Question about Hisense Televison & Video
We have a HSL11929HDIP TV. It has a narrow (1-2mm) green vertical line about 300mm across from the left.
  • Bruce Wickes Jan 03, 2011
    Thank you, I will get a quote for repair.
  • Hisense Master
  • 11,800 Answers
This is a defect at the LCD panel itself - the columns of pixels corresponding to that line are not commanded properly because either the buffer circuit or the connection from it to the columns are faulty. The only thing you can try is to completely dismantle the tv and reseat all the connectors on the LCD panel. If this doesn't fix it then the defect internal. inside the panel. Because of that it's unfixable, the panel will have to be replaced.
Get a quote before replacing it, otherwise you will find out that it will be (almost surely) cheaper just to get a new tv.
Posted on Jan 03, 2011
Picture went black except for partial green and blue lines &2 thin red lines
Vertical scan section circuit fault. Check and replace damaged component/s at its vertical scan output section circuit. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 17, 2014 | RCA MM36100 36" TV
Screen issues
I think better to replace the set as all this sounds like a light engine failing.
Dec 08, 2012 | Televison & Video
I have evenly spaced, rows of two vertical green and red lines from top to bottom of my vizio plasma P50HDTV10A
Somehow when switching between the tv and the dvd my wife encountered the pink and green, thin, parallel, vertical lines on the screen. The picture was visible with the lines. I turned the tv off and on but the problem persisted. Unplugged tv for about two minutes and after plugging it back in and turning it on the vertical lines very gone and the picture was back to normal.
Jan 12, 2012 | Vizio P50HDTV10A 50 in. Plasma HDTV
Hello i have a black line runnig across my screen horizontally. Some times disapperar for a few seconds and tv is normal and then comes back. Some tines is black and some times l flashes in red, ...
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
HOPE THIS WILL HELPOUT IN SOLVING THE PROBLEM...
May 18, 2011 | Televison & Video
Vertical Green Lines across TV Screen with no picture
The capacitorson the FMT board have failed, which will cause that symptom. Is the menu screen clear when you hit menu?
Apr 27, 2009 | Mitsubishi WD-52525 52" Rear Projection...
A NARROW GREEN LINE HAS APPEARED VERTICALLY DOWN THE SCREEN OF MY PLASMA TV
Hi chrishelps,
Your problem is one of 2 things - either the driver board (normally named as one of the "C" boards) has failed for that sector of the panel or your panel is damaged. If the line goes COMPLETELY across, the plasma panel is bad and is no way to repair it short of replacement - they aren't disassemblable and wouldn't recommend doing so anyway...
Wish I had better news for ya',
Mark
Nov 14, 2008 | Panasonic Televison & Video
Problem with my insignia tube tv!!!!
if that look like horizontal line shuld be vertical problem. check vertical ic around it of resistor& capacitor. good luck!
May 26, 2008 | Insignia NS- 27" TV27 TV
One green vertical line in HDTV Vizio 42
Try changing the H/V position in the TV Set Up menu. You can adjust the horizontal and vertical position of the screen and move it enough that the green line disappears from the screen.
May 18, 2008 | Televison & Video
Televison & Video Logo
144 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Electro Med Services...
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
