Question about Microwave Ovens
What would be the approx price of feber cimini light..?
    Brigadier General:
  • 8,909 Answers
Best prices will be on ebay.com
Posted on Jan 03, 2011
Kenmore Elite Microwave has power but will not start?
switch if off completelty for approx 5 mins and then power it back on
Oct 26, 2011 | Microwave Ovens
Tip
MICROWAVE POWER TEST Hi Everyone, In this tip I will show you how to easily test...
Hi Everyone,
In this tip I will show you how to easily test your Microwaves power. If it is sufficient, or if it is not heating effectively anymore.
Non heating Microwaves are a common issue, and the most likely component that is faulty is the Magnetron - These days Magnetron's are quite expensive (usually about 50% the price of a new Entry Level Microwave). Low heating could mean a Magnetron becoming faulty (unlikely, as a Magnetron either works, or it doesn't work)
Tools required: A Normal Glass (Heat-resistant, in other words Microwave friendly), Water (Room Temperature) , a Centigrade Thermometer (Can get this at any Pharmacy)
Procedure:
1) Fill a glass with approx. 125 ml water. Use water at room temperature (from the tap), avoid using refrigerated water as this will work against the test we are doing.
2) Measure the initial temperature of the water with the thermometer (It should be between approx. 10 & 20 degrees).
3) Place the glass with the water about 2 cm away from the center of the Microwave Oven plate.
4) Heat the water at full power (The highest setting possible on your Microwave) for 70 seconds.
5) Stir the water (For 5 - 8 sec).
6) Measure the final water temperature with a thermometer.
7) If the increase is 45 degrees or more, then your microwave is heating sufficiently, if not it could mean replacing the Magnetron, or purchasing a new Microwave.
I hope this guide as helped you. If it has, please rate it accordingly.
on Apr 23, 2011 | Microwave Ovens
I have a sharp carousel 1200 watt and my daughter cooked a toaster strudle for 2 mins and the microwave shot flames and has no power any more. it is approx 7 yrs old, would this do that or possible another...
It sounds like the magnetron has failed, and the main fuse has blown, this is not related to what your daughter put in. This gave out because of parts failure, due to repair cost consideration should be given to a new one because prices have come down.
Feb 23, 2011 | Sharp Microwave Ovens
Have a ge profile spacemaker microwave model# PNM18715M155. The vent fan cmae on while cooking and it wwill not go off. I unplugged and waited 5 min. plugged it back in a the fan still came on.
most likely you have a bad thermal fuse/limit device located behind control panel... there is a small round approx. size of a quarter that has 2 wires attached to it. this device has most likely failed as it is a heat limit and for some reason either the unit got to hot and closed the limit to allow the fan to continue to run or the limit itself has failed... you will have to remove control panel to gain access.... www.sears.com then hit the parts direct link on top and enter your model number to find the part and price ... good luck to you...
Jan 27, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Runs but won't heat
if everything else is working but the heating portion then your problem is most likely going to be either a bad magnetron on unit or a thermal cutoff on the magnetron... the way to access the magnetron is unplug unit and remove touch pad.. located behind touchpad you will see a square device approx. 3 inches by 3 inches and there should be a limit switch attached to the unit... remove wires and test limit switch using a meter. it should be closed and give contuinity through it... if not it is bad.. if it does then most likely the magnetron has failed ...good luck to you ..the magnetron is general a expensive part compared to the prices of the unit...
Jan 19, 2011 | Hotpoint RVM1435 Microwave Oven
Replace my glass tray
The part number is 252200200010 and you can get one from Encompass.
Apr 16, 2010 | Emerson MW8168B Microwave Oven
SMEG SA35MX no longer heating. Light, fan & timer all still working but no heat. Approx 2 years old. Is there a fuse or other component I can replace myself ?
In all likelihood the mangnetron has failed, or perhaps even the Power Supply. or a fault that is shutting the system down for safety reasons You need to have it serviced by a reputable service centre/man. Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one.
Feb 10, 2010 | Microwave Ovens
Won't Heat - Panasonic NN-S668BA
first off does your unit have the word inverter writen on it if it does it could be a failed magntron or the invertor pcb approx repair between £70-150, if it does not then it could be the capacitor or the diode or the hv fuse or the transformer this would be a repair under £90 sorry i cant be closer in price it would need someone to have the right testing tools
Oct 08, 2009 | Panasonic NN-S668BA/WA Microwave Oven
Microwave oven will not turn on. no light, no display.
First check breaker at breaker panel. Then if you remove the front vent and key pad you will find a paper with breakdown of unit. Look for fuse, check with a tester, if bad replace, if not check all cavity switches, approx 3 or 4, test these. One of these three checks should solve your problem.
Jul 03, 2009 | Emerson Fans Emerson 1052466 1000 Watts...
Can the light bulb be changed in this model?
Normally a microwave has to be opened to do this , very high voltage inside approx 2400v , but a normal screw in microwave bulb.
May 12, 2009 | Microwave Ovens
Microwave Ovens Logo
46 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
