(Kv-27tw70) sleep is the default status and Causes tv to turn off after 30 seconds or so...no Remote, what do I do?
    Brigadier General:
  • 8,909 Answers
Aquire a remote control and turn the sleep option off. It cannot be done otherwise.
Posted on Jan 03, 2011
How do I set the sleep timer? We got the tv from a friend and it had no manuel.
Programming the Sleep Timer:
  1. Press and release the TV key.
  2. Press and hold the SLEEP key for three seconds. The illuminated component name turns on.
  3. Release the SLEEP key.
  4. Using the number keys, enter the desired time in minutes (from 1-99 minutes). To set the timer to an umber under 10 minutes, first press 0 and then the desired number (e.g.,05 for five minutes). The illuminated component name blinks with each key press.
  5. Once the second number is entered,the illuminated component name turns off.
    Tip Any key press other than the number keys is ignored. If you don't enter the sleep time within 10 seconds after pressing the SLEEP key, you must start over at step 1. The illuminated component name blinks four times and then turns off, indicating your attempt to program the Sleep Timer has been unsuccessful.
  6. The Sleep Timer is now set.
  7. Leave remote aimed at the TV. Once the Sleep Timer is set, you can continue to use the remote without affecting the Sleep Timer. However, because the timing mechanism for the Sleep Timer is built into the remote itself, the remote must be in TV Mode and pointed at the TV to activate the Sleep Timer.
    Note: If the ON·OFF key is pressed, the Sleep Timer is canceled.
Aug 19, 2011 | RCA Rcr461 Remote Control
Tip
To Clear Green Screen Problem
Here are the proceedures for taking care of this problem:
1) Turn on TV
2) Make sure the remote toggle switches are set to "TV" and "VCR" respectively
3) Press the "Sleep" button
4) Simultaneously press "Display" and "Video Status"
5) Press "2" (Self Check)
6) Turn off the TV
7) Wait for fan to turn off (30 seconds or so)
8) Unplug TV
9) Wait for 30 seconds
10) Turn TV back on
Hope this helps
on Feb 21, 2008 | JVC HD-56G886 56" Rear Projection HDTV
I need to know the service mode of JVC TV flat screen
With TV powered ON press: [DISPLAY] and [VIDEO STATUS] on the remote at the same time.
-or- Press the [SLEEP TIMER] key and set the SLEEP TIMER for "0" MIN. While the SLEEP TIMER information is still on screen, press the [DISPLAY] key and [VIDEO STATUS] key of the remote control unit at the same time to enter the SERVICE MENU.
Exit the service menu by twice pressing the [EXIT] key on the remote.
Mar 18, 2011 | JVC AV-32S575 32" TV
How do I clear or release the timer? When I turn my TV on the red button is flashing indicating that the timer is on.
Look on the remote for button said SLEEP push it clear all timer like 30 60 120 mins to off.The tv is not on a timer anymore.
Jan 06, 2011 | Sony FD Trinitron WEGA KV-34HS420 34" TV
We got a free Sony TV from a neighbor moving out of state. No owners manual or remote, but its worked fine until today. This morning the 'sleep' and 'timer' lights are both blinking, alternately at one...
Unplug tv from wall socket for minute to get its timer function reset, then replug back in and turn it On.
If problem still not solve, let me know.
Thanks.
May 16, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Channel display for Sony WEGA KV32FS100 will not turn off
Most all Sony models use the same programming for the remotes. Borrow a Sony remote and push the display to turn it off.
Mar 23, 2009 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sleep timer?
Sleep Timer option is available in remote only.
Aug 10, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
TV CUTTING OFF
Check this, for how long the TV is on? 30 min., 45min, 1 hour? because maybe you have accidentally programmed the SLEEP control. If so, go to the set up options or menu with the remote control and check the status of the sleep power off time. Or maybe the TV has the otion to power off automaticly set the same way that is the alarm turn on.
Jul 12, 2008 | Mintek DTV-373-D 37 in. LCD HDTV
Sleep light
i have a simular problem with my sony kvfs120 32, my stand by timer is flashing and the tv will do nothing else. the flasing light is actually a self diagonistic code mine is flasing 5 times.
Ray
May 20, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Magnavox lcd tv
Setting the Sleep Timer sleeptimer.gif The sleep timer allows your LCD TV to automatically turn OFF after a given amount of time. You can set the sleep timer using your remote control or through the onscreen display (OSD).
TO SET THE SLEEP TIMER USING THE REMOTE CONTROL
1. Press the SLEEP button on the remote control. The sleep timer appears at
the top of your screen.
2. Press the SLEEP button one or more times to select the time you want.
3. Press the EXIT button to hide the sleep timer display. Your sleep timer is now running in the background. The sleep timer will be hidden after 10 seconds.
Turning On the LCD TV.
1. Press the MAIN POWER switch in the back of the unit (see Back Connectors for location). The Status LED on the front turns orange
and your LCD TV is ready to turn on.
2. Press the POWER button on the front of your LCD TV or on your
remote control. The Status LED on the front turns green.moz-screenshot-6.jpgmoz-screenshot-5.jpg
Dec 18, 2007 | Televison & Video
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
