Question about JVC RX-7000V Receiver
Because my rear speakers are popping and crackling during DTS output, I believe my settings of bass or treble might be overloading my speakers... should I set the rear speakers to "flat"? should I do that to all my speakers? will they still be discrete channels for DTS? What levels should I put for bass and treble if I were to put as "flat"? should i also turn off bassboost? I am kind of scared to hear those cracks and pops because they are loud, despite my volume to be either high or super low.... thanks again!!
    Brigadier General:
  • 8,546 Answers
Cracks and pops are dangerous. Can you tell if they might be circuit overloads or maybe digital decoding errors?
Are you routing bass to small speakers. THAT would definitely have audible problems. Define all of your speakers Large vs Small based on their bass-handling capacity.
ONLY DTS? Probably NOT the speakers or amps. How many sources are involved? Could be with the source or cabling.
Does it happen at low volumes, too? Then it would probably be digital in origin.
Do the indicators various digital surround mode indicators flicker or turn off when the pops appear?
As for the rest of your questions, I'd set everything at flat and start all over. If you're maxxing out any settings, something is wrong.
Posted on Jan 04, 2011
  • big_alx Jan 04, 2011
    Hi Dunnbiker!! Thanks for your feedback!!
    So far, it is only happening to the rear speakers, and it only happens during DTS/Dolby selection even at very low volumes, even with only at volume level 1 or 2... it doesn't happen with analog surround sound... so far i did set to all my speakers as "SMALL", and the wires weren't changed at all... before I used a pioneer that supports AC3 Dolby only, but not DTS... i am pretty sure the pops and cracks are not from the movie, since I also tried Hurt Locker and at the beginning, when there was explosion, i heard a pop even at volume level 1, so i turned off the volume right away!! wow, very nervous to even try out the sounds... i am only using an ASUS O-Play media player, and using optical cable to the receiver. When you mean setting everything at flat, does it mean putting the bass/treble all at 0 db?
    Please let me know... thank you once again!!
  • David Dunn
    David Dunn Jan 04, 2011
    Yes, set anything that boosts bass to nominal. You might be able to leave this part alone for now.
    So it would seem the decoding is the problem.
    http://www.retrevo.com/support/JVC-RX-70...
    You didn't answer these questions:
    Do the indicators various digital surround mode indicators flicker or turn off when the pops appear? (page 16)
    Selecting DTS manually instead of allowing the unit to automatically detect the format may be a problem. (Page 16)
    Take a look at the procedure starting on the upper right of Page 25.
Can't get balance, bass and treble to work when connecting Bose Acoustimass 5II to HK AVR 525
On my yamaha 375 receiver if I connect digital or hdmi it disables the balance/bass treble etc but they work with anolog don't know if yours might be the same just abit strang if anolog doing it aswell
Jan 15, 2014 | Harmon Kardon Harman Kardon Avr 525 7.1...
Crackling from bass combo when I hit low notes
I'm afraid it sounds as though the speaker has been overloaded. The replacement for this will, unfortunately, be a new driver (the speaker unit itself).
Dec 10, 2013 | GK Hair Gallien Krueger MB115 Bass Combo...
Bass treble adjustments
I have the Toshiba Satellite C55-A5300.
I'm not sure about before the update, but after the windows 8.1 update my audio was pretty bad and had no bass at all.
In Control Panel ---> Hardware and Sound I found "Realtek HD Audio Manager" which has a tab named "DTS"
Once I hit the Launch buton I was able to apply settings for headphones and external speakers including bass boost.
My audio is now much better.
Hope this helps.
Aug 24, 2013 | Toshiba Satellite Computers & Internet
How do i find out what sound card my p.c is using? i'm on windows vista, and need to change the bass and treble level ?
Most laptop sound card do not have a setting for bass and treble.
You can use external powered speakers that have bass and treble settings and connect these speakers to the headphone socket on your laptop.
Jun 26, 2012 | Computers & Internet
Does the alpine 9845rb have a clock display?
yes it does see below
  • CD receiver with built-in amplifier (16 watts RMS/45 peak x 4 channels)
  • detachable face with Quick Search button
  • plays audio CDs, CD-Rs, and CD-RWs including discs burned with MP3 and WMA files
  • Bass Engine (bass center frequency, width, and level, plus treble center frequency and level adjustments)
  • BBE sound processing
  • two sets of preamp outputs
  • rear-panel minijack auxiliary input
  • clock
  • CEA-2006 compliant
  • CD frequency response 5-20,000 Hz
  • CD signal-to-noise ratio 105 dB
  • FM sensitivity 9.3 dBf
  • warranty: 1 year
Jun 02, 2011 | Car Audio & Video
I have set up a BOSE Accustimass System with my STR de485 receiver. How do I adjust the treble/bass?
hi,
if u are using bose speaker system then remember one thing. go to speaker setup and select all the speakers as large not small. then only u will get a good tone. bose speakers will handle the output power of ur amplifier.
u can only adjust the bass and treble of ur frond Channel speakers. for that
select multi channel surround sound and the increase and decrease the bass and treble
ok
Dec 31, 2010 | Sony STR-DE485 Receiver
Bass problems
At the audio mixer settings choose playback and look for something like "for advanced users" or like that. Here you will find the BASS - TREBLE control. In some older audio cards there isn't any selection like that.
Stelios.
Feb 20, 2010 | Inland ProSound 2000 Computer Speakers
HOW TO ADJ. REAR SPEAKERS AND BASS,TREBLE , ECT. THANK YOU
the option will be available on your remote... tell me the product name and model..
May 09, 2009 | Audio Players & Recorders
Low treble
I suspect that the speaker levels need to be set. You connected everything right - many people would not have connected the sats via the bass section (which has their high pass crossover and overload protection). But I am betting the HSU is turned up a bit on the high side.
Try this. Set all speakers to small, set all levels to 0. Play the receiver in stereo all mode. If the bass is strong, you need to turn the HSU down closer to a natural sound. Then use the speaker setup tone and adjust as needed.
May 14, 2008 | Onkyo TX-SR304 Receiver
Logitech r-20 speakers
Hi again andrew63,
There are two possible methods of adjusting the bass and treble output to your Logitech R20 speakers:
1. Hardware - if you feel like experimenting or working with electronic gadgets, you can connect an external preamp with tone control or graphic equalizer between the PC and the input of the speakers/amp; and/or (probably the easiest)
2. Use a software (to listen to your music files/medium) that has a virtual equalizer such the old MusicMatch Jukebox or as an add-on/plug in.
Btw, thanks for asking me to be a Tech Buddy.
Jan 22, 2008 | Acer AL2016W 20" LCD Monitor
JVC RX-7000V Receiver Logo
228 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
