Question about Smeg STX2 Dishwashers
Hi, my dishwasher has recently starting making a lot of noise at the beginning of the wash cycle, then does not release the tablet during the cycle, and at the end has the 'rinse' and one of the 'end' lights flashing. can you help ? thanks
  • 3 more comments
  • dingles302 Jan 05, 2011
    Daniel
    Thanks for the reply. Is the drain pump assembly easy to get to ? If so could you advise how to get to it.
    Thanks
    David
    Just to clarify. Is this an external panel underneath the dishwasher or inside the dishwasher below where the filters are located ?
    For clarity. Is the panel external to the dishwasher or inside the dishwasher below where the filters are housed ? thanks
    okay, thanks. I will have a look.
  • dingles302 Jan 07, 2011
    I removed the panel below the filter but could not access any other componants from inside the dishwasher. As this is a integrated dishwasher I do not want to take it out on my own. Can you confirm if I will need to remove the diswasher to get to the pump or should it be accessible from inside ? thanks
  • 4,323 Answers
Hi
The noise that you hear can be coming from the impeller that is either broken or has gone bad and should be replaced. The impeller is located in the drain pump assembly, also it can be due to the motor going bad if the impeller seems to be fine. Hope this helps...
Daniel
Posted on Jan 05, 2011
  • 2 more comments
  • Daniel Scott
    Daniel Scott Jan 05, 2011
    David the bottom panel comes off to access the drain pump assembly.
  • Daniel Scott
    It is the panel where filters are located.
  • Daniel Scott
    Alright
  • Daniel Scott
    Daniel Scott Jan 07, 2011
    Yes right then it should be taken out.
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Why is my whirlpool dishwasher making a loud noise during drain, wash and rinse cycles?
They can be complicated to re-assemble. Best solution is to video the procedure (if you have a video camera) during disassembly and make notes and diagrams to orient things properly and make sure the correct screws go back where they shoud. Takes more time, but you'll be glad you did, it will save you a lot of aggrevation in the long run.
Aug 24, 2014 | Whirlpool 24 in. GU1500XTLS Stainless...
I have an ASKO D3250 and it has recently started making a loud noise from the pump area. It starts as soon as the cycle begins and doesn't stop even if you open the door. It seems to stop about 90 seconds...
All power and sounds should stop when any dishwasher door is opened.
Your door switch may be stuck causing it to continue.
The 90 second sound at the beginning of the cycle is the water pump extracting any residual water before taking on clean water for the wash cycle.
Any excessive noise from the drain pump could be debris in the pump. e.g. broken glass.
You can remove the pump and check it for blockage or any foreign object.
Aug 14, 2010 | Asko 24 in. D3250 Built-in Dishwasher
CONIA DISHWASHER CDW1211 -Thelittle door that
i find it hard to get parts for these because the are imported from china.it may be better to replace the dishwasher
Jun 08, 2010 | Dishwashers
My dishwasher is just 6 months old and started making a humming sound while washing in th wash cycle.
If you hear unusual noises during dishwasher operation, check to see if a dish or cup is loose and being knocked around during the wash cycle. If you hear grinding, grating, crunching or a buzzing sound, chances are a hard object has gone into the wash module. Once the object is ground up, the noises should cease.
Apr 03, 2010 | Jenn-Air JDB6510 Built-in Dishwasher
Our dishwasher is making a loud noise during wash cycle.
if you have a torx 20, and torx 15 screw driver, you an remove the screws from the top plate of the wash motor, and underthere youll see another t15 screw converingthe "chopper" assy, sounds as if a seed, of chicken bone, perhaps apiece of glass hasgottne down there
Jan 25, 2009 | Whirlpool GU3600XTSY Stainless Steel...
Tablet falls out & doesn't dissolve especially on fast cycle
Hi and wlecome...
You should not use anything other than powered dishwasher detergent in these products. They are not designed for tablet-style detergents. The reason is because the dispenser does not "open" during the wash cycle like you would see on a conventional dishwaser. The incoming water pours over the detergent and releases the mixture out the bottom of the dispenser. If you need a user guide, you can get one here: http://fisherpaykelparts.net/index.php?blockitemid=29
Jan 22, 2009 | Fisher and Paykel 23 in. DS603H W Built-in...
My dishwasher does not completely drain after a wash. what do i do?
  1. Check for hose kinks or food plugging drain hose. Start at the drain port exit
  2. Check the check valve and drain hose for debris.
  3. Check pump motor for reversing during the pump out make sure the dishwasher is pausing between the wash and drain cycles letting the pump/motor reverse for the drain cycle.
  4. Check timer for not letting the dishwasher pause. ( not all dishwashers )
  5. Check pump motor assembly for a drain solenoid, during the pump out make sure the solenoid makes that distinctive "clunk" noise
  6. If you have recently installed a new garbage disposal, check knock out plug at connection.
  7. Check pump impeller for damage.
  8. Check that the water inlet valve isn't seeping fresh water into the dishwasher when off
Jan 08, 2009 | GE Nautilus 24" Built-in Dishwasher
Noisy Dishwasher
has there been any hard objects such as fruit seeds nuts egg shells ect. is it doing it in all the cycles
Mar 28, 2008 | Dishwashers
Diswasher motor making noise during wash cycle
It could be the impeller on the motor. The impeller fits over the shaft of the motor and might have split/broken up. That funny noise is probably the shaft spinning inside the damage impeller. Fortunately the impeler is fairly inexpensive and easy to replace. I believe there are one or two parts/covers to remove that are held in by a roughly half dozen torx screws.
Jan 04, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
Smeg STX2 Dishwashers Logo
134 people viewed this question
Top Smeg Dishwashers Experts
Cleverer2
paul
paul
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
