Quark Xpress has stopped working on my Mac. I've tried re-installing from original disc but this did not work.
I contacted a local engineer who came round and fixed it.
Posted on Jul 10, 2008
How do I download Quark Xpress for Mac free?
Quark xpress is not free bur you can download a trial version at their website. http://www.quark.com/Products/QuarkXPress/Test_Drive.aspx
Oct 26, 2014 | QuarkXPress
Overprinting quark xpress demo on all documents
Enter a valid product key. If Quark Xpress doesn't nag you for the key with an automatic dialog box, you will probably find the registration info entry in Preferences. If you have already entered the key, something corrupted the key file, so try entering it again.
Feb 27, 2014 | Apple MacBook 13"White /2.0Ghz Intel Core2...
I can't get Quark Xpress 9 to launch
Go to: C:\ProgramData\quark and delete all sub folders and files present there.
If that doesn't makes any difference in your case than you can run System File Checker (sfc).
You may try uninstalling Quark, rebooting the computer and re-install it.
If at all you don't get any help with that as well than you can try performing system restore.
Jan 11, 2013 | QuarkXPress 7 Full Single User Mac/Win...
I purchased Quark Xpress back in 1990 or so, and the installation discs were the old 3 1/4 discs. I paid for updaters, and at updater 6.1, I still have the Quark CD, but some of the original Quark Xpress...
I continue to be amazed that no body has found THE elegant solution I did. As a matter of fact I am using Quark 4.1 on Window 7, I used it on Vista (where it performed better than Vista) and on XP back at least to 98 or perhaps 95. My original install required burning a floppy (good luck with that today) for the registration. At some point, I discovered it was truly portable and simply copied the installed Quark directory to a new location (anywhere) on each new system. I dragged out a shortcut onto the desktop to the executable on every new platform. It still runs fine on this 64bit Window 7. Has not blown up yet. Something I wish I could say about other software. The only rub I found is that MS monkeyed about with associations (which worked fine in XP & Vista) and I have yet to be able to set.QXDs to Quark when I even set .QXTs to Quark.Windows 7 automatically served up In-Design as being the first (default) association in my programs list. Something I did not accept. I even tried to rewrite the registry in an attempt to make it work.
In fact, if you look into the .DLLs under Windows, you may find versions of the same .DLL that can run under 64, 32 and 16 bit environments. I suspect it will work under Windows 8 if MS doesn't leave working procedures ALONE!
May 20, 2011 | Quark Academic QuarkXPress 6.1 for PC
Mac computer says registration code is wrong on my 6.1 quark xpress. I've checked it several times and it is correct and it's not loaded on another computer. Also the computer I'm trying to load it to...
not possible to bypass the code . if you spent money on buying Quark... you NEED to get it working properly. You should mail quark or take the faulty product back to the shop you got it from.
Apr 14, 2011 | QuarkXPress 4.1 for mac
Error 1720. Trying to install Quark 6.1 on Windows 7
I definitively solved this problem. Follow these steps:
1) Install first Quark Xpress 6.1 on a Windows XP PC.
2) Copy the entire directory of installed files (Normally c:\program files\quark) on a pen drive.
3) Install Quark Xpress 6.1 on your Windows 7 PC until the installation stops with 1720 error.
4) Abort the installations, then copy the Quark directory stored on your pendrive in c:\programs x 86 directory overwriting the existing one.
This way Xpress 6.1 works perfectly on a Windows 7 PC. Guaranteed!
Sep 02, 2010 | QuarkXPress 6.1
I have a Quark XPress 6.1 system on my AppleMac for my work as a journalist. For some reason, completely out of the blue, when I try to click on a page on my desktop to see on screen I get the clock...
It could be that your quark preferences have corrupted, I would go to your users folder then go into the library folder, then the preferences folder and then the quark folder within the quark folder there should be a file called "XPress Preferences.prf" move this to the trash. (Do not empty the trash if it does not work you can replace the file back into the preference folder) When you open quark next it will recreate the preference file and hopefully that will sort it out. Please note your preferences will be back to default and you will need to reset them. Hope this helps
Jul 02, 2010 | QuarkXPress
Quark xpress no longer valid error
iI,m also angry, coz i've lost my Cd Key of Resident Evil 4. I want to play But I can't. Plz Tell Me that how can i get back my CD KEY again?
Feb 22, 2010 | QuarkXPress 7 Full Single User Mac/Win...
Quark 6.5 Error code -39 in a Mac platform
in this case try creating a preferences folder under the HDD>>Applications>>quarkXPress 6.x folder and then check the results.
if it still continues then try to downsave the document to version 5 by doing a file>>save as and changing the version to 5 from there
Feb 05, 2008 | QuarkXPress
Corrupt documents
please try to open the document on a diff machine and if it doesnt works then contact quark tech support for assistance
Jan 15, 2008 | Quark AVENUE XPRESS (115261) for Mac, PC
Computers & Internet Logo
79 people viewed this question
David Payne
David Payne
