Question about HP Pavilion dv6000z Notebook
Have just bought anHPG56 - 130SA Lap Top and the left SHIFT KEY does not work when I try for @ and capitals. The right hand one does! I took it back to the shop and was told the keyboard is American but having checked out a coulple of points I do not believe this to be a satisfactory answer?. Ia m a pensioner and my computer knowledge is limited. Please advise. Sincerely Reg Tarrant
    Brigadier General:
  • 8,909 Answers
The shop is correct, your keyboard layout is American. Unfortunately the shop omitted to set the computer up properly. I would take it back and ask them to set the country code to match the keyboard. It will take them longer to boot up the laptop than to do the job! It is that simple for a trained person to do and should have been set correctly in the first place.
I quite agree, it is disgracefull for you to have been given that information when they clearly understand the problem and could have done it there and then.
I don't know which country you are in and so I cannot advise on your rights. If you are in the UK and mention Trading Standards, you may get a positive result!
Any problems and we will try to help in any way we can.
Posted on Jan 03, 2011
Testimonial: "Thank you very much for the very prompt advice. It is really appreciated----------First class response! Reg Tarrant"
Left shift key types symbols not capital letters
it could be set to do so in system settings, like a shortcut. or there could internally be something inside under the keys which causes it to do that
Nov 03, 2013 | Computers & Internet
Gateway M460 capitalization issues
Try both shift keys, the left one may have died. Otherwise use Caps Lock.
Try this:
Navigate to Control Panel and double click Keyboard.
Select the Driver Tab at the top.
Now click Update Driver.
Updating the driver may work, otherwise a new board may be needed.
Take care!
damnor01
Sep 21, 2012 | Computers & Internet
Shift key
You may have to buy a USB or wireless keyboard and bypass the laptops.
Jul 22, 2012 | Toshiba Satellite M35X-S163 Notebook
I am trying to do a cap and can't figure out how to to change frame setting to be able to do this
Are you talking about making text capitalized?
If so, then all you need to do is hold down your "shift" key on the bottom left of your keyboard at the same time you press the letter in which you want to make capital and then release both keys.
If you want to type a whole line of capitalized letters, press the "cap lock" key on the bottom left side of your keyboard and then you dont have to hold down the shift key.
Mar 06, 2011 | Computers & Internet
I can`t get any upper case functions to work on hp 2011 keyboard what key do i press
1.Make sure the "Caps Lock" key is not on. Though this will be obvious to most people, if your keyboard is typing in only upper-case letters it can't hurt to check. Look at the "Caps Lock" indicator light on the top right corner of your HP keyboard. If the light is on, strike the "Caps Lock" key on the left side of your keyboard. This will turn the "Caps Lock" off, allowing you to type in lower case letters again.
2.Make sure the "SHIFT" keys on your HP keyboard are not stuck. Dust and dirt can build up on a keyboard over time, which can cause certain keys to stick. If either of your keyboard's "SHIFT" keys get stuck, your computer will type in only capital letters. Use a toothpick or cotton swab to remove the gunk from the key, which should help it return to its normal position.
3.Unplug your HP keyboard and then plug it back it. This will remove the device from your operating system and then automatically add it back in. This can have the same effect, essentially, as restarting your computer. If your keyboard was typing in capital letters due to an error being stored in your operating system's memory, that error will now be cleared and the HP keyboard will function as normal again.
4.Update your HP keyboard driver. Click "Start" and then right click on "Computer." Click "Properties" and then "Device Manager." Right click on the listing for your keyboard and then click "Update Driver." This will update the computer software that is associated with your HP keyboard. If your keyboard was typing in all capital letters as a result of an error with this driver, the error will now be fixed and you can use your keyboard normally again
Mar 01, 2011 | HP D8597A Keyboard
The right shift key does not work as well as a few of the upper left control keys...everything else seems to be working just fine.
Hi there , this might be the ribbon cable connecting the keyboard to the laptop , lay the screen flat , look at the left hand side of the lap top , there is a strip you can lift up , where the power switch is. lift the strip up , you will now see the two screws holding the keyboard down, unscrew them , slide the keyboard up slowly and lift , gentaly you will now see the small riben cable, lift the small black catch , then reseat the cable , push the catch back, and reseat the keyboard. now retry the keyboard ...
Nov 13, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
I cannot get my lap top to show on the all with my projector
Laptop will often have a function key (usually F5) for cycling between built-in display, external monitor, and both. Try pressing F5. If that doesn't work and you have a "Fn" key (usually near the left Shift key) hold down Fn and press F5.
Oct 11, 2009 | Compaq Presario Notebook
The Fn botton on my vio lap top won't work
The Fn button is like a 'shift' key. Just as you would press <Shift> and a letter to get a capitalized letter, you press <Fn> and a function key at the same time ( <Fn><F1> or <Fn><F2> and so on) to use the secondary function for that key. For example, on one of my laptops, the <F2> key has an icon for 'wireless' (looks like an antenna). If I simply press <F2>, I will activate the function for <F2>, but if I press <Fn> and <F2> at the same time, I will turn on my wiress adapter.
<Fn> all by itself does nothing.
Hope this helps.
Oct 08, 2009 | Sony Computers & Internet
Keyboard buttons
Hi Grumpy Gran
Great name by the way. Are they listed top to bottom ` a two headed arrow, caps lock, an up arrow and ctrl?
These are not particular active keys. If you have used a typewriter the two headed arrow is the tab key, use it to jump a given number of spaces to the right.
The caps lock will set your keyboard in capitals mode. The uparrow is the shift key which temporarily puts it into capitals or vice-versa. The ctrl key is a special key which is not used in normal typing. You may not need it in normal use.
Good luck with your surfing.
ps its not a good idea to unplug your keyboard whilst the computer is still on. You should connect it when the computer is off so that it is detected when the computer starts.
Mar 25, 2008 | Computers & Internet
Keyboard problem's
Yeah lol!!! shot the cat!
press the fn key and there should be a num key at the very top press those!
Dec 02, 2007 | Acer TravelMate 2300 Notebook
HP Pavilion dv6000z Notebook Logo
101 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
