Question about Hotpoint Ariston AW125 Front Load Washer
Hotpoint 149pm goes through the wash cycle but won't finish the cycle is left with water in it and all button flash and the display says FO5
    Problem Solver:
  • 4 Answers
If your washer wont go into a spin mode it will probably the carban brushes that need replaceing in the motor
Posted on Jan 03, 2011
Hotpoint aquarius WF541 won't finish a cycle
What is the model number? Look inside the door area.
Oct 18, 2012 | Hotpoint Aquarius WMA42 Front Load Washer
My machine will not finish a cycle and just stays filled with water.
It sounds as though you either have a clog in the drainage system of the machine, or a bad drain pump.
May 06, 2012 | Hotpoint Washing Machines
Machine stoped half way in to cycle fo5 appeared on display panel
You need to clean the pump filter.
Remove lower rear panel of washer.
Locate and remove large black hose on bottom of drum.
Remove an clean plastic filter inside the hose.
Reassemble and test for leaks.
Jan 23, 2011 | Hotpoint Washing Machines
Hotpoint qualtis washing machine spin display showing H20 and won't start. model AQXXF 149PM
H20 means a problem with the water inlet supply.
Check the inlet hose/s for a kink or restriction, make sure it is turned on fully at the supply..
If it is cold fill only, could be a frozen pipe.
Hope this helps.
Jan 07, 2010 | Washing Machines
Hi hotpoint 7kg washing machine ultima digit washes fine and spins etc but i keep getting f05 flashing on display what do i do
Hi there usually the FO5 Problem is pump draining problem, check the U Bend under your sink for blockages also the outlet pipe for blockages, you may even need to take of the front lower panel and you should find a small pipe and you can clear and drain water from that also and clear of any bits. hope this helps
Jul 19, 2009 | Hotpoint Ariston AS65VXSNA Electric Dryer
Hotpoint wd44d wash/dryer wont finish a wash nor wont pump out
there may be something stuck in the pump itself. hairgrips and brawires are a common find.
Jan 19, 2009 | Hotpoint Ariston WD440G Front Load...
My hotpoint aquarius wd440 washing machine - flashing lights ?
I have a fairly new Hotpoint Aquarius machine (out of guarantee).
When it is switched on, all of the red lights flash and it will not operate.
Can you help please ??
Oct 18, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Ariston AW125 Front Load Washer Logo
164 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
