Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
RE Craftsman Security+ Opener random opening
Do you meen the batteries in the remotes and the keypad? If they get low can they trigger the GDO without being pressed?
    Brigadier General:
  • 3,614 Answers
Could be possible... or due to low battery the system goes into malfunction... it is better to observe and check your security system,.
let me know more about this problem...
Posted on Jul 09, 2008
Tried to reprogram security code for outdoor key pad on 1/2hp craftsman garage door opener according to instructions online, pressed learn button- put in new 4 digit code-held enter. Lights did not flash...
Seems you've done everything right. Press and immediately release the smart/learn button and then walk over and key in a 4 digit code and press enter. If you are sure the battery in the keypad is good then I think your keypad is on the fritz or the wrong one for that opener.
Apr 19, 2011 | Sears Craftsman LiftMaster Chamberlain...
Flashing green light on garage opener SecuraLift GDO 7v2?
You don't mention any problems so I think what you are seeing is the LED that randomly flashes when everything is working as it should.
Mar 24, 2011 | Sears Craftsman LiftMaster Chamberlain...
Sears garage door opener (GDO) model 139.53985D, only a couple of years old. 315MHz remote controls. Opener has stopped responding to the remote controls,unless a remote is held wihin 12 inches of the...
There is no way to change that radio frequency it is set by the government. Sears service technicians have an instrument to help them locate the interference that causes this type problem.
Oct 16, 2010 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain GDO light turns on randomly at any time of day or night. (Whisper Drive with Motion-Detecting Control Panel 935CB.)
If you don't have any puppies or strange animals running around your garage I would disconnect the wall control for a couple days. If your problem stops I would suspect that control. If you have a heated garage I would also make sure there is nothing that could be moving from the air movement from the furnace.
Apr 02, 2010 | Sears Craftsman LiftMaster Chamberlain...
Remote works randomly,changed batteries now the
Keypad flashing is normal. Sounds like you may have a bad logic board. Try programming everything.
Dec 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Red service light is on the diehard battery backup of my craftsman garage door opener.
time to change the batterys- they cost $90. and owner can install or a gdo repairer can, but consumer should, its harder to make coffee then replace these batterys.....
Nov 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman GDO - Remotes not working
I think this is an easier way to program. Press and hold the button on the remote and then press and immediately release the smart/learn button on the rear of the motor unit. Do this for each remote you have.
Jul 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
Only 1 remote will work at a time
One of your remotes has reverted to an earlier technology and they will no longer work with each other. You need to purchase a new remote making sure you get the same model number. Then you will find you can program 2 that will work with each other and 1 that will not. Remove the battery from the bad remote and toss it so that it doesn't cause problems down the road.
Jul 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
Red light/stuck GDO Sears 139.53600
is it locked. does door lift manually. are springs/cables ok?
Jan 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
70 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
