Question about Cell Phones
Hi We've got kx-tga250fx it keeps ringing saying incoming call when recieved it gives a normal signal and noobody is calling. I have taken out the batteries to reset it and it still does that.
SOURCE: I HAVE A PANASONIC PHONE
Emeritus,
There are several things to ask yourself.
1. Do you have the manual?
2. Is there any software programming which relates to set ring?
3. Is there a manual switch for ring on/ring off?
4. Will another phone ring when plugged into the same jack?
IF NOT, the red and green wire may be reversed at the jack.
5. Lastly, has this cordless handset ever rang?
Most cordless sets have a volume control from off to loud. I hope this will help you solve your problem.
I
Posted on Feb 25, 2008
pazman
  • 81 Answers
SOURCE: no ringer for incoming call
I have seen this issue before and panasonic knows about it. I would contact them directly.
Posted on Mar 30, 2008
vrabhilash
  • 52 Answers
SOURCE: my phone is not ringing on incoming calls
did u try removing the battery and reinserting after 2 min..
and if already tried,
then try dialing from oter phones, or check the assign tone in ur phone contact from which ur testing to be assigned with some ring tone...
Posted on Jul 17, 2008
cnavarro
  • 2460 Answers
SOURCE: Night switching for KX-T7630
You have 4 different modes of calling available to be programmed: DAY NIGHT BREAK and LUNCH. Your installer has to set up the ICD groups, but you can create a LUNCH group which looks like the day mode but rings all phones. The codes are accessed by dialing on the intercom *780x where 0 is day 1 is night 2 is lunch and 3 is break.
You may use the NIGHT mode in the daytime, but if you have voice mail, it will play the night greeting instead of a day greeting.
Carl
Posted on Sep 09, 2008
Phone Squad
  • 31 Answers
SOURCE: my motorola A1200E phone does
It sounds like your loud speaker which also produces the audio for your ringer has malfunctioned. This can be repaired. I recommend searching google for "cellular technicians' you need someone who can service your phone with the proper tools and not cause additional damage with static electricity. Try
www.cellulartechnicians.com
Posted on Oct 15, 2008
I have a panasonic kx-dt343, i can find the incoming call log but only calls that i've answered not ones i've missed. how do i check the missed calls? how do i set it up so the phone will flash if...
Normally, the ICD group is 601. So, press PROGRAM, pick a button, and dial 54601 STORE. The button becomes a log for all calls ringing into the 601 calling group.
Carl
Sep 22, 2011 | Panasonic KXDT343 Phone
My phone rings once and shows "Incoming call" on the LCD screen and when I answer, no one is there. People calling say the phone only rings once or it goes directly to voice mail.
You have to go into the menu and reset the rings so that the phone will ring at least 4 times. Your owners manual should give you directions to do that. You can also call Panasonic.
Aug 29, 2011 | Panasonic KX TG4023 Cordless Phone
I have a Panasonic Keyphone Model: KX-T7750, having problem with alert of intercom/incoming calls. No ring tone but with flash light and intercom light on. May I know how to fix this. Thank you!
Calls are signalled in two ways. First, check the Ringer switch on the left side of the phone. It's a 3 position switch OFF/LO/HI. If the outside lines are blinking the MESSAGE light, then the ringer is probably turned off. If your intercom calls are toning but not ringing, you may have the AUTO ANS light lit. Press it until it's off and intercom calls will either start ringing or send an audible tone.
If it tones, then you have a programming problem where intercom calls are set to tone instead of ring. That's corrected in system programming.
Carl
Apr 25, 2011 | Panasonic KX-T7730 Corded Phone
KX-TA308 in Malaysia, I have assigned Ext110 as operatior, when I call from internal using 0, ext.110 rings, but when incoming call pressing 0 for Operator, it is not ringing and it keeps saying that...
There is a second program that assigns digits to "0". You found the one in the phone system, but not the AA/VM. It's probably still trying to dial 101. Make it dial either "0" or 110.
Carl
Dec 28, 2010 | Panasonic KX-TA308 Phone
Hi: I have a Panasonic KX-T7420 phone. When one of the incoming lines is ringing and I pick up the handset, it picks up the intercom and not the incoming line. Is there a way to get the thing to answer...
There are 2 things that would prevent you from being able to answer a ringing phone by picking up the handset. Your phone has to be ringing, and you need to set preferred line ringing on incoming calls.
The second part is easy. Press PROGRAM 99 and dial 22 STORE on your phone. Now when a call rings on your phone you can pick it up. If you can't, then your phone is not ringing.
Ringing is set in system programming.
Carl
Aug 04, 2010 | Panasonic KX-T7420 Corded Phone
Incoming call rings one time and disconnects
Unplug all phones but one in jack 11 at the cabinet and have someone call in. If it doesn't work, you probably have a bad cabinet. If not, I'm guessing one of your extensions is faulty.
Carl
Apr 06, 2009 | Panasonic KX-TA308 Phone
Message problem
In your case there is no problem regarding your cordless phone. The problem might be in your network only. So please contact your network officer immediately.
Mar 18, 2009 | Panasonic KX-TG6700 Phone
No ringer for incoming call
Mar 30, 2008 | Panasonic KX-TG6052B Phone
Call forwarding
I don't know if you've got this sorted yet or if you're still looking for a solution. If you are still looking, try the following:
From the phone the calls currently ring at, try dialling:
7102, followed by the new extension number you want the calls to ring at. You should hear a confirmation tone and then you should be sorted.
To cancel this and go back to normal, at the original phone dial 7100.
Let me know if this works! :)
Feb 27, 2008 | Panasonic KX-T7433B Corded Phone
Cell Phones Logo
211 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
