Question about Kenwood KDC-MP228 CD Player
I have KENWOOD KDC-W241 and i have done protect. How can i fix it?
SOURCE: protect mode
Press reset button (small circular button need something with a point) to the left of the 1 channel
Posted on Feb 28, 2009
smarthome2
  • 1114 Answers
SOURCE: kenwood kdc-438u stuck in protect mode what do i
Disconnect all speaker wires at the receiver and turn it back on. If it does not go into protection, your receiver is ok. Re connect speakers one at a time and test until your receiver goes into protection, then trace the speaker wire to the speaker for cuts or shorts. If you have a multimeter, switch it to ohms and check the speaker for a dead short, you may have a blown speaker. Hope this helps.
Posted on Sep 27, 2009
SOURCE: how can i deactivate the protect that blinks in my
Disconnecting the terminal will take to much time.. In between the skip button ,and the #1 on your stereo there is a little dot. Barely noticable unless you know what your looking for, take a safety pin or a screw( anything with a little tip) and push it in. This will restart your stereo. (Car Must be on)
Posted on Feb 12, 2010
  • 6 Answers
SOURCE: how can i remove protect mode on my kenwood
find the lil hole in front of the face use a paper clip to reset it if it keeps on doing it you got a speaker going bad
Posted on Mar 22, 2010
  • 40 Answers
SOURCE: Kenwood kdc-bt742u flashing protect and no sound
If protect is coming up on the display, it means the system is detecting a short somewhere on one of the speakers and so is turning the amp off to avoid damage.
Check all the connections at the back of the amp to ensure they are not shorting, and at the back of each speaker, if nothing is found there, check each wire for damage, or a bare wire touching the body of the car
Posted on Mar 25, 2010
My Kenwood KDC-MP142 in protect mode. is there a reset button??
My kenwood is stuck completely in protect mode. I ve everything listed and it wont come out of it. So should i assume the unit has gone bad?
Oct 20, 2011 | Kenwood KDC-MP142 Car CD/ MP3 Player
Kenwood kdc-mp832u keeps flashing protect and will not clear... what will fix this
hit the reset button on the face of radio with a ball point pen or similar
Sep 23, 2011 | Kenwood KDC-MP832U
I am installing kenwood kdc-mp443u. it is flashing protect and i can't remove it. can you help please?
A speaker wire has a short-circuit, crossed, or touches the chassis of the vehicle it activates the protection mode function.
? Wire or insulate the speaker cable properly and press the reset button. If the "PROTECT" code does not disappear, consult your nearest service center.
I have attached a link for you which is for a free Kenwood KDC-MP443U instruction manual download. Nice receiver by the way!
Kenwood KDC MP443U Instruction Manual
Dec 18, 2010 | Kenwood KDC-135 CD Player
Kenwood KDC-MP732 CD Player in protect mode how do i get it off had a blown speaker fixed it and still in protect mode
Protect Mode (Blink): The speaker wire has a short-circuit or touches the chassis of the vehicle, and then the protection function is activated.
Solution: Wire or insulate the speaker cable properly and press the reset button.
Here is a copy of the Instruction Manual for the Kenwood KDC-X790 and KDC-MP732.
Jul 25, 2010 | Kenwood KDC-MP732 CD Player
Kenwood car stereo cd player reads protect mode how do i fix this
i have a kenwood kdc-241 car stereo and it has gone onto protect mode i have done everything it says in the manual and even taken it out of the car just in case it was damp i have tried putting it back in but still is in protect mode can anyone help me please
May 25, 2009 | Kenwood Car Audio & Video
Car Stereo in Protected Mode will Not Play Radio or CD
try the small reset on the lower right hand side of the player it fixed mine
Feb 03, 2009 | Kenwood KDC-MP228 CD Player
Security Code for Protect mode
Turn on the car so the radio is flashing "Protect." Look on the front / removable face of the stereo. On it you will find a small round hole - that's a reset button. Find a small paper clip, unfold the clip and stick it gently into the hole. The "Protect" will stop flashing, and Kenwood will be displayed. Unfortunately all your settings/presets will be gone, but at least the stereo is working again!
Apr 30, 2008 | Kenwood KDC-W3534A CD Player
Kenwood cd receiver KDC-MP436U
Protect:- The speaker wire has a short circuit, or touches the chassis of the vehicle, then the Protect function is activated. Wire or insulate the cable properly and then press the reset button. If the "Protect" code does not disappear, consult your nearest service centre.
Mar 20, 2008 | Kenwood KDC-MP235 CD Player
Security
"Protect" isn't for security on a Kenwood; it's caused by a problem with the speaker output. There may be a defect in the CD player, or you may have a blown speaker or a shorted speaker wire in the vehicle. Try disconnecting all the speakers and see if the unit still shows "protect" when you turn it on. If it still shows the "protect" message with no speakers connected, the unit needs to be serviced; if not, re-connect the speakers one at a time until you find out which one is causing the problem.
Aug 10, 2007 | Kenwood KDC-MP232 CD Player
Protected
Wires are exposed. According to the manual, the wiring is grounding out or exposed at some point between the head unit and the speakers.
Sep 13, 2006 | Kenwood KDC-MP332 CD Player
Kenwood KDC-MP228 CD Player Logo
595 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
