Question about Canon P23-DHV Calculator
Removing the cushion, that came with it....brand new
Can not seem to figure out how to get the little sponge like thing out?
Gently Press the plastic window down and slide it out away from the calculator in the direction of the arrow.
Posted on Jul 12, 2008
Were could I buy sponge for headphones shb6110?
Measure the diameter across your headphones from edge to edge using millimeters. Once you have that, you can go through these results and should be able to find one that matches.
31results for headphone cushions padding sponge
Aug 29, 2014 | Philips New SHB6110 Bluetooth Stereo...
Tip
INK STAINED ON YOUR SEAT CUSHION FABRIC, NO TROUBLE
This is a quick and easy way to save you a lot of time and money if you have ever had a dissasterous ink spill on a velour type durable fabric, such as what I experienced in a car Dealership years ago, my new car get ready man sat in a brand new vehicle that had velour seats and forgot he had a pen in his back pocket, when he sat down in the cars seat the pen opened up staining the seat and his uniform real bad!!
Here is what I did.....
we got a lot of plain clean white cotton rags, and a couple of aerosol,cans of "Brake Cleaner" any brand that is the cheapest in price, spray the affected area and blot with a clean rag, use this proceedure over and over until you start to see the stain lifting out off the seat fabric, you know hwen you are done as the last blotting will result in a clean white rag and an impeccably cleaned seat fabric, the only thing that is left behind is a smell from the brake cleaner, let the car air out using a fan and all doors/windows open and after the seat drys use a scented spray on the repaired area, that will not restain the seat cushion again.
The smell will be gone after a couple of days and a little venting of the interior. $10.00 of aerosol cans and white rags versus a t least a couple of hundred dollars in an ordered replacement seat cushion, plus labor.
Have Fun!!!
on Aug 16, 2010 | Ford Crown Victoria Cars & Trucks
Removing rear set for 76 cutlass
I have done this several times, but it has been is a while!
I think it goes like this.
On the bottom front edge of the rear bench seat cushion are two stamped metal "hooks" that secure the bottom of the seat to the floor. These hooky things and their matching loops are about 12 inches inboard from the far end of each cushion, or maybe a little more than a foot on either side of the center. There are matching wire loops are welded to the floor of the car. To remove the bottom cushion, you push the lower seat cushion back toward the rear of the car a few inches, and lift it . Pushing it back a few inches should cause the hooks to clear the loops. It should be hard to do.
The upper rear cushions are bolted with a couple of screws to the trunk firewall. Removing a couple of screws at the bottom will allow the rear upper cushion to be lifted up.
Be blessed.
May 21, 2014 | Chevrolet Chevy Cars & Trucks
I lost my instruction manuel and i dont know how to put oil in the airfilter
pop air filter of.Carefull not to let anything get down into engine. Remove sponge. If theres 2 sponges then you need to coat the inner sponge. pour a little onto sponge and squeeze so it gets into all the holes. give it the sponge a good last squeeze holding over jar to get rid of excess as this will prevent air from entering engine. Fit air filter back on. Good idea to have a few spare so when one is used others can be washed and dryed. Either wash in wasing up liquid and dryed or nitro fuel and dryed.Hope this helps.
Aug 06, 2010 | Tornado 110 Nitro 4wd 2 Spd Off Road S30...
The pads are teaard and Yellow Sponge of the pads came out,
Based on what you are saying, those are the signs of old age, unless the dog got them..
Short term solution is to put the foam back in as best u can, and either glue or duct tape the covering back in place.
If you use the duct tape, be sure to not to cover the area where the sound comes from when you repair them.
The duct tape will not affect the comfort factor if applied smoothly and wrinkle free,
Long term solution is to replace the ones you have.
Check around for pricing.
If your sound equipment is fairly new, wireless headphones are an option.
Happy listening.
Sep 30, 2009 | Bose QuietComfort 2 Consumer Headphones
Soup boiked over on stove top
I had some luck removing food and other stains with the new Vielda Glass Ceramic Scrung (its a sponge)
"Special scour sponge for cleaning glass ceramic cook tops without scratching. Eliminates burnt-in stains and greasy dirt film. Removes grease and loose dirt particles. Microfibre side will create a streak free finish."
I found mine at Walmart. It was a little pricey but if you just use the sponge for the stovetop then it will last a very long time.
Hope this helps.
Dec 17, 2008 | Kenmore 95592 / 95594 / 95595 / 95599...
Electrical issues
If you are not fimiliar with electronics repair then I would have to say take it to a repair shop. You can check the cord and make sure it was not frayed, Also make sure it was plugged in completely to the wall when you give it a try. If the cord is frayed you can take it to any electronics store and buy a new one or order a new one online.
Dec 19, 2017 | Panasonic Health & Beauty
We have a Kenmore Stylite Retrax vacuum cleaner, brand new. Suction is not working properly.
I actually pulled back my old vac after using this thing. Having said that I have played around with it and one quick cure is the remove or clean the little circle sponge filter at bottom. If you remove the canister and look at the bottom of vac you will see where the air travels down through a small circle. In there is a sponge filter that is probably clogged. Now Being frustrated, I just removed it and the vac sucks like crazy now. There are just way to many filters to worry about. As mentioned you need to clean the top main filiter, then the top sponge filter, and then dont froget there is alson one in the front of the machine (square paper filter) that catches dust leaving vac. These are on top of the little circle one that I removed, so I dont think it will be missed. Try and see what you think.
Apr 21, 2008 | Vacuums
Canon MX850
funny thing, just had the same problem on a Canon mx850, one year old. the cause = a serious paper JAM. My solution, i freed all the paper around the two little black spongs under the inks cart. then, i turned the printer on, waited for it move the ink cart to the middle, after i unplugged the printer so that the ink stayed in the middle. this permits you to move it freely, and have the room to work on the purge system. 5c20 is the pruge system not working correctly! i actually had to take apart my printer, opened it in two to find that the little motor that moves the purge system just got unplugged, probably by the paper JAM!. simply replugged the little motor. before trying this, behind the two black hard sponges, under the white squeege that moves back and forth; is a little black wheel, with uneven teeth spaced on it. this only turns clock wise direction. must likely it's stuck, needs to do a complete turn to be realigned. clock wise only (try to move it if your not sure what side is clockwise, don't insist, it's not that hard to turn the right way!!) now, when you turn this wheel, the squeege moves back and forth and the sponges go up and down, alernating with the sponges. it should become easy again, and the problem should be alright!
it's to be noted that, i won'T open the printer like i did, if is just out of the box!! or still under warantee.
i live in the middle of no where, and i had nothing to lose in trying to fix it myself.
hope this helps, write for more questions
Mar 23, 2008 | Computers & Internet
Canon P23-DHV Calculator Logo
22 people viewed this question
old marine
old marine
