Question about Hammering
Hi, knocking off some plaster in my living room, my fuse box tripped, some numpty had buried bare cables under it, if i knock the switch back on, it pops and knocks off again, could it be a fuse problem ??
  • 2,098 Answers
The problem is not in the fuse.
It only shows that's the fuse doing its job.
You have a short circuit my friend that's why your fuse tripped because it is guard to avoid further damaged to you and your property.
I've adviced you to look for a qualified electrician to locate the short circuit.
Once it was isolated by the electrician it will be back to normal again.
Posted on Jan 03, 2011
Where is the auxiliary power fuse on a 2004 Chevy Malibu
Theres a fuse box in the trunk left side under a plastic knock out another on the passenger side near floor below the radio behind plastic knock out..another under the hood under the battery cover. They all have a place for AUX add ons.
Oct 18, 2014 | Chevrolet Malibu Cars & Trucks
Turn on starter and knocks but will not turn over
Hi Anonymous, and the usual suspects are:
1.Ignition/Light Key Switch not in IGNITION position.
2.Engine Stop switch in the OFF position.
3.Discharged battery, loose or corroded connections check negative cable at both ends. (solenoid chatters).
4. Bank Angle Sensor tripped and Ignition/Light Key Switch not cycled to Off and then back to
5. Starter control circuit, relay or solenoid faulty.
6. Electric starter shaft pinion gear not engaging or over-running clutch slipping.
7. Security alarm not disarming
For a prime suspect please visit website below and good Luck.
Big Twin Carb EFI DTC Intructions codes Harley Davidson Forums Harley...
Jan 07, 2013 | Harley Davidson FLHTCUI Electra Glide...
I have a 1994 Chevy Silverado and every time I turn on the ignition, the knocking noise begins from under the dash somewhere. If I remove the fuse to the a/c/heater it doesn't make a sound when I
Try starting the truck so it makes the noise.
Then switch the air control to "fresh".
If noise stops, it is probably the motor that closes flap to recycle the cab air.
It would be found under the dash, under the glove box, & would need to be replaced.
Sep 20, 2012 | Cars & Trucks
Diagram location knock sensor quest 1998,I don't find the knock sensor on the nissan quest 1998
it is buried under the intake manifold. But ignore the knock sensor code, it means absolutely nothing. It will not resolve any issue you have. The KS code is usually the result of a broken engine mount.
go here if you have any issues.
http://groups.yahoo.com/group/villagerquest/
Jun 08, 2010 | 1998 Nissan Quest
Dryer blows cold air
check curcut breaker to make sure that the dryer didnt trip it if you have older setup with stick fuse's have someone who knows how to test and replace I wouldn't want you to get knocked across the room if you did something wrong or worse
Dec 09, 2009 | Washing Machines
Hi, I've got a problem with inset spotlights
check your wirenut connections in the first fixture. over time, perhaps, the wirenuts may have come loose. other times there is a thermal overload in each fixture which opens because of excess heat.
Oct 25, 2009 | Electrical Supplies
Knock engine sensor light on truck is hesitating/
Did they replace the knock sensor?Check the wire going to the sensor(knock).Look for a bare place hiting up against something ,grounding it out.Make sure the plug to knock sensor is good.And make sure it is making a good connection,Knock sensors also ground a part of the computer to feed back imformation.This connection is a must,the truck will not perform at all,stumble,miss,and carry on.Sometimes even backfire.If they did not replace the knock sensor,replace it with high quality sensor from NAPA,or oem from dealer.This sensor has to be made perfect,no room for inperfection.The knock sensor is easy to replace,they just screw in a hole in the block.When removing the sensors,nothing will come out such as oil or water,this is a dry threaded hole.It is a bell shaped sensor.If you don`t know which sensor is bad,purchase one.replace one,and if there is no change,replace the other side with the old sensor you just took out,it will be a good one.I hope this helps you,Let us know if it does.
Oct 05, 2009 | 2000 Chevrolet Silverado 1500
Location of knock sensor
Knock sensors can be difficult to locate because there usually buried under intake or exhaust manifolds and misc. engine wiring and plumbing. Knock sensors need to hear an engine knocking noise, therefore there usually located somewhere they can hear an engine knock. If it's a V6 then possibly it will be between the cylinder heads and access to them can only be attained by removing the intake manifold. I would suggest calling a Nissan Dealer parts person and ask them. Good luck.
Jun 16, 2009 | 2004 Nissan Frontier
Hammering Logo
Top Hammering Experts
John Trevino
Steve
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hammering Expert? Answer questions, earn points and help others
