I have a toshiba 46h84. it wont come on at all. the power button doesnt light up, but there is power running thru the fuses and 5.8 volts at the power button. i have schematics for the tv. could someone point me in the right direction or give me some possibilities?
  • 734 Answers
Check the latching relay to switch on the tv.
Posted on Jan 03, 2011
  • garysgirl Jan 03, 2011
    I don't see a latching relay on the schematic. Is there a number on it?
I HAVE A TOSHIBA SATALITE A135-S4427 TURNED IT OFF ONE NIGHT WORKING FINE, THE NEXT DAY IT WONT TURN ON. I HAVE POWER THRU THE CORD AT ABOUT 18+ VOLTS BUT NO INDICATOR LIGHTS OR POWER TO COMPUTER. HELP?
Try removing the battery and power supply, hold the power button for about 10 seconds then just plug the power supply back in (not the battery) and see if it turns on.
Holding the power button with no power supply can discharge any stored power in capacitors.
Oct 24, 2013 | Toshiba Satellite A135-S4427 Notebook
I have a 42 inch toshiba 720 dlp hdtv, and it wont turn on. i press power to turn it on, it tries to fire up, the lights under power and lamp start blinkin green, and then orange, but then just stops and...
Tv "LAMP" LED light indication is blinking or lite up?The tv projection lamp insisde this tv now like 1 1/2 or 2 years already?Tv on and used daily like 4 or 5 hours everydays?Yes.The tv projection lamp life are over.The tv require a new tv projection lamp.Still have problems after this the tv board that call the Ballast board it is dead too,must require changing too.The Ballast board only job are to help to fire up the tv projection lamp and keep it lit.
May 01, 2011 | Toshiba 46H84 46" Rear Projection...
When i turn my toshiba tv model #46h84 the green bulb lights up the screen but then shuts off and there is no picture! please help me out!!!
I have the same exact problem...for a few weeks the TV would turn off and the red power light would blink. Then the other day I started having exactly the problem you describe...green screen for a few seconds and then total shutdown.
Feb 08, 2011 | Toshiba 46H84 46" Rear Projection...
Sirs: We were just changing channels and the
THE projection bulb is blown if no sound tv probably broken
Jul 31, 2009 | Toshiba 46H84 46" Rear Projection...
No picture but sound on Toshiba 46h84
If you feel comfortable enough, you can try replacing the pico fuses on the power supply board. Test them with a multi meter very carefully.. these sets have up to 5000 volts and care should be taken, even by a professional with the back panel removed.
Jun 13, 2009 | Toshiba 46H84 46" Rear Projection...
Relays wont click on when plugging power to deflection board 1730c toshiba 46h84
have you checked your fuse? Will the relay click when you press power? You may possibly have a bad relay or the bridge rectifier diodes could be open.
Jun 18, 2008 | Televison & Video
Blue crt assmbly maybe?
its very possible that the blue CRT is horting the set out. Heres how you can test it. Remove the speaker grille and access panel behind the grille and you will see the crts. remove the blue crt circuit board from the end of the blue crt and make sure it isnt touching anything then try powering up the set if it doesnt shut down then you have found the problem and you will need a new crt. or you can switch the blue circuit with the green and try it iwth the blue on green and the green on the blue then if the screen turns green before shutting down you will know that its a problem in the blue drive circuit and not the crt. lety me know if you need further assistance.
Apr 01, 2008 | Toshiba 46H84 46" Rear Projection...
TURNS OFF BY ITSELF
my tv starts turning a red color and then turns off by itsself then i have to unplug it to turn it back on every 5 mintues or so.
Nov 14, 2007 | Toshiba 46H84 46" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
