing Machines
I have a Simpson EZI Loader 5.5kg, where is the lint filter
HI just read your posting.Now the SIMPSON EZI LOADER comes in front and top loader versions.Which type is yours?Are you getting a lot of lint on your clothes?Please reply with additional information and I am sure I can help you.Looking forward to your reply.
Oct 03, 2010 | Washing Machines
Simpson ezi loader washing machine clicks 3 times then the end button lights up without even starting the cycle. does anyone have a solution for this?Solve this problem 1 2 3 4 5 6 7 This is a... Solution...
It sounds like a door switch fault see if the end light and the start/pause light are flashing count the flashes if end flashes 4 times and the start/pause once or maybe more this could be error 41, door switch fault.A door switch would cost about $ 20 but there may still be a problem with the main Programmer.
Good luck.
Apr 27, 2010 | Zanussi FS1455W Front Load Washer
Simpson front loader washing machine repair person
I have Simpson EZI sensor 9.5kg and during the washing i have a EF message coming up.
Dec 21, 2009 | Washing Machines
Washing Machines Logo
152 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
