Question about ASUS P5PE-VM Motherboard
CPU overvoltage error"
    Director Badge:
    Uploaded 100 video answers.
  • 1,751 Answers
Hi
Did n't you just post in hardware about flashing the BIOS?
Did you enter the BIOS & check the cpu voltage setting to make sure it's correct?
Actually, after the flash you probably should have used the ClearCMOS jumper to reset the BIOS,
then ran thru ALL the settings & manually adjust them for best performance.
Posted on Jan 03, 2011
2 Suggested Answers
immortal4u
  • 223 Answers
SOURCE: Dear All, When we start Deaktop
hi yadav, i think you have tryed al, i am sure there is no problem with your CPU or SMPS , i think your motherboard got shortcircuited , just try this steps if nothing work mean you have to replace your Motherboard yadav.
step 1 - Try resetting your BIOS settings to default
step 2 - Do you have the AUTO Overclocking feature enabled? If so... DISABLE it.
step 3 - try a BIOS upgrade
Good luck ! if you think your problem solved don't forget to rate
My asus motherboard is shown the cpu is in over voltage stage what will be the problem in this case btw i already replace with new power supply unit .....
Regulators (and capacitors) on the motherboard control the CPU voltage, not the power supply. The power supply is never exact enough.
How much overvoltage is it?
Be sure and check your voltages in BIOS if possible, it's not taxing your computer but it is more accurate than some voltage reading programs. Also try another program to read the voltages as you may get different results.
Sep 08, 2016 | ASUS Computers & Internet
Error: "Intel CPU uCode Loading Error" - "Press F1
This could have been a RAM issue or a BIOS issue. Check your RAM first and reset your CMOS. If possible upgrade your BIOS version from the manufacturers website. but be very careful if you do so. a wrong move may spoil your Board completely.
Sep 18, 2011 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
My motherboard is p5sd2-vm. how to fix CPU overvoltage error on start up?
Hi
Have you overclocked the system? If so, reset the CMOS by popping the battery out for about 15 mins. Then putting it back in.
May 26, 2011 | Computers & Internet
Dear All, When we start Deaktop come erorr "CPU overvoltage error" Press F1 We reinstall OS,remove Fan and pest Hit sniak,Change SMPS but same problem comeCPU overvoltage error" ...
Jan 03, 2011 | ASUS P5PE-VM Motherboard
The light on my hard drive is yellow rather than green and my computer will not turn on.
Ordinarily yellow light indicates ACPI standby. On some Dell and HP motherboards the same light also indicates a CPU failure, usually due to overvoltage or overheating.
Turn the PC completely off (unplug from the wall socket). Open the side, so you can see the motherboard with CPU and heat block. Best if you wait some ten-twenty minutes. Plug the power cable and power on the PC. Does it turn on, and does the CPU fan rotate correctly? If the PC turns on, and the fan doesn't, you have a busted fan which needs replacing.
If this doesn't solve the issue, describe exactly how the error happened. Is it a new PC, a PC which already worked and stopped doing so, a DIY assembled machine? Does it never turn on, or does it sometime do?
Aug 20, 2010 | Dell (8N816) Motherboard
I have PC with motherboard:P5VD2-MX/V2PE/DP_MB<GA>;CPU 3.4GHz
if your Cpu has burnt out within 6 months look at the cooling on the cpu and also make sure you use a good quality heat dissipation compound such as arctic fox! failing that you could have an overvoltage issues supplying more than the recommended voltage to the cpu
Jun 21, 2009 | Intel Motherboard
In setup
Here are the settings.
The fine clock ratio stayed at 0.5 after I loaded optimized defaults.
Robust Graphics Booster___________ [Auto]
CPU Clock Ratio ____________ [8]
Fine Clock Ratio ____________[0.5]
CPU Host Clock Control_ [Disabled]
CPU Host Frequency (MHz)__________ [333]
PCI Express Frequency (Mhz)_______ [Auto]
C.I.A. 2__________________________ [Disabled]
System Memory Multiplier (SPD)____ [Auto]
DRAM Timing Selectable_______ SPD __ [Auto]
Performance Enhance = [Turbo]
CAS Latency Time________________ Auto (7)
Dram RAS# to CAS# Delay_________ Auto (7)
Dram RAS# Precharge Delay_______ Auto (7)
Precharge Delay (tRAS)__________ Auto (20)
ACT to ACT Delay (tRRD)_________ Auto (4)
Rank Write to READ Delay________ Auto (5)
Write to Precharge Delay_________ Auto (10)
Refresh to ACT Delay______________ Auto (60)
Read to Precharge Delay__________ Auto (5)
Static tRead Value_______________ Auto (6)
Static tRead Phase Adjust________ [Auto] (0)
CPU/PCIEX Clock Driving Control [800mV]
CPU Clock Skew Control [normal]
GMCH Clock Skew Control [Normal]
System Voltage Control____ [Manual]
DDR2 OverVoltage Control__ [normal]
PCI-E OverVoltage Control_ [normal]
FSB OverVoltage Control___ [normal]
(G)MCH OverVoltage Control [normal]
CPU Voltage Control_______ [1.25]
Limit CPUID Max. to 3.....................: [Disabled]
No-Execute Memory Protect............: [Enabled]
CPU Enhanced Halt (C1E)................: [Disabled]
C2/C2E State Support....................: N/A
x C4/C4E State Support..................: N/A
CPU Thermal Monitor 2(TM2) ...........: [Enabled]
CPU EIST Function.........................: [Enabled]
Virtualization Technology................: [Enabled]
Integrated Peripherals
Legacy USB Storage Detect___________________[Enabled] *Note* Must be enabled to flash from USB
Hope this Helps, Please Rate My Response! Thanks!
PREM
Feb 20, 2009 | Gigabyte GA-8S661FXM-775 MATX MBD SIS661FX...
Gigabyte GA - x48 - DS4.
Hi Plineh,
It sounds like a bios issue. (So it would be considered a hardware issue).
Uninstall all driver software for the radeon. (If the software for the nVidia software is in the system, uninstall it as well). Check your bios settings, see page 51 in your manual.
Set, Robust Graphics Booster, to [Auto].
CPU/PCIEX Clock Driving Control [800mV] you may need to go lower.
CPU Clock Skew Control [Normal]
(G)MCH Clock Skew Control [Normal]
System Voltage Control [Auto]
DDR2 OverVoltage Control [Normal]
PCI-E OverVoltage Control [Normal]
FSB OverVoltage Control [Normal]
(G)MCH OverVoltage Control [Normal]
Loadline Calibration [Auto]
CPU Voltage Control [Normal]
(Restart the system with one radeon installed into PCIE_16_1 slot.) Once windows finishes loading re-install the latest software for the radeon. (Download from here):
http://www.sapphiretech.com/us/support/drivers.php
Monitor the card & see if it goes into hyperdrive. If it does not than sut down the system & add the second card into PCIE_16_2 & run in crossfire mode.
You may need to adjust the bios setting further if either card goes into hyperdrive. Your board was made in 2008 & is still under warranty. I call to the manufacture's tech support is something I would not exclude.
http://www.gigabyte.com.tw/Company/ContactUs.aspx?CompanyWebPageID=6
Good luck & take your time!
Mike
Nov 04, 2008 | Intel Motherboard
I need help
first off check the CPU fan operation then check the heat sink is clean and has no dust in the vanes etc.
otherwise go into bios and you will have to go to the page that controls CPU and check settings are for your CPU and not overclock settings
Jul 29, 2008 | ASUS P4P800 SE (890552603657) Motherboard
ASUS P5PE-VM Motherboard Logo
329 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
