When the unit is turned on it only stays on for a few seconds & then shuts down & turns off. No book left with unit when purchased the house so not sure of symbols on remote. (If needs to be reset). your advice muchly appreciated.
  • 2,133 Answers
Your statement without error code mention, And hence, there are 2 reasons. Rotate blower motor manually. if rotate, replace your indoor sensor. If hard to rotate, problem with motor mechanism -locked. Replace bearings or motor.
Posted on Jan 03, 2011
Onyko tx nr616 receiver keeps shutting off. Only stays on for approximately 3 seconds. Can you help?
The amp protection circuit has been activated. Remove the power cord from the wall outlet immediately. Disconnect all speaker cables and input sources, and leave the AV receiver with its power cord disconnected for 1 hour. After that, reconnect the power cord and reconnect an input and a pair of speaker wires onto the unit. If the receiver still does not turn on than you will have to bring it in for service. Turn up the volume and if the receiver doesn't shut down, power off the receiver and add another pair of speakers. Power up the unit again and turn up the volume. If it doesn't shut down, power off the unit again. Now connect all your input sources and turn on your receiver. If the unit shuts down again, your unit will need to be further serviced at an authorized Onkyo service center.
Sep 30, 2014 | Onkyo Tx-nr616 7.2 Thx Certified Network...
Samsung UN46ES6500FXZA turns off by itself
I can not acces my Facebook deos not recognize or mail or password,how I can restart t.v to install and to atarte again please help me , thank you
Feb 10, 2014 | Samsung UN46ES6500 - 46" 3D LED-backlit...
My 2005 equinox cooling fans come on for a few seconds &shut off making engine over heat &OVERHEATING What is the problem?
Should be a relay somewhere in the engine compartment - may be failing. You may be able to switch with another relay to diagnose.
Check your owners manual under fuses and relays.
Jun 23, 2012 | 2005 Chevrolet Equinox
Our dehumidifier turns on for only a few seconds, then shuts off.
Wendy, it's probably because the humidity level on the unit is set higher than the humidity level in the house. Keep in mind, the humidity level you set the control to, is not the amount extracted from the air. It's the level you want it to maintain. The higher the percentage level, the more humidity stays in the house. The lower the percentage level, the more humidity it removes, until the lower humidity level is reached. Then the humidifier will automatically shut OFF and/or the unit shuts OFF, because the bucket is full. Once it's emptied and replaced, if the unit needs to continue to extract humidity, it will start running again.
Hope this helped you solve the problem. Please let me know. Thanks.
May 04, 2011 | Maytag M7DH45B2A Dehumidifier
I have a pioneer avic-f900bt and it keep turning off. it powers up for a couple of seconds and then it shuts off what could that be please help me.
I appear to have the same issue with mine. I purchased mine from Audio Itch in Tampa, Fl in December of 2008 and had them install it with an amp and speakers. Worked fine for almost exactly a year. Upon starting up my car, it powered up and gave the system powering up notice, then went blank. Rebooting with the small restart pinhole button sometimes works, but most of the time it will start powering up again, then shut off????
Mar 07, 2010 | Pioneer AVIC-F900BT Car GPS Receiver
My Insignia converter shuts off after few seconds
Try power-cycling the unit to reset it (turn it off and unplug for several minutes). Also, remove the batteries from the remote control and push all of its buttons, then install a fresh battery. If these steps don't resolve the issue, you may return with the unit to the place of purchase to pursue service options.
Jan 15, 2010 | Insignia Digital-to-Analog Converter for...
Every time i turn it on it will stay on for a few seconds and then the red light on it turns on
these amps are junk you can et one twice as good for a better price. they all shut down when giving power sooner than later.
Jun 10, 2009 | Hifonics BXI2008D Car Amp
Dvd/vcr
well sounds like one of the players is not in correct spot thus shuts down (kinda timing issue) see if there is anything preventing it from going jiggle or turn upside down see if you hear anything.
Feb 12, 2008 | Philips Magnavox DVD/VCR Dual Player
Receiver shuts down after loud bang
You said Unit is enclosed!! Does that mean it is inside something? Receivers & Amps need to have a clearance above them so air can circulate, otherwise you'll have an overheating problem. You also might have some of your wires crossed which will cause the Amp to shut down. Look at all your connections and make sure they're correct, including speaker wires.
Sep 22, 2007 | Audio Players & Recorders
Heating & Cooling Logo
47 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
