Question about HP Pavilion DV1010 Notebook
All 3 of my usb ports are not working , what can be causing this
    Genius:
  • 1,288 Answers
Failed USB controller, You could try going into Control panel / Device manager and next to the USB controllers, see if there is any error mark showing against them. If there is, Right click and uninstall, reboot and see if that gets them back working. If not, there is an issue that will need a qualified technician to repair
Posted on Jan 03, 2011
  • HP Master
  • 2,385 Answers
Hello
You can get help form here http://support.microsoft.com/kb/817900 to fix this problem from Microsoft official web site, just follow the instruction.
Good Luck, and do rate the solution if helps
Will not come on was working fine before
If the USB port was fine, the unit would come on regardless if the battery was good or not. This is telling me your USB port is loose. We fix these all the time.
Most issues causing this is a bad charger, dead battery or caused by a loose USB port in the back. If the port is loose, the battery will not be charged and won't even work when connected to an external charger. More info can be found here:
http://www.sharc.net/gps_charger_repair.htm
Sep 27, 2013 | Garmin nuvi 1350 Car GPS Receiver
Where can I get a replacement for my 2 front usb ports on my optiplex 760..they are not working??
I've never seen 2 front USB ports that were bad. I've seen 1 that was defective because the USB device that was plugged into it was broken off. However in that case it caused the power supply to short out and prevent the computer from powering on. Here is a link to your model:
ftp://ftp.dell.com/Manuals/all-products/esuprt_desktop/esuprt_optiplex_desktop/optiplex-760_Service%20Manual_en-us.pdf
If the USB ports on the back of your computer work then the front ones should too unless there is a connector dislodged to motherboard. All USB ports use the same circuit.
Jan 29, 2013 | Dell OptiPlex 760 MT Desktop Computer
My hard drive is not visiable in system
Ok try to plug it to the USB port at the back of your CPU usually USB port at the back of the CPU supply sufficient power to the device that was plugged in that port so it functions properly cause a USB device plugged to a USB port w/ low or insufficient power supply in that device may cause the device not to work properly that's the reason why your portable HDD wasn't recognize by your system..
Jul 08, 2011 | Transcend INFORMATION : 320GB 2.5 inch...
My Dell Latitude D400 laptop's USB ports stopped working. They used to work fine, now they don't recognize anything (card readers, mouse, camera, etc.) I removed the USB port drivers and reinstalled. It...
USB port is corrupt...if all that you said is what is happening then the best is to
buy a keyboard to USB port convertor....
refer this image....Ebay has it for about 1$
May 10, 2010 | Dell Latitude D400 Notebook
Keyboard doesn;t work at all. Keyboard checks out OK at another PC
Is this a USB or PS/2 keyboard? If it is a PS/2 then the port that is integrated on the board is not working. If it is a USB, try plugging it into another USB port and see if it will work. If it does not work on either port then the ports on the system board are not working. It means u're having some malfunctions on the system board itself.
If it is a USB keyboard and it is that the USB ports integrated on the system board are not working, buy and install a PCI card with USB ports. It should work then.
Mar 15, 2010 | Dell 0Y3740 Keyboard
One of the USB devices attached to this computer has malfunctioned, etc.
This problem is caused by a USB ports of the motherboard. Try to insert the usb devices in the different usb ports and if all ports you inserted encounter the same problem then probably the ports has technical hardware problem. To solve this, buy an expansion usb card to your computer. Be sure also that the usb devices you inserted in your computer in properly working and has no defect to determine that the ports are the problem and not the devices. Please don't forget to rate me..Thanks..:-)
Oct 26, 2009 | HP LaserJet P2015 Printer
Usb ports loose and now wont work
Even taking a laptop apart (to board level) is tough, but you need to order the USB socket on ebay and solder the new one in carefully. Are you a qualified miniature soldering expert?
Jun 30, 2009 | Dell Inspiron 8600 Notebook
USB power pulled by Dictaphone 0PSHM01-006?
A USB port supplies 5v
As the OPSHM01-006 was made to work with a standard USB port it should only pull current equal to what a standard USB port is rated at.
If when the machine is plugged in it causes the host machine to get sick or it will not operate there is a component down in the scanner
Jun 25, 2009 | Computers & Internet
Canonmax310 negates other usb ports
Local computer shop employee suggested that the USB ports on the front of the computer might be the problem rather than the printer causing havoc. I connected all devices on the back USB ports and the problem was corrected.
Thank you for the opportunity to seek help with this matter.
Nov 24, 2008 | Canon PIXMA MX310 All-In-One Printer
Front side USB port is not working
On some computers the front usb ports are like a usb hub, they don't have enough power to power up a hard drive.
Nov 04, 2007 | ASUS M2N-MX Motherboard
HP Pavilion DV1010 Notebook Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
