I have a Siemens E14-48 washing machine and it has come up with an error code F21 and will now not do anything thanks richard
Am havin d same problem how do I fix it
Sharon
Posted on Aug 07, 2011
I want to know how can i cleare the erro f21 about siemens washing mechine.
Error f21 happens when the machine does not drain in an appropriate time. This can be caused by a blockage in the drain or a faulty pump. There is a previous post in relation to resetting this error. have siemens washing machine that says f21 what does that mean
Jan 14, 2017 | Siemens Washing Machines
Siemens washing machine display F21 flashing. Fault is not resetting after power off.vario perfect iq 300.
Try this, unplug it and press and hold down the power button for 10 seconds and then plug it back in and see if the error code has cleared.
Aug 28, 2016 | Siemens Washing Machines
I have a siemens washing machine that says f21 what does that mean
Many thanks. For F21 fault everyone was talking about the drain valve but found one answer related to power supply n board this helped. Resetting by turning program switch to 12 o clock then turn to 6 o click then keep spin button pressed n move knob to 7 o clock position. Then release spin n move knob to 12 o clock. This way F21 got resetted.
Aug 31, 2011 | Washing Machines
What does error code f67 on a siemens wash machine mean?
I have a Siemens WM16S772DN washing machine and encountered the error code "F:67" followed by repeated beeps. (Note: Siemens and Bosch are related companies). I called Siemens and they said the code means "Fatal error" or program error. The service technician was called, and he replaced the electronic board and reprogrammed it.
Apr 18, 2011 | Bosch Washing Machines
It is FO 2 its happpend twice no papper work for it?
Hello there and thank you for choosing fixya
Depending upon the type of washing machine, you may notice an "F21" or "F02" error code. An "F21" or "F02" error code is indicative of a slow draining cycle, normally caused by a clogged or kinked drain hose. If an "F21" or "F02" error code appears, check the drain hose on the back of your washer to ensure that it is not clogged or bent. Once the drain hose has been unblocked, the error code should disappear and the machine drain properly. However, if you have a high efficiency washing machine and the error code continues to appear, make sure you are using the correct detergent; because high efficiency machines use much less water than traditional washing machines, they require the use of a low sudsing detergent. Traditional detergents may produce too many suds, which can block the machine's drain hose and lead to slower draining cycles.
Please feel free to post me a comment back if you need help with the dissasembly of this ok?
best regards Mike
Mar 28, 2011 | Washing Machines
Siemens washing machine - Error code F37 Thanks
Siemens washing machine - Error code.f16
Dec 07, 2010 | Siemens Washing Machines
Bosch Exxcel Washer F21 error code
got a bosch washing manchine it keeps coming up f21 error and i have no book 2 see wot it is can you help me by tellin me wot it is thanks
Apr 11, 2008 | Bosch Washing Machines
Washing Machines Logo
1,297 people viewed this question
Top Washing Machines Experts
