Question about Printronix Line Matrix P5210 Printer
Can someone help me on how to clear this error? thanks in advanced.
Clean shuttle on printer
  • bhamu Apr 24, 2009
    I have Shuttle Jam error in my printronix p7210 printer so please advice me how to solve it for regular work.
  • 38 Answers
See this post:
Posted on Aug 02, 2008
Shuttle fault
If the printer detects the shuttle moving at the incorrect frequency, it shuts down the shuttle and attempts to restart it.
If the shuttle still operates incorrectly after three consecutive attempts, the Printer goes Offline, and the Shuttle Fault message is displayed.
Press the Clear button, then put the printer back Online. If this doesn’t work, turn the power switch off, then back on again.
If the error is still seen after performing the above actions, check there are no paper jams , labels etc or ribbon jams that may prevent the shuttle moving correctly. Also check the Patten gap to make sure it is not closed too much.
Then you may need to change shuttle components
Dec 04, 2009 | TallyGenicom 6306 Matrix Printer
I am receiving an error message on my HP Officejet 6110 printer screen that prevents the printer from functioning. The message is "Open door. Clear carriage jam and then press enter." I've tried opening...
yes, that is a carriage jam and not paper, the grinding is from the clean station that gets blocked with dried ink and cant move. you need to open the printer and clean the ink off of the clean station so it can clean properly and not cause a carriage jam.
Jun 29, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Shuttle jam appear
in this pdf u have got the problem solve the shuttle jam problem
Apr 01, 2009 | Printronix P7010 Printer
Hardware may be
first of all do one thing and that is keep your platen marked A,B,C in b or c position then start printer if it prints then it means your shuttle gets very much tight in position A, for that please switch off the printer remove paper and loose your shuttle and adjust your shuttle according to the movement of paper. also do one thing that is clean your shuttle senser also.
Feb 19, 2009 | Printronix Line Matrix P5005B Printer
Error 058 Shuttle Jam on an IBM 6400 Matrix printer
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 06, 2009 | IBM 6400 Matrix Printer
"Shuttle jam" see manual problem on Printronix line matrix P 500E printer
Verify that there is nothing clamped between the platen and the shuttle.
Last time I had this fault, it turned out to be a broken wire in the harness that connects the CMX board to the shuttle module.
Other possibilities include a failed shuttle or CMX board.
Steve W
LazerTek LLC
Jul 06, 2008 | Printronix Line Matrix P5005B Printer
"Clear paper jam" error, but there is no jam!
Try cleaning the rollers, it's the maintenance tab on the printer's properties. Maybe this will help.
Feb 28, 2008 | Canon PIXMA MP130 All-In-One InkJet...
058 shuttle jam
This can happen for a number of reasons.:-
a. The print mechanism needs to be adjusted ( You'll need a technician to do this if yu are not familiar.
b. Something is clogging the print mechanism, eg Old ribbon residue, or sticky labels etc.
c. The paper thickness lever is set to incorrect setting . Try adjusting it out .
Jan 18, 2008 | IBM 6400 Matrix Printer
Printronix Line Matrix P5210 Printer Logo
601 people viewed this question
Top Printronix Office Equipment & Supplies Experts
Chinmay Joshi
Chinmay Joshi
Are you a Printronix Office Equipment and Supply Expert? Answer questions, earn points and help others
