Can't access admin page of my Linksys router, WRT54GS. I have its IP address (192.168.1.100), but do not remember my username I used when I received my password back in 2008. I WANT TO CHANGE THE SECURITY SETTINGS to "WPA2 Personal" and select the algorithm "TKIP+AES". Finally, enter my password into the "Shared Key" field and save my changes. (I obtained the above procedure from a google search for a method to update my router to a more secure format.) I believe I am now ready to implement this process since I have just downloaded Window's WPA2 hotfix. Before accessing the admin page referred to above, I will also update my wireless card driver. PLEASE ADVISE. Thanks.
  • DubbleA Jan 06, 2011
    Thank you for your solution. It looks like it would work but I am delaying trying it out now because there are two other pcs networked to my router, and I have been asked by their users to not do anything that might interrupt a project they are working on. I will try it later. Thanks!
    Genius:
  • 1,098 Answers
Welcome to Fixya.
Based on your post, you can't access the admin page because you do not remember the username anymore. If you don't remember the username anymore, you just have to reset the router. Locate a small button or small hole on the router. Using an unfolded paper clip, press for about 10 seconds or until the light stops blinking.
Doing the above will reset the router to it's factory settings. The default username is admin.
Hope this helps!
Posted on Jan 03, 2011
I just received a new modem from my cable company and now my router doesn't work. I tried resetting it and it still doesn't work. What do I do next
Reset your router back to it's factory settings by holding the reset button for about 5 seconds. I have provided a list of the most popular router brands. If it does not work you may need to google what your specific model's default IP address/default username/default passwords are, for example search for "Encore ENHWI-2AN3 default IP address" The default login info can change, it can depend on where you obtained your router. If you purchased it yourself from a store then the standard defaults should work. If you obtained your router from your Internet Provider you may need to contact your service provider. It also may depend whether it's an old or new model router as well. And you may need to press and hold the reset button on your router several times before it actually clears. Make sure you have a wired connection then once you have accessed your router simply run the Setup Wizard. Set your SSID as something you'll remember like "Mavericks Network" and your Password can be something like your phone number for example 3109876543
Belkin - Username: Leave the field blank Password: Leave the field blank Default IP address is: 192.168.2.1
Buffalo - Username: root Password: Leave the field blank Default IP address is: 192.168.11.1
D-Link - Username: admin Password: Leave the field blank Default IP address is: 192.168.0.1
Encore - Username: admin Password: admin Default IP address 192.168.1.1
Linksys - Username: admin Password: admin Default IP address 192.168.1.1
NetGear - Username: admin Password: password Default IP address will be: 192.168.0.1 or 192.168.1.1
TP-Link - Username: admin Password: admin Default IP address 192.168.1.1
TrendNet - Username: admin Password: admin Default IP address 192.168.10.1
Zhone - Username: admin Password: admin Default IP address 192.168.1.1
Zyxel - Username: admin Password: 1234 Default IP address 192.168.10.1
Sep 07, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
After trying to connect my mac laptop to ethernet suddenlink had a failure at the same time. NOWI CAN NOT OPEN THE ROUTER OOR ANYTHING. jim FOUTTY
Sep 07, 2011 | Linksys WRT160N Wireless Router
Wanted to set password om my linksys
192.168.2.1
192.168.1.1
Sep 07, 2011 | Computers & Internet
How to secure router with password
access the router by typing its default IP address on your URL browser.
IP Address depends on router brand:
LinkSys 192.168.1.1
DLink 192.168.0.1
username and password for Linksys is admin
Dlink has admin username but no password
then browse the administration page to setup password
May 28, 2011 | Computers & Internet
I am having url 192.168.1.1 and other combos fail for Linksys wrt54gs. I am online with the Linksys but want to access and have a secure line rather than unsecured line. It is connected to our desktop...
To access the router setup, open an IE browser, on the address line: http://192.168.1.1 then press enter, you should be prompted for a username and password, leave the username blank, password is: admin, this should give you access to the router.
http://en.wikipedia.org/wiki/Linksys_WRT54G_series#Default_settings
if for some reason that doesn't work, start, run, cmd, enter, this will open a command window and type the command IPCONFIG /ALL look up the default Gateway IP address and see if it is different. If the gateway is a different IP address, try that IP address
Mar 02, 2010 | NetGear RangeMax WPN824 Router
I have a netgear ds116 hub and i want to set up a linksys router
Here's what you can do. Don't connect the Linksys router yet to the hub. Connect 1 computer directly to the Linksys router. Access the router's setup page of the Linksys router thru http://192.168.1.1
It will prompt you for username and password. No username and password is admin.
Look for Local IP Address or LAN IP Address. Change the LAN or Local IP Address of the Linksys router to 192.168.5.1 then click on Save Settings at the bottom. Right after saving the settings, unplug the power of the Linksys router, connect it to the hub and it should be good to go.
Oct 06, 2009 | Linksys Wireless-G WRT54GS Router...
Setup install complete still can't access router
you need to access the router via the web page ie using internet explorer or firefox and using the ip address of either 192.168.0.1 or 192.168.1.1 and it will prompt you for a username and password
by default i think its username - admin with no password or visa versa no username and password is admin
Apr 20, 2009 | Linksys Wireless-G WRT54GS Router...
Have linksys wrt54gs & have trouble accessing password
Hold the reset button on the router for about 30 seconds. This will reset it to the factory defaults. Both the ID and PW will be admin
Mar 02, 2009 | Linksys Wireless-G Broadband Router
I have a new computer laptop and need to connect to my router WRT54GS Ser # CGN10D815901 and can't get on the internet. I think I just need my scurity key. I am WEP security code, correct? I had the piece...
  1. Access the router's setup page using a computer that is wired or physically connected to the router.
  2. To access router's setup page, launch IE and on the address field type 192.168.1.1 (which is the default IP address of Linksys routers). Then, it will ask for a username and password. By default, there is no username. The password is admin.
  3. Once you're in the Linksys setup, go to WIRELESS tab. There is a subtab called Wireless Security.
  4. Click on wireless security tab and you will find there the security key or wep key that is enabled in your router.
Hope this helps!
Nov 10, 2008 | Computers & Internet
Linksys wrt54gs router and Xbox live
make sure that internet connection working fine first..if it is connect you xbox via wired or wireless(if wireless, make sure that you connect to your own wireless network and enter the wireless security if there is)...check if you can get an ip address, better set to obtain the ip address and dns of your xbox, if all set and still unable to access internet, access the linksys router setup page by typing 192.168.1.1 on the address bar of your internet explorer, when pop-up for username and password type admin under password, leave it empty for the username. Click administration tab and disabled UPnP. Check if your X-BOX working fine. Hope this help you.
Sep 29, 2008 | Linksys Wireless-G WRT54GS Router...
Computers & Internet Logo
70 people viewed this question
David Payne
David Payne
