Hi there turn on my jvc tv and within seconds went off ,checked the fuse in the plug but that was ok.The tv is only 2 yrs old and is a very good set
  • 8,617 Answers
I will need the model number in order to help you. Please respond to this same post when replying
Posted on Jul 09, 2008
After moving dryer to new apartment, worked at first but now won't turn on
Did you check the power source? You could have popped a breaker (or fuse) if the dryer circuit in the new apartment is inadequate. Might have been good for one shot, then no more.
Sep 03, 2012 | Maytag Dryers
Power surge from storm. Power light turns on for 2-3 seconds and goes off. Previously had a power supply replaced 3 yrs ago. tv is approx 12-15 yrs old.
MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ONFOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device" and "menu"buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix.
before you rate this information or if you have questions let me know what you find.
SD TECH
Jul 25, 2011 | Mitsubishi WS-55511 55" Rear Projection...
I purchased a JVC LT52X579 March 30/09. The TV would phase out by itself and then restart by itself. Some times it would remain on and could be cut off only by unplugging it from my sudge protection...
Please unplug TV from wall socket for couple of minutes, replug back in and turn ON.
If still does not power up, try it in another wall socket.
Also check standby/ power light flashing or its solid at TV.
If standby light is flashing or its not lit then TV got power supply problem and requires qualified TV tech. I hope TV is still under warranty so ask for warranty cover to store.
Thanks.
Jul 24, 2009 | JVC Televison & Video
Tv problem
see if the fuse is ok
Nov 23, 2008 | Apex Digital GT2011S 20" TV
JVC 27230
Hi, last night I tunred my tv off and when I went to turn it on in the moring, the timer light keeps flashing. I have no reason to set the timer. I've tried to un-plug it and plug it back in but it keeps turning off. What can I do? Thanks
Mar 29, 2008 | JVC AV-27230 27" TV
Sony wega
ok,just check the fuse if it is open,and when it is open,replace it with a new one.then check also the str,the regulator and the horizontal output transistor.
Oct 22, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Jvc AV-36f802 not power up, automaticly shut down within 2 seconds
Hi, You may also want to check the Vertical IC. In some units I've worked on, failure or cold solder in the vertical IC triggers protection. Good luck and cheers.
Aug 15, 2007 | JVC AV-27820 27" TV
Horizontal Lines
The unit most likely has a short in the horizontal section and would require repair by a service center. Go here to find a JVC repair center in your area http://maps.jvc.com/cAscList/
Sep 18, 2006 | JVC AV-56WP74 56" Rear Projection...
JVC TV-13143 13 in. TV/VCR
Its could be a fuse but highly unlikly. A surge will usually blow out the power supply, like short out the rectifiers,or the standby power supply. Its best to let a trained servicer look at the set. Good Luck
Aug 13, 2006 | JVC TV-13143 13 in. TV/VCR Combo
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
Electro Med Services...
