Ricoh lw310 How do I access the used toner bottle?
  • matthew987 Jul 09, 2008
    Thanks I figured it out. It was fairly simple. I really appreciate the quick response.
  • bstjcjc Aug 22, 2008
    i need to get to the used toner bottle on a ricoh lanier lw310. could you please tell me how?
    Problem Solver:
  • 6 Answers
Unless you care to risk damaging the copier, I'd recommend having a service tech empty the used toner bottle.
Accessing it requires removing two covers, loosening a leaf spring, and removing the toner overflow sensor before you can remove the bottle. Then you have to reverse the procedure.
Posted on Jul 09, 2008
We have a Ricoh Aficio CL3500N and are getting an error stating: "Used toner is almost full." No manual to refer to. Thank you!!
Hi there, You can just empty the waste toner bottle. here is what you need to do. Here is also a manual for your machine http://support.ricoh.com/bb_v1oi/html/oi/re/model/cl3500/cl3500en.htm Detailed instructions on cleaning the Waste toner bottle on Page 32 of the Maintenance Guide. Instead of replacing just empty it. Just be careful as the toner is toxic so you can also vacuum the toner out of the Waste Toner Bottle.
Regards,
Jul 27, 2011 | Ricoh Aficio CL3500N Laser Printer
Ricoh aficio Aficio 3224C used toner bottle -1 is full
On a 3224, the used toner bottle is easily replaceable. To get to it, open the front cover of the copier. In the lower left corner, you will see a white or light gray plastic container which slides straight out -- that is the used toner bottle. You can replace it (if you have a new one) by taking the old one out, putting the black plug in the hole to prevent toner from spilling, throwing it away, and inserting the new bottle. If you don't have a new used toner bottle, you can empty this one out into a large bag or trash can and then reinstall it.
Mar 18, 2011 | Ricoh Aficio CL3500N Laser Printer
Pls we need your help with ricoh affico printer 3224C the screen of it write this message : used toner bottle setting error used toner bottle -2 is not set properly. open the part as shown and set the...
look my friend used toner means that this toner is disposal or exhausted ok ensure that empty exhausted toner not mean fresh toner are yo ander stand
Jan 12, 2011 | Ricoh Aficio 1035 Copier
Ricoh copier imagio error used toner bottle is full
Change the used toner botle,desasembly the LCT tray,open the front cover and change the waste toner bottle.
Feb 09, 2010 | Ricoh Aficio 450 Copier
How to replace waste toner bottle for Ricoh Aficio w3600
1. Lift the original feed unit.
2. Lift the upper unit.
3. Right upper cover
4. Right cover [
5. Loosen the leaf spring and lift it.
6. Toner overflow sensor
7. Toner collection bottle
Once you have it out jsut dump it out (carefully) remove the sensor on the bottle and wipe clean reinstall the sensor re install the bottle and you should be good to go
Jan 21, 2010 | Ricoh CL3000E Laser Printer
I need to empty or repalce the used toner bottle
Hello sir; You may open side door, you will find out a retangle plastic box that is the waste toner bottle, on the top of waste toner bottle have a green knob, just slide it to right, you can remved it and dump it out.
May 18, 2009 | Ricoh Aficio CL3500N Laser Printer
Used toner bottle full on a ricoh aficio 400
The sensor is dirty or damaged cleans or replaces. This is not reset.
Apr 08, 2009 | Ricoh Office Equipment & Supplies
Used Toner Bottle Full Ricoh Aficio 1035P
The used toner is stored in the Transfer Belt assembly on the right door that you open to remove a jam. Remove one spring on each side and release the catch while gently lifting up on the belt and roller assembly. It swings 90 degrees up from the rest of the assembly. There are 6 screws that hold a cover on the lower assembly. remove it and dump the waste toner. *** VERY MESSY*** have a vac on hand. Not a shop vac unless you want toner clouds floating around the office. If the six screws aren't present, dump the toner out of the **** between the mylar-rubber blade and the lower assembly. once this is done, the message will clear.
Ricoh cl4000dn toner bottle sensor
The toner bottle sensors don't go bad too often. Do you have an extra yellow toner bottle? Try replacing that first. Compare the tray where the yellow toner bottle sits to the other three colors, and make sure nothing where the toner bottle connects is broken or bent.
Jun 22, 2008 | Ricoh CL4000DN Laser Printer
Ricoh 1018d won't add toner after installing toner bottle.
the part numbers are different for each toner from ricoh, Lanier, Savin and Gestetner. From what I recall is the bottles are different, check the old bottle vs new. Also if the machine had run very low you may have to open and close the fron cover several times, this intiates a toner feed program.
www.p4photel.com
http://www.websitetoolbox.com/tool/mb/copierquestions
Feb 26, 2008 | Ricoh Aficio 1018D All-In-One Laser...
421 people viewed this question
jasbo
jasbo
