Question about NEC (OP-220-62006) 1.35 GB Hard Drive
I want to connect this hard drive with other computer. What kind of cable shoud be use for data transfer?
  • 516 Answers
Much better if you buy a usb to sata adaptor, all you have to do is plug the usb adaptor from sata hard disk drive to usb port. It will detect as a removable drive and it is very easy to transfer file. It will serve as a external hard drive. Have a nice day!
Posted on Jan 03, 2011
Testimonial: "Thank you."
What is the connection plug from Fujitsu mht2080ah to computer?
You can install the hard drive into an USB hard drive adapter case.
Then you can connect it to the USB port on your computer. The computer will see this as an external storage device, then you can copy the files off this hard disk to your computer.
By inserting the hard drive into an USB hard drive adapter you can deleted unwanted files off the hard drive and use it for backups and data transfer from one computer to another computer.
Mar 31, 2013 | Fujitsu MHT2080AH 80 GB Hard Drive
Wd 1600 not working
Western Digital My Book hard drives use USB 3.0 and USB 2.0 speeds to transfer data from the hard drive to the computer and vice versa. When your My Book external hard drive is not performing properly or not turning on, you can troubleshoot the problem before sending the hard drive back to the manufacturer. Correctly powering up and installing the My Book are essential for transferring information and avoiding corruption.
Run your fingers up and down the power cable that connects to the back of the My Book hard drive and the wall outlet in your home. Feel for breaks or tears on the cable and replace the cable if needed. Check the pin on the back of the hard drive where the power cable meets the drive. Make sure the pin is straight and will make contact with the power cable properly. If the pin is bent, send the hard drive to Western Digital for repair. Plug a different device into the power outlet you are using to make sure it works properly. Use a device that you know powers on correctly. b> Slow Transfer Rates b> Open your computer's tower and check over the PCI adapter card that gives you the ability to achieve USB 3.0 speeds. Make sure that the adapter card is installed correctly per your manufacturer's installation manual. If the PCI adapter card is not installed correctly, you will not be able to transfer data in the 3.0 speed. Disconnect any other external hard drives connected to the system. When two hard drives are connected via USB, they share the transfer rate bandwidth and slow your transfer speeds down. Run a Windows Update to change the USB driver on your computer. Click "Start" then "All Programs" and then "Windows Update." Run the update and choose your correct USB 3.0 driver from the list. Click "Install" at the bottom to install the driver. Hope this helps.
Jan 05, 2013 | Western Digital My Book Essential Edition...
Won't connect to computer; turns on just fine, but computer doesn't even register it. have tried connecting it to 2 computers, with no success.
Sounds like the internal interface card in the hard drive has failed. Luckily if you can hear the hard drive power up then your data is salvagable.
You have a couple of choices:
If you have the item still under warranty then get it replaced and they should provide either a data recovery or replacement of the internal board.
If not then open up the casing and disconnect the drive from the internal power and data cables. Purchase a USB to hard drive cable, which will allow you to transfer the data to another PC, or purchase a replacement hard drive enclosure, which may not look as good as the one you have, but will be just as functional. Enclosures can be purchased from a computer store, Amazon, Ebay etc for very little money.
Mar 09, 2010 | Fantom Drives 120 GB Hard Drive
My laptop is broken and i want my data copy to my other pc
Maybe you need laptop drive enclosure? It can be powered by USB cable alone together with to and in data transfer.
Hope this helps.
Jan 18, 2010 | Hitachi HTS541612J9SA00 120 GB SATA Hard...
My fujitsu laptop recently had a new hard drive installed in it ,but i want to transfer the data i have on the old hard drive that was removed from laptop to my new hard drive. I bought the all in one...
The Coolmax adapter is an USB hard drive adapter that can connect various types hard drives to your computer. This is used for testing and and transferring data to and from hard drives connected to the computer via the computer's USB port.
This Coolmax USB hard disk adapter can connect a 2.5-, 3.5- and 5.25-inch IDE or SATA hard disk to a PC. The black adapter box connects the hard disk, while the secondary power plug/adapter powers the drive. In the case of smaller notebook or SATA disks, the power cable is plugged directly into the adapter (as opposed to straight into the IDE hard disk).
The red USB cable, meanwhile, can be used to power hard disks directly from the host PC's bus via another USB port.
Connect the hard drive to the adapter as detailed above, power up your computer and plug the Coolmax USB cable into the conputer's USB port. The computer will detect and see this as an external drive, most likely as a E drive (the next drive letter that is available). Click on this drive and open to open the folder/s where your data is stored then select the folder/s and/or data and copy them, then open the hard drive on the computer and paste the folder/s and/or files onto the new hard drive.
Sep 29, 2009 | Fujitsu Siemens Computers & Internet
Cannot find My Book when connected to my computer, but on 'Uninstall Hardware', it knows it's there and says there's no problems with it.. Blue light on the drive itself lights up and a click is...
Possibly not. External disks due to very high data transfer rates suffer all kinds of problems when the USB cable is either too long or unscreened. Use a short screened cable and see if that makes a difference. If it Firewire any FW cable should be ok
Aug 11, 2009 | Western Digital My Book Essential Edition...
Hard Drive switching
You have to check the physical dimensions first, as most of the spares are tailor made for a particular model and cannot be used for other models. The easier way to transfer data would be to connect a data cable or network cable, create a network between both the PCs and transfer the data.
Jan 27, 2009 | Acer Aspire 5100 Notebook
Transfer old hard drive to new computer
saharris
yes, u can attached this drive with ur new pc and transfer data. u also can use with it. if ur drive with PATA interface when u connect in same cable with other PATA drive u must configur one is master and other slave.
Jul 10, 2008 | Computers & Internet
My computer died, but
the easy way to recover your data is to take out your hard drive and connect it as a secondary drive in any other computer, then you can get back all the data. if this is not possible you can use many data recovery tools like Norton ghost, for your help. .
For Good Data Recovery Tools http://www.datadoctor.in/
Mar 20, 2008 | Computers & Internet
Computers & Internet Logo
90 people viewed this question
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
