Question about Intel DG31PR Motherboard
My system worked properly for last 10 months. but before couple of day system is shout down instantly, i tried to start it again, but after the bios screen shutdown again & again................ after that, this was happened repeatedly......but there is no any common pattern in this fault..........sometimes its happened after 30 min , sometimes system works properly for 2 hours and then shutdown automatically..........only common thing is, after the fault occurred it cannot be restarted instantly.............. so to troubleshoot, i replace memory, power supply with known good one but cant resolve... there is no slow down or struck, even considerable heat in processor heat zinc.......so i decided that there is no overheat problem.............. i tested system without my hard disk that include my OS. but system shut down without prompt me to install OS or message like "operating system not found"..........so i thout that there is no problem with my OS............. so i think fault on my mother board........pls help me to troubleshoot the fault. OS : windows 7 ultimate (activated and worked properly) virus : kaspersky Internet security 2010 ( does not any error messages & worked normally) processor : Intel core 2 duo 2.8 mother board : Intel dg31pr
    Problem Solver:
  • 17 Answers
Hi
maybe the time you install os you did not install properly, or you make an online windows update,
you need to check what application you installed last before you encounter that problem, if still appearing the problem got device manager and disable the "automatic shut down on system failure"
thats it
good luck
Posted on Jan 03, 2011
With using, the computer without reason/ warning got stuck and I forced turn off the computer; then, tried to turn on again. It was not Boot. The power on, but it is stuck in there, no Boot. Help!
A couple of things spring to mind, but difficult not having the machine.
Upgrade to Windows 10 is automatic and your machine is trying to update and finding a problem. I would not load Windows 10 until Service Pack 1 comes out.
Also sounds if the processor is overheating. When you boot up, you can get into the BIOS, often by tapping Delete, or F10. There is usually a prompt onscreen during boot up. One of the screens in the BIOS tells you the processor temperature. If it rises over 60' you have a problem with cooling. The computer has a fail safe feature to save the processor by shutting down.
Sep 02, 2015 | Gateway Desktop / Intel Core i3 Processor...
Dell inspiron 15 beeps 7 times
DELL BEEP CODES
Beep Codes Beep Code Description Failure Coverage 1 System Board: BIOS ROM failure System Board, covers BIOS corruption or ROM error 2 Memory No Memory / RAM detected 3 Chipset Error (North and South Bridge Chipset DMA/IMR/ Timer Error for Intel platform); Chipset Error System Board Chipset Failure Time-Of-Day Clock test failure. Gate A20 failure Super I/O chip failure Keyboard controller test failure. 4 RAM Read/Write failure Memory failure 5 RTC Power Fail. CMOS battery failure 6 Video BIOS Test Failure Video card / chip failure 7 CPU Cache Test Failure CPU failure 8 LCD LCD failure
Oct 23, 2012 | Dell Inspiron 15 Laptop Computer- Intel...
New HP Mini w/ Windows XP ''Remote Procedure Call'' Shuts down
Hello.
This may not be the answer you are looking for, but in my opinion, if you are experiencing system problems after a couple of days, I'd advise you to return the mini for a new one. If the supplier doesn't have a 30-day return policy, then contact HP.
Hope this helps.
Dec 17, 2009 | HP Mini 1000 Netbook
Network adapter stop working
If u r facing frequent problems with the network adaptor change it and make sure u have the drivers for that as well. If required reinstall the os, that will solve ur prb.
Jun 23, 2009 | Computers & Internet
My Compaq Presario F700's Wi-Fi stopped working
can you check if the driver is properly installed?
- go to start, point to computer, right click then click manage, click device manager and see whether you have an exclamation mark or "X" sign on one of your devices. if yes, you need to un-install first the driver, restart machine, re-install the driver properly.
May 28, 2009 | HP Compaq Presario V6000T Notebook PC
Boot up ishue
From the sound of it, the PSU is going. The long cool down time would indicate to me that is a rather large component that is not exposed to very much airflow. To help isolate this, you might want to try running the system with the cover off. If the problem stays about the same, I'd say it's the PSU. Check all the fans while you're at it.
Jan 23, 2009 | ASUS P4SP-MX Motherboard
Monitor won't turn on -- flashes on then off again
This is probably a RAM memory trouble, you have to try with 2 ways: 1) Try with another RAM memory to start your pc, 2) Verify the memory using a DOS software to check it.
Also, you could reset the BIOS using the jumper settings established on the PC Motherboard Manual to try if the BIOS is fail, or update the PC BIOS.
At last, You must check the temperature generated on the devices, if it's warm it means that the Hardware needs to add more fan coolers, or deactivate Overclocking. The overheat cause this fail too.
Click on this site to setup Bios or Cmos :
http://www.computerhope.com/issues/chooo192.htm
Or can try in safe mode
Best of Luck ! Please dont for get to Vote.Thank You.
Dec 11, 2007 | Sceptre DCL 7A 17" Flat Panel LCD Monitor
Intel DG31PR Motherboard Logo
95 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
