I have a Text SL 802-CSM calculater need to change vat from 17.5 to 20% how do i do it please
You press
(C.CE) (20) (MGN SET) (COST TAX +)
That it done
Posted on Jan 18, 2011
How do I reset anti theft in my 2002 ford f150
tis a process so here goes..... Central Security Module (CSM) enable/disable mode allows autolock feature to be turned on or off. To enter enable/disable mode, close all doors. Ensure ignition switch is in LOCK position. Perform the following steps within 30 seconds:
Turn ignition switch from LOCK to RUN position.
Press power door lock switch UNLOCK button 3 times.
Turn ignition switch from RUN to OFF position.
CSM module should chirp horn indicating CSM module is in enable/disable mode and ready to accept program changes.
Press power door lock switch UNLOCK button once to command CSM module to toggle autolock feature on or off. Press power door lock switch LOCK button once to enable/disable autolock feature. CSM module will chirp one time to indicate autolock has been disabled.
CSM module will chirp once, followed by a longer chirp to indicate autolock feature has been enabled. Press power door lock switch UNLOCK button once, then turn ignition switch to OFF position to exit enable/disable mode. CSM module should chirp once to verify a feature change. Best to you.
Dec 31, 2017 | Ford Cars & Trucks
Am not VAT registered yet how do I remove the last owners VAT number from my casio te 2000 till when I issue receipts thanx
Turn key to Program mode 2 SUBTOTAL Now you will see the P01 change to P02 on the display. This is text mode ------------------------------------------------------------------------------------------------
If anyone needs a Casio TE-2000 manual, go here:http://the-checkout-tech.com/manuals/cashregisters/Casio4.php
Apr 24, 2013 | Computers & Internet
How to take the vat number off the receipt on casio te 2000
Without a manual, you won't have the layout for entering text or the character codes to enter text manually. Someone may have left the text on the front of the buttons if you are lucky. Can you see the alphabet drawn on the front of each button?if not, You'll need a manual. There is one here:http://the-checkout-tech.com/manuals/cashregisters/Casio_TE-2000_users_and_programming_manual.html
May 01, 2012 | Casio Parts Cash Register PC Desktop
How to change the lock code on the door
The owners manual has directions on changing or adding a personal code.
If you are talking about the factory code, the only way to do this, is to replace the CSM ( Central Security Module, mid 2000 MY and older it was called a RAP - Remote Antitheft Personality )
A RAP and CSM are not 1 for 1 pin compatible, so if you go to a junk yard for a new CSM, make sure the build date on the truck is 2-OCT-2000 or newer ( up to a 2004 Heritage or Lightning, not the new body style 2004 ).
The CSM is up behind the dash on the driver's side.
The CSM is the white color box center of this picture, that is the parking brake on the left side of the picture.
If you did not get an owners manual with your truck ( purchased used ), you can download one from Ford :
https://www.fleet.ford.com/maintenance/owners_manuals/default.asp
The setting a Personal Code for the door keypad starts on page 111 in the 2002 owners manual.
Oct 25, 2010 | 2002 Ford F150 Regular Cab
What is CSM/SLA -of CD-RW DRIVE SH-R522
It's not CSM/SLA. The letters CSM are directly over SLA, and they are vertically read as CS, SL, MA -which stand for Cable Select, Slave, and Master. They are found on IDE drives as the jumper points. Depending on where the drive is connected on an IDE cable, the jumper should match accordingly. CS is often used for either, preferably when there are no other devices on a single IDE cable.
Sep 27, 2010 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
How to get to Program 2 to change VAT number
If anyone needs a Casio TE-2000 manual, go here: http://the-checkout-tech.com/manuals/cashregisters/Casio4.php
Sep 24, 2009 | Casio TE-2000 PC Desktop
As the VAT has changed in the UK to 15% instead of 17.5% i need to change this on my Casio calculator. I have a Casio MJ 100. Please help me!
Hi. Switch on using the Ac button
Press the TaxSet button - and hold for 2/3 seconds
You will be show either the current tax held or zero
Type in the tax you want ie 15
Now press the taxSet button.
To verify its worked prees Ac button then press the Tax+ button is should now show you 15%. Hope this helps.
Apr 30, 2009 | Casio SL-100 Calculator
Blunt Clipper blade
www.sheareaseltd.com £5.90 incl VAT & Postage for sharpening.
Apr 04, 2009 | Sunbeam SBCL 802 Hair Trimmer
166 people viewed this question
k24674
jasbo
jasbo
