Question about Hotpoint WMA13 Front Load Washer
My washing machine drum wont turn. The washing machine fills with water then just sits with water in it. It will drain but wont spin It worked fine yesterday, but today nothing. When I turn the drum by hand, there is still resistance there, so I dont think the belt has gone.
  • Patricia Swift Jan 07, 2011
    Thank you so much for your advice. Brushes now replaced and I have my washing machine wqorking once more. Thaks again.
  • Hotpoint Master
  • 1,525 Answers
Hello. if it don't turn then it could be the brushes on the motor also check the interlock on the door. any spin problems could be the module control board get back to me if you still have problems
regards
shaun
Posted on Jan 03, 2011
Testimonial: "Many thanks for the advice regarding my washing machine. The brushes have now been replaced and the washing machine is once again working."
  • shaun taylor Jan 08, 2011
    glad to help
    shaun
Machine worked fine to start with . Then stopped. Will fill water but drum wont turn on a wash cycle. And wont spin on spin cycle.But Belt seems fine. Can you help.
The pump needs to be replaced. The pump controls the agitation for the wash cycle, also controls the tub for draining & spinning after the wash & rinse cycle. The belt has nothing to do with it. Pump is very simple to remove & replace, and not too expensive, it's plastic.
Jun 03, 2015 | Washing Machines
Hoover optima 614 drum wont spin
Either a broken drive belt or a failed transmission.
Jan 12, 2015 | Hoover Washing Machines
Kenmore topload washing machine that wont switch to drain
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
Then, see the Whirlpool / Kenmore Service Manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Normally, this would appear to be a Lid Switch or Neutral Drain problem BUT since it is re-filling , it sounds like a Timer problem.
See the Service Manual for how to test / replace the timer.
Apr 16, 2010 | Kenmore Washing Machines
Washer won't drain.
My washer fills up with water and goes thru the wash cycle but when it's time to drain, it just sits there and clicks.
Oct 17, 2009 | Tecnik TKL9260 Front Load Washer
Washing machine wont wash or spin, just fills and drains
THE MODEL NUMBER IS USUALLY FOUND SOMEWHERE AROUND THE OPENING OF THE TUB OR ON THE LID ITSELF
Apr 24, 2009 | Washing Machines
Washer won't spin and drain
Sounds like your drain poump is failing. It's spinning lighter loads but not able to take a full load. I woule definately replace the drain pump,
Feb 28, 2009 | Frigidaire Washing Machines
My whirlpool awz410 is not spinning
if its draining while its filling ,raise the drain hose higher than the water level and it wont syphon.
May 01, 2008 | Whirlpool AWZ410 Front Load Washer/Dryer
Zanussi washing machine wont spin
check the drain hole when you start the machine if the water is coming back out , if yes that means your dump valve is bad.
Apr 23, 2008 | Zanussi ZWF1430W Front Load Washer
Hotpoint WMA13 Front Load Washer Logo
182 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
