Question about Toshiba Televison & Video
Cannot view other channels while recording. - Toshiba Televison & Video
    Brigadier General:
  • 8,909 Answers
If you are using the output of the tv to record the programme or recording from a digi box with only one tuner, you cannot watch an other channel at the same time because there is only one tuner or channel selected.
Posted on Jan 03, 2011
My vcr will only record the channel I am on. When I try to set programming for another channel it will not record unless I am on that particular channel.
The vcr will only record what it is given to record. If your TV is the recording source, it has to have dual tuners to allow recording of one channel and viewing of another, as does the vcr.
Hope that clarifies the situation.
Dec 30, 2010 | Televison & Video
How do i get my funai vcr to record from my freeview box. I can only record through my analogue channels. I have a funai vcr either 31B-750 or 31B-754 (PDC) and the freeview is an Astratc TopD2
hi, how is the free view running through the video?
Option 1(this is the most complicated way if you are using scart lead or the three color leads then skip to option 2)
if you using the normal arial socket ie arial from roof goes into free view then from free view into vid then vid into tell then what you need to do is make sure on the free view that you have a menu screen on the screen either tv guide or something that will stay on their.
Now put the video on a channel you dont use say 6 then you need to use the video remote and then enter the setup mode and then start the scanning process to look for the signal keep going until you get the menu screen that you opened on the free view then store this as channel 6 on the video.
Now when you want to record from the free view you put the video on channel 6 and put the free view on the channel you want to record.
Option 2:
If you free view box is using scart leads and has two scart lead outputs on the back, ie one for the telly and the other for the video, if you have it like this then plug telly scart into telly and video scart into video.
Now in the back of the video you should have scart lead coming from the free view, and maybe one coming from the video into the telly
If this is the case then all you need to do to record off free view is switch the video on the when you choose what channel you want to record instead of choosing 1 to 5 for normal channels you need to select av scroll down the channels past zero if you have not got av button once av is selected you should then see the free view channels try by pressing guide on the free view and put the video on av this should then let you see the free view via video if not dont worry press record for 5 min then rewind and press play it should now play back the free view you was just watching.
Option 3 now if you have it set up any other way just let me know how then i can assist you further ok.
If you have any problems following my instructions then just post me a message back and ill be glad to assist you further ok.
Many thanks for using fixya.com
Nov 18, 2009 | Electrical Supplies
Hi just got a LG dvd/vcr Model RC897T. I have it hocked up right, but i can't get it to switch over so that it would be seen on the TV. can you help
If a cable box is not required for cable signal reception, connect the cable line to the ANT. IN connector on the recorder.
If a cable box is required for cable signal reception, connect the cable line to the IN connector of the cable box. Connect a coaxial cable from the OUT connector of the cable box to the ANT. IN connector of the recorder.
To view or record a CATV channel:
  1. Tune the TV to the Recorder output channel (CH 3 or 4).
  2. Set the Recorder channel selector to the cable output channel. (Example: CH3).
  3. Select a channel using the cable converter.
With this connection, you cannot record one program while viewing another.If you are using a cable box to tune channels, it is not necessary to do Auto Channel Set.
Oct 20, 2009 | LG RC897T DVD Recorder/VCR Combo
I have purchased a Teac HDR2500T video recorder. I can set up to record television programme through EPG or PVR. I can see in LIST that the programme is recording, however when the programme is finshed,...
The part re the other channels having no signal....I had the same problem with mine and that was because the small loop cable in the back wasnt right. I could watch all channels, press record and still watch that channel but try to watch a diff channel while its recording and they were gone. As soon as I had the loop cable in properly it solved the problem. Hope this helps....
Sep 06, 2009 | Televison & Video
How to get all freeview channels-all i get is the first 5 channels
Go to menu, find "autoprogram" setting and select it. It will scan all available channels
Aug 17, 2009 | Panasonic DMR-ES30VS DVD Recorder/VCR
Sony bravia-unable to tune in video channel via dvd
thethe wires have to run out of your cable box into the dvd recorder then back out to the tv,try rehooking it up
May 19, 2009 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
Panasonic dvd recorder dmr-ex75
Change the AV settings on the DVD or TV to be the same format. Feeding AV into an AV-S gives B&W
Sep 16, 2008 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
CANT FIGURE OUT HOW TO RECORD OFF AN 'AV' SETTING
The method is the same as for TV channels; select the input (i.e. view the desired channel), then press the record button. AV1 and AV2 usually are at the end of the channel list, and can be found by pressing the channel UP or DOWN buttons.
Aug 13, 2008 | Sony RDR-GX300 DVD Recorder
Viewing cable tv channels
Use an av output from your media box and plug it into the line input of your DVD recorder. It can record using the line input of the DVD recorder.
Aug 09, 2008 | Televison & Video
Recording and viewing different channels
The EX75 has only one tuner circuit, so you can't watch a different channel from the one you're recording. To do this you will either need a set-top box for Freeview or a Freeview compatible TV.
Apr 10, 2008 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Televison & Video Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
