Question about Maxtor Hard Drive
Want to use a Diamondmax Plus 9 as an external storage device, where do I position the Jumper?
    Sergeant:
    Champion:
  • 342 Answers
Cable select
Posted on Jan 03, 2011
Trying to transfer data from an old harddrive i have (maxtor, diamondmax plus 9 80 GB ATA / 133 HDD) to My HP laptop
Install the hard drive into an USB hard drive adapter case the plug this USB hard drive into the USB port in your laptop. The laptop will see it as an external storage device, open the various folders and copy the files to your laptop.
You can delete any unwanted files off this external USB hard disk and use it for backups and file transfer.
Mar 14, 2013 | Computers & Internet
Maxtor diamondmax plus 9 hard drive not seen by computer
I'd say you did a good job troubleshooting. Replace the drive.
Dec 29, 2012 | Maxtor DiamondMax Plus 9 80 GB Hard Drive
What is the jumper pin placement to make a slave of a DiamondMax Plus 9, 80GB hard drive?
The manual is linked below and section 3.3.1 covers jumper settings.
The slave setting shows the park position so you have a jumper on the drive so you can reconfigure it later.
A quick answer is that the slave setting is no jumper at all on the jumper pins.
DiamondMax Plus 9 Manual - DiamondMaxPlus 9.book
Feb 12, 2011 | Maxtor Hard Drive
What is the jumper setting to service (format) the diamondmax plus 9 disk?
This document might help you:
http://www.seagate.com/staticfiles/maxtor/en_us/documentation/manuals/diamondmax_plus_9_manual.pdf
Oct 06, 2010 | Maxtor DiamondMax Plus 9 80 GB Hard Drive
How to set jumper to slave mode on maxtor 6y080m0(picture pls)
These are the jumper settings for a Maxtor Diamond Max ATA hard drive.
Sep 23, 2010 | Maxtor DiamondMax Plus 9 80 GB Hard Drive
Need jumper settings wd800 as Mast. & maxtor Dia.plus as slave??
To use the WD 800 as a master there must be no jumper attached to it.The maxtor has a diagram for the jumper and it MUST be set to slave not cable select.
Mar 24, 2010 | Maxtor DiamondMax Plus 9 160 GB Hard Drive
What are the jumper setting for slave on maxtor diamondmax plus 9
This web page shows the jumper settings you require.
http://www.google.com/imgres?imgurl=http://www.seagate.com/staticfiles/images/support/en/us/mxo_ata_jumpers_rev.jpg&imgrefurl=http://forums.macrumors.com/showthread.php%3Ft%3D387061&usg=__oBf6Czrk9E5_4ovUuuyxJCl68fY=&h=411&w=850&sz=83&hl=en&start=3&itbs=1&tbnid=J_I6lp0cCbuIwM:&tbnh=70&tbnw=145&prev=/images%3Fq%3DJumper%2Bsettings%2Bold%2BMaxtor%26hl%3Den%26sa%3DG
Dec 01, 2009 | Maxtor DiamondMax Plus 9 120 GB Hard Drive
PC will not see Maxtor 80GB DiamondMax Plus 9 as seconary slave.
Two thing,
First, never use a Maxtor HDD as a slave to a CDROM/DVD, doesn't work and tends to cause stability issues. So try swapping the jumper on the CD/DVD to slave and setting the Maxtor to Master, this should get it working.
Second, if it is showing up as 33GB, you have the Jumpers set to limit capacity(designed to avoid troubles on older systems. If this is the case, you likely have a single jumper in the center row of pins between the power and data cables. If it only works as master at the moment, then you likely have the neter row(limit size pins) and the one closest to the data cable(Master Pin) both plugged in.
Change your DVD/CD to slave, remove the limiting jumper and ensure the Master jumper is installed on the Maxtor, then be sure the end connector on the ATA(likely marked master) is plugged into the Maxtor and the middle connector(Slave) is plugged into the DVD/CD, this should have you all fixed up.
Hope this helps FixYa,
Chris
May 19, 2009 | Maxtor DiamondMax Plus 9 80 GB Hard Drive
Can I use my maxtor diamondmax +9 as an external harddrive
Yes, this is very possible. All you need to do is purchase a harddrive enclosure. This google link contains shopping results for this item--> http://www.google.com/products?rlz=1C1GGLS_enUS291US303&sourceid=chrome&q=harddrive+enclosures&um=1&ie=UTF-8&sa=X&oi=product_result_group&resnum=1&ct=title
I hope this helps. Let me know if you have any questions.
Thanks, Raph30
Jan 27, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor 500 gig internal diamondmax 21
external USB hard drives do not need to be jumpered, if your computer does not recognize the ext. drive probably it is because the enclosure is defective, when you connect the USB cable you should get the "ding-dong" connection sound.
If you think that your computer recognizes the hard drive then jumper it as "secondary" or "cable select" and install it INTERNALLY, then transfer your data, that will prove that there's a problem with the ext. enclosure.
One more thing, maybe the USB port you use is malfunctioning, try one that you know that works (assuming that you have other USB devices that work).
May 04, 2008 | Maxtor Hard Drive
Maxtor Hard Drive Logo
Top Maxtor Computers & Internet Experts
Computer Links
terminalcon
Jerry Umali
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
