Question about ASUS P5PE-VM Motherboard
Dear All, When we start Deaktop come erorr "CPU overvoltage error" Press F1 We reinstall OS,remove Fan and pest Hit sniak,Change SMPS but same problem comeCPU overvoltage error" please give soluation
    Sergeant:
  • 223 Answers
Hi yadav, i think you have tryed al, i am sure there is no problem with your CPU or SMPS , i think your motherboard got shortcircuited , just try this steps if nothing work mean you have to replace your Motherboard yadav.
step 1 - Try resetting your BIOS settings to default
step 2 - Do you have the AUTO Overclocking feature enabled? If so... DISABLE it.
step 3 - try a BIOS upgrade
Good luck ! if you think your problem solved don't forget to rate
Posted on Jan 03, 2011
How do I access the BIOS settings for the P5LP-LE motherboard. The startup key says to press F1, but pressing F1 does nothing.
The instructions say:
"Hold down the F1 key during the startup process and enter BIOS setup to re-enter/reset any custom BIOS settings." I would also try hitting the F1 key multiple times from the very turn on of the computer because the key may have to register at some point after turning on.
Try clearing the CMOS settings as explained on this page, it should clear out any passwords and will set the BIOS settings back to factory settings.
HP and Compaq Desktop PCs Motherboard Specifications P5LP LE Lithium
As for "The CPU fan runs normally on boot, but as soon as the Windows flash screen comes up, the CPU fan slows way down."
This is quite normal. On start-up the temperature of the CPU is not being read, when the flash screen comes up just happens to be the same time that the computer recognizes that the CPU is cold and doesn't need to be cooled.
On the "Then the installation program starts running and the CPU Fan speed starts fluctuating wildly from slow to extremely fast."
This could be normal as when files are read from a DVD the CPU doesn't work hard, but when it unpacks the files or does calculations it does work hard. Or it could be that the thermal paste between the CPU and the heat sink is not correct. Either dry , not making contact, or even too much. If the heat is not being transferred that would also explain the shut-down.
Nov 11, 2016 | Computers & Internet
Asus p6t se
harry up change cpu fan or" pemanent damage your cpu if fan is off.
May 30, 2012 | ASUS P6T SE - Motherboard - ATX - iX58 -...
CPU Fan Failure
ask the Dell support of directions, they will guide you.
Mar 27, 2012 | Dell Inspiron 620 ST Desktop Computer...
Error: "Intel CPU uCode Loading Error" - "Press F1
This could have been a RAM issue or a BIOS issue. Check your RAM first and reset your CMOS. If possible upgrade your BIOS version from the manufacturers website. but be very careful if you do so. a wrong move may spoil your Board completely.
Sep 18, 2011 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
My lenovo thinkcentre desktop computer never shows "press any key" while I try to format. Unable format my C drive and recently 500 GB HDD was installed in my computer. pl.advise how to format...
Hi! Welcome to www.fixya.com.
Removed your power cable and drain power without any power. restart and keep on hitting f12 to get to the boot menu choose ODD then put the OS CD then press enter until its say press any key. If it did not work your other option is reboot and hit f1 or f2 to change the boot sequence on boot option. Restart pc then hit f2 go to boot option and choose DVD/CD to be your first boot option then press f10 restart and it should load automatically.
Hope this resolution fix the problem on your computer. Thanks for contacting Fixya. Bye for now.
Jul 20, 2011 | Computers & Internet
System configuration data updated ERROR,--Need a solution I have a fairly new Gateway M-1625 laptop running windows vista 32 bit, sp1. I turned it on and beeped twice (beep, beep) and gave me an...
Got a backup?
If not, download a Linux Live CD. Boot your machine with it, save all your data to an external drive and then do a complete disk format and re-install. That will be quicker in the long run.
Not sure about that PC, but on Dell, for example, you hit CTRL-F10 (I think) at power-on and it gives you the option of reinstalling the OS from the recovery partition (wiping any unbacked-up data in the process).,,Gateway is probably similar.
The Boot/BCD issue means your 'Boot Configuration Data' is hosed.
Jun 07, 2011 | Computers & Internet
When I start my computer, I'll get a black screen with a bunch of text with "American Megatrends" as the header. The screen is unusual, and on the bottom it says "CPU fan error!, press F1 to...
You need to plug in your CPU fan. The CPU fan is VERY important in that it constantly cools your processor, making sure your computer doesn't over heat. If the computer runs and the fan isn't running, the CPU will over heat and cost you hundreds of dollars.
Turn off the power Unplug your computer Open up the case of your computer Find your CPU fan Find the cord coming from it Find the plug on your motherboard labeled CPU fan Plug it in there Plug your computer back in Turn it on
Mar 17, 2011 | iBuyPower Gamer Extreme 573D3 Phenom II X4...
Fails to boot, fans and lights on, no bios or anything
My recommendations would be to remove all connections to the board.
Remove the CMOS battery.
Remove the CPU fan and CPU.
Look at the top of the CPU, if you have a crust over the top of the CPU, you will need to remove it to a clean surface.
Next, your CPU fan should be a 3 wire connection on the motherboard, within two inchs of the CPU holder.
After cleaning the CPU, re-inseart and apply a heat sink lub for good heat transfer.
Re-install CPU fan and plug in to board connection.
Re-install your CMOS battery and power up unit.
With the CMOS battery removed, the time and date will need to be reset.
Also, in the BIOS for that board, you should be able to see temps. and rpm readings. ??
Hope the CPU has not taken a dump on you.!
Before you plug in the drives and other devices, check temps. rpm and voltages.
Have fun, hope this has helped you.
Oct 06, 2009 | ASUS P5GD1-VM Motherboard
I need help
first off check the CPU fan operation then check the heat sink is clean and has no dust in the vanes etc.
otherwise go into bios and you will have to go to the page that controls CPU and check settings are for your CPU and not overclock settings
Jul 29, 2008 | ASUS P4P800 SE (890552603657) Motherboard
ASUS P5PE-VM Motherboard Logo
79 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
