Question about Xerox Office Equipment & Supplies
Photocopieur Xerox 3050 affiche message (incident NVM) comment faire?
2 Suggested Answers
  • 22 Answers
SOURCE: MON PHOTOCOPIEUR AFFICHE LE CODE
L6 = Polygon Motor Lock Detection
Polygon motors are not serviceable items.
Try switching the machine off/on. If the code doesn't clear then you will need to get the motor replaced. Quite often the motor will have made a screeching or rattling noise before it fails.
Hope this helps
Posted on Feb 10, 2011
MON PHOTOCOPIEUR AFFICHE LE CODE ERREUR L 6 SUR LE PHOTOCOPIEUR SHARP AR-205 DIJITAL QUE DOIS-JE FAIRE
Hope this helps
Feb 09, 2011 | Sharp AR-M205 Copier
I have Color Registration problem in Xerox m24.I hv checked all 4 Drums.They are free .IBT assembly is free.On PWS Regicon setup, it gives NG.There is Color Regidtration issue.Kindly suggest solution
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
Jan 17, 2011 | Xerox WorkCentre M-24 Color Copier
As soon as machine is turned ON error code 124-315 appears. pls help!
Here is a note from a Xerox Tech:
Everything points to NVM coruption so try with reseating the NVM pwb. And then maybe NVM init.
Hope these helps.
Nov 23, 2010 | Xerox DocuColor 12 Printer
Xerox 3050 service manual
sir,
i want get solution for my 3050 xerox machine. while taking the copy the background coming black, idon't know the reason, i changed explosure lamp, primary corona end block, tonner, but till the problem is background black, if one copy comes clear another copy will be black. if know the solution kindly pass the message to my cell no.7760191629.
thankyou,
regards,
prabhu
Sep 11, 2010 | Xerox Office Equipment & Supplies
Error-9-354
User Interface (UI) DIAGNOSTIC ENTRY:
Turn on the power… then while holding down the ‘0’ button, press ‘Start’.
The screen will prompt you for an “Access Number”… use the keypad to enter ‘6789’ which is the Default Access Number.
This should bring you to a menu of options to choose from:
• NVM Reset (Non Volatile Memory) / NVM Initialization
• NVM Read / Write (memory adjustments) you will need to know which codes do what
• Component Control (for testing sensors, motors, etc.)
• Print (for running Test Patterns from Diagnostics)
• Subsystem Check (for fuser nip measurement check out, and developer unit check out)
• Max Setup (for setting up copy quality)
Set NVM to 776-060=0 and 776-372=0
Hope that helps
Mike
Sep 23, 2009 | Xerox DocuColor 12 Color Copier
NVM settings
In tray one there is a hidden compartment take a flat blade screwdriver to the cover as you are looking directly down at the top of the front of the drawer you should be able to open the top of the compartment. In there is what is called the birtcertificate for the machine and the original NVM settings are in there.
Dec 24, 2008 | Xerox DocuColor 12 Printer
82 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
