Question about Pioneer Audio Players & Recorders
My pioneer AV reciever last shows in the display a "amplifier error" then suddenly the power shut-off. aftr that i power on again but the reciever do not power on again. I remove all the connected speakers and try to put on but it still doesnt work? whats the trouble?
  • 2,098 Answers
The real problem is already informed you by the unit itself.
For us technician it was obvious that you have a faulty output I.C.
Your unit automatically shuts off to avoid further damaged most especially to the speakers.
I've advice you to look for a qualified technician/service center to replaced the output I.C.
After that your unit will back to normal again........
Posted on Jan 03, 2011
Pioneer vsx 515 overload and shuts down what can i do to fix this problem.
hi,
First of all remove all the speaker connections from the amplifier. After that power the amplifier and check the overload (protect) show or not . if not, then any of the speaker is damaged or you have to check the impedence of your receiver and speakers. It will be written on the rear side of both receiver and speakers in ohms. PIONEER recommend to connect 8 ohms speakers in to this AV receiver. If you are using 6 ohms speakers you have to do some setting in the AV receiver.For that do the following
1. With the receiver in standby, press STANDBY/ON while holding down the SPEAKER IMPEDANCE button.( Each time you do this, you switch between the impedance settings: )
SP 6 OHM - Use this setting if your speakers are rated at 6 Ohms
SP 8 OHM - Use this setting if your speakers are rated at 8 Ohms or more
You are not able to connect speakers with impedence bellow 6 Ohms with this receiver. Becuse the AV receivers impedence range is 6 - 16 Ohms.
If then also it shows protect you have to check the amplifiers hardware.
AV receivers shows protect mode , when there is a hardware fault in side it. Its a warning that some thing is wrong.
Normally AV receivers show this when any of the output amplifier get some problem. there are six amplifiers in this AV receiver. May occur when the output diver transistors of any of the amplifier become shorted. if the output transistor get shorted this will lead to flow of current through the speakers. To prevent this there is a protection circuit for each channels. One combined output of this protection circuit is connected to the system control. when the any of the output amplifier fails, the protection circuit detects it and switch of the speaker and sent data to the system control. when the system control get this data it will give a warning to the customer through display that PROTECT.
You have to check the amplifier.
for that you need digital multimeter,soledring iron screwdrivers etc
open the amplifier , then power it on. connect the negative terminal of the multimeter any where in the chase( metal body of the amplifer). then connect the positive terminal to all the output transistors emitter pin one by one . the voltage should be bellow 0.5V. If any of the emitter of the transistor shows voltage more than 0.5V., then that amplifier stage is faulty. Remove the transistors and check it. if it is shot then replace with a new one.
after replacing the transistors do not power up the amplifier directly from the main. You have to put a bulb of 60 watts in serial.
You can do this easily remove the mains fuse. put the bulb in a holder. now you have to wire from the holder. connect one of it to the one end of the fuse holder and the other wire to the other end of the fuse holder. Why using a bulb is, if there is any further problem in the amplifier stage on which the transistors replaced, there is a possibility of the new transistor get damage. if we use a bulb in serial with its mains supply ,when any overload in the amplifier occur the bulb will drop the current, by lighting itself.
After connecting the bulb in serious power on the amplifier. watch the bulb. It should light for one or two second and go dim . if so check the display, is there is protect mode is on or not . if not and come back to normal operation ,then remove the power , remove the bulb insert fuse and check
connect the power and check.
If the bulb shows bright light then there is some component also faulty in the same amplifier. after removing the power you have to check again the amplifier stage of which the transistor is replaced, for any other faulty components.
ok
Jul 27, 2011 | Pioneer VSX-515 Receiver
My reciever keep saying protect and i cant hear nothing
hi,
First of all remove all the speaker connections from the amplifier. After that power the amplifier and check the protect show or not . if not, then any of the speaker is damaged. If then also it shows protect you have to check the amplifiers hardware.
Normally AV receivers show this when any of the output amplifier have some problem. there are six amplifiers in this AV receiver. May occur when the output diver transistors of any of the amplifier become shorted. if the output transistor get shorted this will lead to flow of current through the speakers. To prevent this there is a protection circuit for each channels. One combined output of this protection circuit is connected to the system control. when the any of the output amplifier fails, the protection circuit detects it and switch of the speaker and sent data to the system control. when the system control get this data it will give a warning to the customer through display that PROTECT.
For that you need digital multimeter,soledring iron screwdrivers etc
Open the amplifier , then power it on. connect the negative terminal of the multimeter any where in the chase( metal body of the amplifer). then connect the positive terminal to all the output transistors emitter pin one by one . the voltage should be bellow 0.5V. If any of the emitter of the transistor shows voltage more than 0.5V., then that amplifier stage is faulty. Remove the transistors and check it. if it is shot then replace with a new one.
ok
May 19, 2011 | Sony STR-DE598 Receiver
My Pioneer Elite VSX-53TX volume quit in the middle of a video. the read out on the unit says - - muting - - and no, we did not push the mute button. do you have any idea how to get the volume back
hi,
ok
Mar 23, 2011 | Pioneer VSX-53TX Receiver
My sub woofer wont work? the stereo turn on then it shuts back off.
hi,
ok
Mar 08, 2011 | Pioneer SX-315
Display shows overload and receiver shuts down
This means that one (or maybe more) of the amplifiers is shorted. Remove all speakers cables and try again. If you get the same message that means that one (or more) amplifiers is fried. To find which and why you will have to open the unit and test the amplifiers.
Jul 31, 2010 | Pioneer VSX-D412 Receiver
I have a Pioneer GM-X862 when i have it
make sure you do not have the ground and power crossed or touching if that dont work then you have ground problems hope that helps if not your amp is at fault(replace it)
Nov 03, 2009 | Pioneer GM-X862 Car Audio Amplifier
Power will not stay on
Activated protection circuitry means that the amplifier is seeing conditions it does not like and is shutting down the power to prevent further damage.
Either you have a short in your speaker wires, in your speakers, or a blown amplifier.
Disconnect both speakers and turn on the amplifier. Does it still give the error message? If it does, your amp is blown. If it does not, carefully inspect your speaker wires and their connection. Make sure all looks good and reconnect the speakers and try it again. Still get the error message? You likely have a problem in your speaker cabinet(s).
Apr 21, 2009 | Onkyo HTR500 Receiver
AV Receiver pioneer vsx D914 does not turn on
See now what happen to me just last night actually was I was listening to music and had the receiver turned up to about -55. all of a sudden, it showed me AMP ERROR and shut off all on it's own and would not turn on.... I later was snooping around my wiring and fount two wires were touching. I have had the receiver unplugged since the incedent last night and I am going to try to get it working when I get home from work.. I know that it is a beautiful sound system and its sound quality is just amazing. It's definately the best system I have owned and I really hope that leaving it off for 24 hours will reset it and make it work again. I don't really have the money to go out and buy a new one.. nor do I really want to... If you have any luck you can let me know! Thanks!
Nov 27, 2008 | Pioneer VSX-D914 Receiver
110 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
