Question about Behringer Xenyx 1002fx Mixer 10 Input 2 Bus with Efx
Hi, I have a EURORACK ub1204fx and this is my problem: the effect does not work when I open fx return, there is much noise. Dpm5 broken?. How to get it? Thanks
  • Behringer Master
  • 5,603 Answers
This is confusing... the "FX return" is for an INPUT from an EXTERNAL effects unit... if you try to take output from there it will be nothing but noise as you are tying two inputs together with nothing driving them. Possibly you are misunderstanding the terms and use of these connections.
Posted on Jan 04, 2011
Effects won't work stuck on d2
Hi, did you find a solution for this problem? I have it too.
Nov 16, 2013 | Behringer EURORACK UB2442FX PRO Mixer
I need a new fx push knob for eurorack ub2442fx pro
This place has a great selection of Behringer parts. You should be able to find your knob here: http://www.dbmproaudio.com/behrparts.html
Jan 10, 2013 | Behringer EURORACK UB2442FX PRO Mixer
How do i wire up an effects unit for the eurorack pro RX1602? It only has a mono/FX output socket.
In your user manual on page 7 is figure 3.2 wire your effects unit like the Virtualizer they show... driven by that mono/fx send and the the effects return returns coming back into unused channels...
Sep 13, 2011 | Behringer Xenyx 1002fx Mixer 10 Input 2...
I have a behringer eurorack ub1204fx hooked up to a bose L1. I can't seem to get the reverb to work
you have to set three gain controls to pass the FX into the mix. The FX send gain for each input channel, the FX fader which sends the FX mix to the effects unit, and finaly the gain that sends the FX output to the mix. Depending on which effect you choose, some are very subtle.
Aug 06, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
When i have my FX on and sending to main they make a horrible clicking (shorting out) sound. if I push the main mix button it shuts off the effects and the noise goes away...bad side...then I have no...
Check the 5 volts to the FX unit, If the voltage is low, the FX processor will keep reseting generating clicks, In a different product, the 5 volt filter cap was degraded and voltage dipped down to 4.5 volts causing resets.
May 31, 2011 | Behringer EURORACK UB2442FX PRO Mixer
HI I NEED TO BE ABLE TO FIGURE A WAY TO BYPASS THE FX WITH A FOOTSWITCH, CAN YOU HELP PLEASE.
I am afraid they did not provide a way to control the FX via a footswitch.
What I would do is to use an EXTERNAL effects unit that does have foot switch input. Use this by connecting via two TRS insert cables to the MAIN L and R "insert" jacks. These insert cables each carry both the send and return signals for each side of the stereo.
Feb 28, 2011 | Allen & Heath ZED10FX 10 Channel USB Mixer...
Can't route effects to two channels of my mixer. If I plug into input 1 of my power amp, I have effects. If i plug into input 2 of my power amp, I get no effects. I tried both Crown and QSC power amps. ...
The power amp is the final stage - the last output from the mixer goes to the power amps.
Its a routing problem - some mixers only allow certain routing and this could be affecting your FX routes.
All the FX - internal or outboard come before power.
Check the manual Check the aux send and returns Check if you need need stereo plugs for the send and return of FX.
Get back if still stuck.
Feb 26, 2011 | Lexicon MX400XL Dual Stereo/Surround...
I have the Xenyx 2442Fx for about 6 months. I know it's still with in the warrenty period, but I have something rather strange happening to the digital fx on Aux 3. This is a bit of a long winded one but I...
This sounds like a breakdown in the digital circuits. You are seeing/hearing digital noise. This is most likely an IC that is breaking down internally. This will take some time to find/fix. Use the unit for your gig, then return it under warranty for repair. Pay close attention and note WHEN the problem occurs. If possible, try this multiple times and record any pattern to when it happens. The more detailed the "timing" the easier it will be for the repair shop to reproduce the problem and fix it.
Keep us posted.
Dan
Aug 17, 2010 | Behringer XENYX 2442FX Mixer
Power supply cooked
There isn't anything in the power supply you cannot rebuild except the transformer.
BUT you should verify that something in the mixer didn't short out and damage the supply.
After you relace the smoked parts (likely the TOP245Y offline regulator chip is gonzo... then you use this trick to restart the unit safely:
Put a 60 Watt light bulb in series with the hot side of the input power line. I would recommend you use an ISOLATION transformer when working on the power line side of this for safety.
Jan 17, 2009 | Behringer Pmp3000 16 Channel Audio Mixer
Open Questions:
See all Behringer Xenyx 1002fx Mixer 10 Input 2 Bus with Questions
Behringer Xenyx 1002fx Mixer 10 Input 2 Bus with Efx Logo
391 people viewed this question
Top Behringer Music Experts
Vito Vacirca Jr.
Matthew Spark
Matthew Spark
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
